SVS SB-2000 or Sunfire HRS-10 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 71 Old 05-31-2014, 03:21 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
Hello.
I'm looking for musical, yet low-hitting subwoofer, which will thump you in the chest and sound crisp at the same time. My room is 1000 cubic feet large, and it has sloped ceiling on both sides. I decided to go for sealed design, as I heard it's more accurate and can benefit from room gain due to shallow response-rolloff.
I can't decide between the two models mentioned in the title. SB-2000 is 12" powered with 500W RMS in 47 l sealed box, and HRS-10 is 10" powered with 1000W RMS in 32 l sealed box. Which will provide better tactile response (chest punch / shaking legs) in my room, and deliver overall better sound?
Both subs have same price, as the Sunfire in case is for sale. I'm also interested in hearing more sub recommendations for my needs. So, the usage is 80/20 for music/movies, and the chest thump / tactile response is priority number one. However, the sound must be more accurate than my cerwin vegas biggrin.gif
boomybass is offline
post #2 of 71 Old 05-31-2014, 03:32 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Go for SB Ultra 13. It has features you will want to use a 2 channel system (variable high pass)
As for HGS, no +/- so could be anything..
fatbottom is offline
post #3 of 71 Old 05-31-2014, 04:58 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
Too expensive, plus I think it would overdrive my small room. And I have Audyssey EQ2 on mah receiver
post #4 of 71 Old 05-31-2014, 05:41 AM
Quoted: 68 Post(s)
Liked: 111
With that budget and room, the SB-2000 is a great choice. For a little more, the Rythmik F12 is worth a look also.
rnatalli is offline
post #5 of 71 Old 05-31-2014, 06:32 AM
fatbottom's Avatar
Liked: 518
My room is half the size of yours, and I have the SB Ultra 13. Not overkill.
In fact got SVS 12" and for that size room, for movies, it's dissappointing. For music it's great.
post #6 of 71 Old 05-31-2014, 06:35 AM
bear123's Avatar
Quoted: 1628 Post(s)
Liked: 2367
Chest thump is the product of one thing....high enough SPL.  In that case, I would recommend looking towards subs with the highest output with low distortion...i.e. high CEA2010 output.  SB13 Ultra would have been a good choice, but is out of the budget.
One of the highest output sealed subs under $1k is likely the PSA XS15se, recently upgraded with a much better driver which plays cleaner.
I would also take a look at  Rythmik's F15HP, which should be similar in output to the PSA.
Both of these options will likely have very high output to provide the chest thump you are looking for, and play low and clean.
bear123 is offline
post #7 of 71 Old 05-31-2014, 07:14 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
Does anyone have SB-13 ultra for sale?
post #8 of 71 Old 05-31-2014, 09:23 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
Does anyone have experience with tactile transducer? I think I'll go for SB-2000, and buy ButtKicker in the case SB-2000 alone doesn't produce enough pressure.
That would be cheaper than ultra, and may yield even better results I hope.
Does tactile transducer feels like a real subwoofer (vibrating inside whole body), or does it just tickle
your buttocks?
post #9 of 71 Old 05-31-2014, 09:28 PM
bear123's Avatar
Liked: 2367
They are better for the very low frequencies that cause rumbling vibrations.  If you want chest thump, again, you just need a lot of output.  SVS makes good subs, but there are other alternatives that will give much higher clean output for the money.  I have witnessed this first hand in my room.  If you ante up to the Ultra series you should get plenty of output.  Just speaking of their cheaper offerings.
bear123 is offline
post #10 of 71 Old 06-01-2014, 03:50 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
So, if I understood right, chest thump is directly proportional to the output, aka volume. Is it even possible to achieve the thump in 1000 ft^3 room at volume level, which doesn't damage your eardrums or neighbor-relations? I know that is possible in car, where the bass could be easily felt at pleasant volume. I also wonder, why my 12" cerwins doesn't deliver the thump even at levels, where my ears hurts. I fear same thing would happen with ultra, if the only factor to the thump is max volume. Or is it possible to adjust the subwoofer level, so it plays loud and thumps, and main speakers playing pleasant volume, without sounding unnatural? BTW, can you recommend some better products than SVS?
post #11 of 71 Old 06-01-2014, 04:10 AM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
I find I get that very tactile feel (even at just moderate volume) whenever I get the frequency response at the listening position nice and smooth free from large peaks and dips. Even just a track with guitar strings being struck, I can feel the energy passing through my body. I don't think it's about having lots of bass output, but rather having the whole frequency response at the same level in balance.
kiwi2 is offline
post #12 of 71 Old 06-01-2014, 04:56 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
I thought so. There has to be other factor than just a volume. So, to have best prerequisites for thump, you don't necessarily need high power, but flat frequency response (with shallow roll-off I guess) and proper placement. In that aspect, SB-2000 seems to nail it, as it has ultimately flat frequency curve and can still output 1000 W peak.
post #13 of 71 Old 06-01-2014, 06:24 AM
bear123's Avatar
Liked: 2367
+1 to what Kiwi2 said about getting a smooth response.  This will likely require two subs, measurement ability, and eq.  Otherwise you are very likely to have a null or dip right in the range needed for that chest thump, which then requires you to double or triple the volume to get even close.  As far as SVS, first let me say that they are good quality subs, but their weakness, until you get into the Ultra lineup, is that their output is sometimes a bit less than some competetitors.  Not retail brands, but other ID companies.  Take a gander at this output chart to compare:
Comparison_Mini_Chart_XS15se_v2.png?2134
The other thing that can help a lot with getting that kick in the chest feeling is near field placement.  As in right beside or right behind your seating position.  This can make a drastic difference.
spidey.joe80 and Dr. H like this.
bear123 is offline
post #14 of 71 Old 06-01-2014, 11:14 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
How Rythmik F12 / F15 servo subwoofers compares to SB-2000?
Also, could SVS PC12-Plus be a wise choice? It's 12" 800 W cylinder, could be used ported or sealed mode and looks nice:D
Does using ported sub in sealed mode (plugging holes) yield same results as sealed box?
post #15 of 71 Old 06-02-2014, 04:17 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
I have decided to buy SVS, as they are only quality manufacturer that delivers to Finland. My last question: should I go for:
PC12-Plus: 1400 €
Dual SB12: 950 €
PB-2000: 800 €
SB-2000: 700 €
Objective: CHEST THUMPING bass, tighter the better. 80/20 for music/movies. Spine crushing rumble is a big plus, but not necessary
Facts: Room volume is 1000 ft^3, dimensions are 5 x 3.4 x 2.2 m, the ceiling is sloped almost from the floor to almost to the middle of my room on both sides. Main speakers are 12" cerwin vegas, which doesn't produce the chest thumping bass (due to room shape?). My room is at upstairs, could the resonance of floor affect the performance?
post #16 of 71 Old 06-02-2014, 04:26 AM
fatbottom's Avatar
Liked: 518
I've had these SVS subs
PC Plus 20-39
PC Ultra 13
SB 12+
SB Ultra 13
The SB work better for music, if you have a larger room and need extra headroom a ported model offers, go for them. But for a smaller room and a more musical sub, SB is my preference. That room isn't huge, so I think SB Ultra 13 would be good option.
I'd choose one SBU13 over two SB12+.
post #17 of 71 Old 06-02-2014, 04:35 AM
fatbottom's Avatar
Liked: 518
Also I think your "chest thumping" bass is probably not what a quality sub offers, you know that boy racer thump thump thump noise..
post #18 of 71 Old 06-02-2014, 10:57 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
No. You have bad subwoofer or placement, if it doesn't thump you
post #19 of 71 Old 06-02-2014, 12:39 PM
fatbottom's Avatar
Liked: 518
hahaha.
yeah SBU13 is a bad sub all right.
post #20 of 71 Old 06-02-2014, 01:26 PM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
hahaha.
You probably have misconfigured the sub
post #21 of 71 Old 06-02-2014, 01:54 PM
fatbottom's Avatar
Liked: 518
nope.
that thump thump thump boy racer effect- I don't get that.
post #22 of 71 Old 06-02-2014, 06:27 PM
smurraybhm's Avatar
Quoted: 1354 Post(s)
Liked: 1596
So Bear you are active on the sub thread and definitely seem to like PSA which makes sense as they make very good subs at great prices - wonder where they learned that smile.gif
The chart you thru up to me seems to be selective in nature, if you look at the measurements from http://www.data-bass.com/data?page=systems the numbers don't support the extra subs they say needed to match output of one PSA. As someone who just ordered his second sub - a SVS PC12 Plus - please share your wisdom on the numbers posted by PSA. A lot of speaker manufacturers can post numbers that may make their speaker seem superior - curious about the difference and I just can't buy that the Ultra isn't a better sub. Thanks. Steve
Panasonic 60VT60 (cal by DNice)
Denon 5200 w/ Outlaw 2200 Amps (3)
Ascend Acoustics Sierra 2s F/R & Horizon w/ RAAL Center; Sierra 1s Surrounds; DefTech PM1000s Fronts & Top Middle w/ PSB S5 Rear Surrounds; PSA v1800 & SVS PC12+ Subs
Oppo 103; Onkyo HD-DVD; Apple TV & Roku/Fire Sticks
smurraybhm is online now
post #23 of 71 Old 06-02-2014, 06:42 PM
bear123's Avatar
Liked: 2367
Well, CEA 2010 output data certainly does not tell the whole story when it comes to sub performance, but imo it does cover a lot of it.  You get a pretty good idea of output throughout the entire operating range and how loud it gets within allowable distortion limits.  Data-bass is a very informative sight and useful for getting performance data, but certainly is not the only source of information on subs.  Some manufacturers post their own measurements from in house testing, such as Hsu.  I like some of PSA's subs but I try not to blindly recommend them all the time, but if I feel it is the strongest choice or worth considering I will mention it.  As far as the chart goes, they do not list each individual frequency, but they do list the average just as CEA2010 dictates.  You will notice on Hsu's website that they also list their averages, although they do so along with the individual data points.  Hsu and PSA are the only two companies I know of that list CEA2010 output numbers on their site for all their subs.
You can probably check Hsu's website for output on the ULS-15 to check for accuracy of the data.  The SB2000 has output numbers listed in the Audioholics review, and off the top of my head I am not sure where the SB13 has been tested.
You can do the same thing for their XV30 comparison chart....the FV15 and VTF15 are both listed on data-bass.
If someone is looking for a lot of output from a sub on a budget, I think this is useful information in helping to determine which sub to buy.
Hopefully we will see data-bass testing on all of PSA's updated products.  If the testing correlates well, this should be good for the consumer as it provides competition that should cause others to improve the performance of their own products.  :)  After all, if PSA can outperform competitors with made in the USA subs for less money, imagine what can be done with the made in china subs with a bit of competition stirring things up a bit.
bear123 is offline
post #24 of 71 Old 06-04-2014, 05:51 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
I have opportunity to get second hand SB13 Plus for 1000 €. Should I get it or buy new SB-2000 for 700 €?
post #25 of 71 Old 06-04-2014, 05:55 AM
fatbottom's Avatar
Liked: 518
I'd go for the SBU13. Is it the new or old model, BASH or Sledge?
post #26 of 71 Old 06-04-2014, 06:07 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
sledge
post #27 of 71 Old 06-05-2014, 03:55 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
Guy at SVS told me to get PB-2000 for HT/music setup with my cerwin-vega xls-12 in 1000 cu feet room.
post #28 of 71 Old 06-09-2014, 02:06 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
Hi man. Would SVS PB-2000 + Anti-mode deliver me some serious chest-hitting tight bass in 1000 cu feet sloped ceiling room?
post #29 of 71 Old 06-09-2014, 06:41 AM
pmanyon's Avatar
Quoted: 48 Post(s)
Liked: 32
I went from the sb2000 to the pb2000 for exactly what you are looking for. I was underwhelmed with the sb2000, especially for movies. It had tight, clean bass, but it lacked the heaviness and explosiveness of even the pb1000, which I originally owned. Switching to the pb2000 was like a whole new world. It will kick you in the chest in a small room like that (my room is about the same size). The sound also sounds bigger and heavier. If you have the space, go for the pb2000. I also didn't notice a difference for music between the sb and pb. However, I didn't do critical listening in that regard. Despite that, I think the pb sounds great for music. Soft and subtle when needed but hard hitting as well.
pmanyon is offline
post #30 of 71 Old 06-12-2014, 02:07 AM - Thread Starter
boomybass's Avatar
Quoted: 36 Post(s)
So, I have become to conclusion, that I will either get PB-2000 AND Anti-Mode sub-EQ, or dual PB-1000. Both options are about the same price and delivers same extension and pressure. However, apparently dual PB-1000 have better mid-bass slam and smoother FR.
The thing is, that I have tricky listening room: 1000 cubic feet, sloped ceiling (see picture). I have cerwin-vega XLS-12 full range speakers, and I'm a bit disappointed with their performance, as the bass is boomy and lacks tactile response, until played at volume which will make your ears bleed. And even then it sounds boomy. I believe this is due the nulls and peaks caused by sloped ceiling.
I heard that dual subwoofers can deal with problem as such, but how is it possible, when two full-range speakers can't? Does subwoofers interact with the room some way differently than 3-way speaker's long stroke woofer?
So, which would be a better choice to achieve clean, visceral, chest thumping bass in my room; dual subs or more powerful sub + EQ?
