Rythmik FV15HP efficiency - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-09-2014, 11:21 AM - Thread Starter
brutal0101's Avatar
How is the FV15HP so efficient compared to other subs with similar specs such as the Hsu VTF15HP, PSA XS15.
It is also 15' and has a barely 600 watt amp.
I have never had it, I am basing my judgement on the frequency response SPL charts I have seen.
Is it really the best sub under $1500?
brutal0101 is offline
post #2 of 17 Old 04-09-2014, 11:36 AM
bear123's Avatar
Quoted: 1806 Post(s)
Liked: 2684
If you base this on the highest 16-30 Hz output, probably.  On over 30 Hz output, that would probably go to the XS30.
The driver quality of the FV15 is much better than the Hsu, and the amp has nearly twice the power.  Compared to the XV15, which is over $600 cheaper, same thing...better driver, more power, bigger cab.
bear123 is offline
post #3 of 17 Old 04-09-2014, 11:43 AM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 80
I'll float a provocative question that is likely to elicit a debate: considering it's about the same cost, dual XV-15s or a single FV15HP?
Dolby Atmos 5.1.4
Denon x6200
Ascend Acoustics Towers and Horizon Center (NrT)
RSL 34CE in-ceilings (4)
Rythmik E15HP
Jahjd2000 is offline
post #4 of 17 Old 04-09-2014, 11:48 AM
tvuong's Avatar
Quoted: 1793 Post(s)
Liked: 1087
^^ Dual XV15s.
tvuong is offline
post #5 of 17 Old 04-09-2014, 11:55 AM
bear123's Avatar
Liked: 2684
If adding an additional FV15 is not an option down the road, dual XV15's would almost always be the better option imo.
bear123 is offline
post #6 of 17 Old 04-09-2014, 11:59 AM
derrickdj1's Avatar
Quoted: 995 Post(s)
Liked: 733
Efficiency is related to amp design, cabinet size, driver construction and ect. Most subs use little energy until they are under 30 Hz or have a significant bass boost.
derrickdj1 is offline
post #7 of 17 Old 04-09-2014, 12:33 PM
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
I had that option, FV15HP-SE was my choice.
*ENTERTAINMENT PURPOSES ONLY - PIONEER KRP-500M*
(2) Monitor Audio RX6 towers - (1) Monitor Audio RX center - (2) Monitor Audio RX FX surrounds - (1) NAD T758 AVR - (1) Velodyne Optimum 8 Sub
purplerain is offline
post #8 of 17 Old 04-09-2014, 02:11 PM
Kini62's Avatar
Quoted: 1743 Post(s)
Liked: 1556
Depends a lot on your room and whether you want a lot of sub 20hz output and an overall better sounding sub. The servo and amp controls on the Rythmik make a huge difference.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #9 of 17 Old 04-09-2014, 02:20 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
FV15HP. It's just so much better.
shadyJ is offline
post #10 of 17 Old 04-09-2014, 10:44 PM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 80
I finally ended my melodramatic search for a sub tonight. I placed an order for dual Rythmik E15HPs smile.gif .
Dolby Atmos 5.1.4
Denon x6200
Rythmik E15HP
post #11 of 17 Old 04-10-2014, 09:14 AM - Thread Starter
brutal0101's Avatar
How's the sound quality of the XV15 compared to the FV15HP. I have read people in the past who think the sound quality of the Rythmik is clearly better. Sound quality is very important to me, it's not just about more output. If I only wanted output I could have bought a Behringer Concert sub for a lot cheaper.
post #12 of 17 Old 04-10-2014, 10:39 AM
bear123's Avatar
Liked: 2684
From Josh Ricci's Audioholics review of the XV15:
"We found that the XV15 sounded clean, composed and dynamic with music, while possessing extension well below 20Hz in room with plenty of headroom to make its presence felt in a large space on movie night"
http://www.audioholics.com/subwoofer-reviews/xv-15-subwoofer
Data-bass measurements:
http://www.data-bass.com/data?page=system&id=88
bear123 is offline
post #13 of 17 Old 04-10-2014, 10:46 AM
shadyJ's Avatar
Liked: 1352
I consider the XV15 relatively compromised in terms of accuracy based on available measurements. That is an argument that has been done to death here, so if you want to know why, just do a forum search on the matter.
shadyJ is offline
post #14 of 17 Old 04-10-2014, 12:45 PM
tvuong's Avatar
Liked: 1087
Sweet. Congrats!
tvuong is offline
post #15 of 17 Old 04-10-2014, 01:58 PM
Kini62's Avatar
Liked: 1556
Awesome!
Just curious as to why the E instead of the regular F?
Def Tech SC8000
post #16 of 17 Old 04-10-2014, 04:25 PM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 80
Originally Posted by Kini62 View Post
Awesome!
Mainly for WAF. I had to convince my wife that adding a subwoofer upfront would not only provide a big sound improvement but also be unobtrusive. The latter point being her chief concern. The output difference I read is only .5db and it's a little cheaper to boot. I think I save $150 with the E over the F for duals.
Dolby Atmos 5.1.4
Denon x6200
Rythmik E15HP
post #17 of 17 Old 04-10-2014, 08:19 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
Exactly! I would go for the E15HP over the F15HP all day. Cheaper, Smaller, and only .5db difference in output. Seems like a no brainer imo. smile.gif
basshead81 is offline
