Reaction 212 turbo vs hsu vtf-2 mk 4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-06-2014, 08:35 PM - Thread Starter
Line voltage's Avatar
I've narrowed my long sub search down to these two. I have a 2100 sq foot room. I'll say 60/40 HT/music. I'm looking for good output but more so, quality sound.
Denon avr-x2000
Monster HTS 5100 MKII
B&W FPM 5 L/R
B&W FPM 6 C
B&W in ceiling 6.5" surround
SVS PB-1000
PS-4
Samsung blu-Ray
Samsung 51" plasma
Line voltage is offline
post #2 of 5 Old 04-06-2014, 08:51 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
I am guessing that the VTF2's ports give it more output from the upper teens to the low 30 Hz region, but the Reaction's dual woofer give it more output above 30 Hz. Basically the Hsu will be better for deep bass but the Reaction should be better for mid and upper bass. The Hsu will have good quality bass, it is using a great driver. The Reaction is new but it looks like it could be good. Your room is huge though (or did you mean 2100 cubic feet instead of square feet?), neither sub will pressurize that entire space. Whichever you decide to get, try to place it as close to the listening position as you can, perhaps in an endtable placement or right behind the seat if possible. That way you will still hear and feel the bass. Otherwise the room may swallow up the sub, and you will hear very little bass.
shadyJ is offline
post #3 of 5 Old 04-07-2014, 05:12 AM - Thread Starter
Yes I meant 2100 cubic feet. And I'm really glad about your placement comment because that happens to be a good spot for it. So, the one 12" hsu ported sub will have more output than the dual sealed?? Are we talking a few db's?
Denon avr-x2000
B&W FPM 5 L/R
B&W FPM 6 C
SVS PB-1000
PS-4
Samsung blu-Ray
Samsung 51" plasma
post #4 of 5 Old 04-07-2014, 05:15 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
With the sealed sub, movie output will greatly depend on your room dimensions.  A ported sub will have great output down to the port rune regardless of room size.  Divide 565 by your longest room dimension in feet, and this will tell you the frequency at which you will begin to get room gain.  Keep in mind room gain will benefit both ported and sealed subs.
bear123 is offline
post #5 of 5 Old 04-07-2014, 10:26 AM
shadyJ's Avatar
Liked: 1350
I am just guessing here, but the Hsu should have more deep bass output, but not as much upper bass output. I would guess that the difference in either region is maybe 3 dB, keep in mind that is very speculative. The performance of the Reaction is largely unknown, it is such a new sub. It looks like it wouldn't be bad though.
shadyJ is offline
