Going from 2 to 1 subs? (Outlaw to ?) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-15-2014, 10:29 PM - Thread Starter
Randall.White's Avatar
Quoted: 353 Post(s)
Liked: 89
This is just a "might happen" thread. My wife and I started looking at new houses today and my (2) LFM-1EX subs would not fit into any of the homes we looked at.
Current room size 3400 cubic feet.
Possible new room 2000+/- cubic feet.
For one, the subs I have now would be WAY too big so I'd need to look for a smaller enclosure. So sealed? I've never owned a sealed sub in home audio. Cosmetics aren't that important but I'd like them to look decent. I have NHT speakers so matching black would be nice. I'm mainly concerned about the sound.
Any input? Where to start?
Thanks for any help.
Randall.White is offline
post #2 of 15 Old 04-16-2014, 05:39 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
First, I would really try to make the Outlaws work.  Have you thought of using one or both as end tables to help fit a smaller space better?  If you have to go smaller, dual PB1000's or dual XS15's would be two options.  I think the PSA sealed will keep good output for movies due to the larger drivers.  Rythmik also makes some fine sealed subs if you are willing to spend a bit more.
bear123 is offline
post #3 of 15 Old 04-16-2014, 05:42 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
First, I would really try to make the Outlaws work. ... If you have to go smaller, dual PB1000's ...
+1. 2,000 cu.ft. isn't that large a space. Dual PB-1000s would work very well in there.
eljaycanuck is offline
post #4 of 15 Old 04-16-2014, 06:17 AM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 902
I second the end table idea with your Outlaws. I used to have an EX that served well as an end table.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #5 of 15 Old 04-16-2014, 06:48 AM
flickhtguru's Avatar
Liked: 110
Yes try to make the Outlaws work, I have dual Plus's and have used 1 up front and 1 as an end table then when I moved to a new house and got new furniture I kept 1 up front but now have the other 1 behind the corner of my L shaped sectional couch and WOW!!! bass is awesome.... If you absolutely cant make the Outlaws work I'd look at 2 SVS SB2000's. They should work well in a smaller room and the sub cabinet is a 14.2" cube so very small for a 12" sub.
Shawn
flickhtguru is offline
post #6 of 15 Old 04-16-2014, 02:54 PM - Thread Starter
Quoted: 353 Post(s)
Liked: 89
I've never placed anything on my subs, do they ever shake so hard that stuff will fall over? like drinks or decoration stuff
post #7 of 15 Old 04-16-2014, 05:07 PM
bear123's Avatar
Liked: 2513
I don't think that will be a problem.  My sub is completely inert due to the design, but I know quite a few forum members who use single driver subs as end tables with lamps and such on them and don't seem to have issues.
bear123 is offline
post #8 of 15 Old 04-16-2014, 05:15 PM - Thread Starter
Quoted: 353 Post(s)
Liked: 89
Thanks. I'll give it a test run tonight. I'd hate to have some friends over and a beer or something shakes off or spills over.
post #9 of 15 Old 04-16-2014, 07:15 PM
Hopinater's Avatar
Quoted: 1783 Post(s)
Liked: 4394
I've tested my XV15 to see if it could act as an end table and it didn't cause anything to shake around too much. I agree with bear and the others and I would do everything in my power to run dual Outlaws if it's at all possible.
That said, if you can't make the outlaws work I would think sealed subs would work well in a 2000 cu ft room. Of course that will depend on the sealed subs you end up using.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #10 of 15 Old 04-16-2014, 07:24 PM
bear123's Avatar
Liked: 2513
Ok, here is the plan:
Tell your wife you are thinking of switching subs:
Then say, "Or, I was thinking of using the subs we have as endtables.  What do you think babe?"
Hopinater likes this.
bear123 is offline
post #11 of 15 Old 04-16-2014, 07:43 PM
Hopinater's Avatar
Liked: 4394
^ LOL, that's a great idea. I'm keeping that picture and using it myself in the future.
post #12 of 15 Old 04-16-2014, 10:21 PM - Thread Starter
Quoted: 353 Post(s)
Liked: 89
^^^^ HAHAHAH, I think that will work! What are those monsters?
post #13 of 15 Old 04-17-2014, 07:48 PM
bear123's Avatar
Liked: 2513
Those are called orbit shifters.....and the name is appropriate.
bear123 is offline
post #14 of 15 Old 04-17-2014, 11:23 PM - Thread Starter
Quoted: 353 Post(s)
Liked: 89
No kidding, those things are HUGE!
post #15 of 15 Old 04-18-2014, 02:04 PM
Hopinater's Avatar
Liked: 4394
You might need to build the room around those things. I bet the WAF is mighty low on the Orbit Shifters.
