single BIC F12 vs. dual Dayton 1200's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-23-2014, 12:55 PM - Thread Starter
Cayenn's Avatar
Quoted: 27 Post(s)
Hey AVS,
I just finished connecting my first stereo system to my computer. It consists of a Yamaha RX-V375 receiver and a pair of Pioneer SB41 bookshelf speakers. I'm really happy with how clear and crisp the dialogue comes through, it's aeons better than the "high-end" PC speakers I had, but I definitely need a sub, or sub(s) to complete it.
My budget is about $200. I've narrowed it down to either a single BIC F12 or dual Daytons. Or perhaps just a single Dayton would be enough? I could use the money I save and buy some nice speaker stands, but I don't want to sacrifice SQ. I could always get the stands later.
I know a 2.2 setup is a bit odd. But ultimately, which setup do you think would give the best sound experience?
The setup is in a relatively standard living room.
Any input would be greatly appreciated.
TY,
Cayenn
Cayenn is offline
post #2 of 11 Old 04-23-2014, 08:03 PM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
Running dual subs is not odd at all. Many of us do. Dual subs offer the potential benefit of a smoother frequency response through a wider seating area. But if you are primarily listening sitting at a computer with the sub nearfield (~ 3ft or less) and/or have very limited placement choices, then the benefit of duals may be negated.
As for the SQ of the Dayton vs. the BIC F12? I don't know. Given the cost of dual Daytons plus shipping, I'd rconsider saving up just a little more for the Mordaunt Short Aviano 7 or a BIC PL-200 (which can often be had for about $275 if you make them an offer).
Cayenn likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 11 Old 04-23-2014, 11:19 PM
PS3forlife's Avatar
Quoted: 32 Post(s)
Liked: 44
I would also look into the nxg bas500 it can be had for 260 it fills my large basement pretty damn well. Just throwing in another option. It was described in a review by Jim Wilson as being very musical also.
PS3forlife is offline
post #4 of 11 Old 04-24-2014, 07:50 AM - Thread Starter
Cayenn's Avatar
Quoted: 27 Post(s)
Thanks for the replies. It's for an HT setup in a standard sized living room. About 40'x17'x10'. No tall ceilings. That's why I was considering the dual sub setup. Thanks for providing me with additional options. I'm looking into the PL-200 now  --- I've got a bit of reading to do :)
I would definitely stretch my budget to $260-280 if it's really worth it.
Cayenn is offline
post #5 of 11 Old 04-24-2014, 08:13 AM
cel4145's Avatar
Liked: 2984
That room is huge. I would not buy a sub right now until you can buy something much more powerful. Sub response performance is dependent on the size of your room.
cel4145 is offline
post #6 of 11 Old 04-24-2014, 08:19 AM - Thread Starter
Cayenn's Avatar
Quoted: 27 Post(s)
Yeah, its a bit elongated, not very wide though. And there are two pass throughs, one of which connects to the kitchen/dining room area, I really think I can channel the sub if I position it effectively though, since the living area is an elongated rectangle. And I dont listen to anything very loudly. I'm only running two Pioneer SB41's and the sound come through very nicely. I'm very satisfied with the loudness/clarity. The bass would just be there to provide some aux relief for the speakers. I dont intend to blast it all the way or anything. I'm not a "basshead" at all (if it matters any.)
Cayenn is offline
post #7 of 11 Old 04-24-2014, 08:24 AM
cel4145's Avatar
Liked: 2984
I'd probably go for the BIC PL-200. It has a lot of output from 40 to 80hz, so it would probably work better for making sure you have plenty of midbass.
Cayenn likes this.
cel4145 is offline
post #8 of 11 Old 04-24-2014, 08:29 AM - Thread Starter
Cayenn's Avatar
Quoted: 27 Post(s)
Thanks for the help, brotha. So far, I've read great things about the PL-200. It seems to be worth the extra $80. I still got a bit of reading to do though, before I pull the trigger on either one.
I've rated your posts +1
Thanks once again
Cayenn is offline
post #9 of 11 Old 04-24-2014, 08:31 AM
cel4145's Avatar
Liked: 2984
I'm glad that helped.
You know, the other best reason to go with the PL-200 is if you ever decide you need some more bass and would like to improve the bass in your room, you could always add a second. I don't think you would want to go four Dayton SUB1200s in the room smile.gif
cel4145 is offline
post #10 of 11 Old 04-24-2014, 10:44 AM
lizrussspike's Avatar
Quoted: 505 Post(s)
Liked: 636
How do you like the NXG? I read the reivew and I am intereted. I have two polk 505s and am wondering if this would be a worthy upgrade, and saving the 505s for my son
lizrussspike is offline
post #11 of 11 Old 04-24-2014, 12:26 PM
PS3forlife's Avatar
Quoted: 32 Post(s)
Liked: 44
The nxg is amazing for the price. It will dig deep and take a large amount of abuse. I love mine. The only upgrade I would consider is adding another as my basement is huge. But even with one it rocks my house.
