splitting the LFE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 06-01-2014, 12:58 PM - Thread Starter
Plasmacolon's Avatar
     Currently I’m running 2 subs in my HT.  I’d like to run 4.  Right now I have the single line level (LFE) output on the amp split and running the divided signal to the two subs.   My question is right now I notice what I think is a reduction in bass output when I split it once.  Is it actually a reduction in bass output from splitting the output on the amp or is it just wave cancellation in the room?  Is there any way I can test the signal level on the sub out from the amp?
Denon 3811ci
Mirage M3's (Mains)
Mirage MC-2
Mirage BPS-1's (surrounds x4)
Mirage BPS 400 x4 (subs)
60" Panasonic VT
Plasmacolon is offline
post #2 of 24 Old 06-01-2014, 01:39 PM
dpc716's Avatar
Quoted: 13 Post(s)
Liked: 24
I've split the lfe signal as many as 5 times in the past with no issues. If you are noticing a reduction in output when adding a second sub it is most likely phase related as you noted. Try changing the phase settings and see if it helps.
dpc716 is offline
post #3 of 24 Old 06-02-2014, 04:31 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
this is the real cause of global warming. Soon the sun will go supernova unless you stop it. smile.gif
the sub "hears" the voltage, which is not divided in a parallel connection. Assuming the subs have reasonably high input impedances, there is so little current demand that splitting cannot cause a real problem with, probably, any reasonable number of subs a person could actually fit into a room. At 2 volts (high for a receiver's sub output) into 20,000 ohms (low to middling for an input stage - I don't think a megohm - 1,000,000 ohms, is unheard of) the receiver is being focred, FORCED, I say, to put out 0.0002 watts. Yes! Fully two thousandths of a watt. And one thousandth of an amp. Put two of those subs in parallel and the power demand skyrockets to .0004 watts. Fully .0002 amps. Just not a problem
JHAz is offline
post #4 of 24 Old 06-02-2014, 08:03 PM
Bill Fitzmaurice's Avatar
Liked: 4641
+1. If you parallel enough sub amp inputs the summed low impedance will load down the AVR sub output driver, but that would probably take at least 6 subs.
Bill Fitzmaurice is online now
post #5 of 24 Old 06-05-2014, 11:00 AM
Shreds's Avatar
Quoted: 276 Post(s)
Liked: 213
I have noticed a drop in preamp output when Y-jacking on two different systems. I think when you do that the inputs have weird interactions with each other too. The best way is to have active buffers between each sub that isolate the inputs, kind of like a headphone amplifier with multiple outputs. If you have one of those lying around you can use it instead of splitters to see if the problem is still there or not. The cheaper headphone amps tend to be a bit noisey but it shouldn't matter that much on the low end.
Shreds is offline
post #6 of 24 Old 06-05-2014, 11:21 AM
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1120
I have used one output for 8 subs with success.
Marantz 7702 Atmos
MKtheater is online now
post #7 of 24 Old 06-05-2014, 01:39 PM
A9X-308's Avatar
Quoted: 1285 Post(s)
Liked: 954
Sorry, that is simply incorrect. See JHAZ's post above.
A9X-308 is offline
post #8 of 24 Old 06-05-2014, 01:49 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
The difference Aiui is that phones are passive and powered subs are not. I have over time taken plenty of heat around here from folks who do not grok this distinction in the opposite direction. Different cables can result in measurable and audible differences when they are connecting say a high output impedance guitar pickup to a guitar amp. Shifts the resonant frequency of the system. It's why Hendrix liked coiled guitar cables with his post-CBS neutered strat pickups. Rolled off some highs. Irrelevant unless something is terribly wrong in the context of a relatively low output impedance preamp out into a high input impedance sub amp.
JHAz is offline
post #9 of 24 Old 06-05-2014, 11:47 PM
Shreds's Avatar
Quoted: 276 Post(s)
Liked: 213
Look, I ain't making it up. 2 times Y-jacking outs got screwy with me. The rest of the time I used Y jacks it was fine. I didn't get schematics on the inputs and test cables and do the math so I don't really know what the reason was.
Wouldn't the signal load change from all of the different input impedances combining in parallel? So if the number drops and there is a dc blocking cap on the amp's input for example, it would create an RC filter with a faster rolloff down low, right? I'm not saying that's what happens every time but it is one possibility where there would be degradation. I just don't see hooking 19 subs up to one jack being an audiofile kind of thing to do.
Shreds is offline
post #10 of 24 Old 06-06-2014, 12:26 AM
A9X-308's Avatar
Liked: 954
OK. So you split the signal and got some sort of effect, but you don't know what it was or what caused it. So it could have been an error on your part, not the general principle and that's what's being argued, so to say that you need to add a multiple line driver in all or even most cases is wrong. I've done it before many times with no effect, and I know because I've measured it.
The input impedances of the amps in parallel will combine in the same manner as drivers in parallel, only the impedances will be about 1000x higher.
It would not be a cap in the amp's input but the source's output. However most LF points in most gear is low enough not to be audible even if it was brought up an octave or more and then would only be noticeable as a slight reduction in LFE on some movies, and almost never on music.
I just don't see hooking 19 subs up to one jack being an audiofile kind of thing to do.[/quote]Hyperbole doesn't help. No one suggested that. But splitting a signal to two (or even four) sub or power amps, will not cause a drop in level, nor provide any real issue in almost all cases.
As for audiophiles, they do lots of stupid stuff and generally don't understand any electrical theory, so it not 'seeming audiophile' is a positive.
A9X-308 is offline
post #11 of 24 Old 06-06-2014, 12:34 AM
Shreds's Avatar
Quoted: 276 Post(s)
Liked: 213
I care about single digits when it comes to a sub so it would effect me. I'm telling my experience, sorry you don't agree with it.
Shreds is offline
post #12 of 24 Old 06-06-2014, 12:51 AM
A9X-308's Avatar
Liked: 954
It would for me to.
I'm not disagreeing with your experience, but your suggestion of a line driver. In most cases, it will simply NOT be necessary. That's what I'm trying to get through. I have been designing and building linear electronics for a long time, so I come with a strong theoretical background and lots of experience. Your problem might have been user error or a really oddball set of devices, far from the norm (electrically). However, without any measurements it simply may have been that the placement and/or setting caused the fault that you heard and not simply splitting the signal.
A9X-308 is offline
post #13 of 24 Old 06-06-2014, 02:26 AM
Shreds's Avatar
Quoted: 276 Post(s)
Liked: 213
It is also possible that the signal will be distorted without buffers depending on the equipment. I don't need your resume to realize it either.
Shreds is offline
post #14 of 24 Old 06-06-2014, 02:37 AM
A9X-308's Avatar
Liked: 954
You made the claim. Prove it for non pathologically bad sets of gear.
A9X-308 is offline
post #15 of 24 Old 06-06-2014, 02:37 AM
McStyvie's Avatar
Liked: 78
I run four subs on two outs through a mini DSP. No issues whatsoever. Only time I notice a drop in level is if I add filters to the Mini DSP (i.e. reducing peaks on the graph), but that is something entirely different.
McStyvie is offline
post #16 of 24 Old 06-06-2014, 02:45 AM
Shreds's Avatar
Quoted: 276 Post(s)
Liked: 213
Yeah, I made the claim. Don't have to prove it. Just adding my two bits. Everybody reading it can do what they please. You are getting in my face about it and it's starting to get irritating Mr. Coolaid.
Shreds is offline
post #17 of 24 Old 06-06-2014, 03:22 AM
A9X-308's Avatar
Liked: 954
Tradition is whoever makes the claim has to provide the evidence. In other words, you have nothing.
A9X-308 is offline
post #18 of 24 Old 06-06-2014, 07:30 AM
Shreds's Avatar
Quoted: 276 Post(s)
Liked: 213
And apparently you have a menstrual cycle. Where's all of this data on your end from your extensive tests then cause you haven't done anything other than treat me like I kicked your dog down the steps.
Shreds is offline
post #19 of 24 Old 06-06-2014, 08:24 AM
A9X-308's Avatar
Liked: 954
Cheap attempt at an insult.
What I am telling you is the application of basic electronics. I feel no need to keep reams of data to prove time and time again that 2+2=4.
Your emotional response to the situation is your problem and it seems that you can't bear to be questioned. I'm more than happy to be proven wrong and learn something, but have yet to see anything from you that I can learn from on this subject.
A9X-308 is offline
post #20 of 24 Old 06-06-2014, 08:31 AM
MKtheater's Avatar
Liked: 1120
I used 5 y splitters for 8 subs on 4 amps(2 channel each) and no problems whatsoever.
Marantz 7702 Atmos
post #21 of 24 Old 06-06-2014, 09:09 AM
Shreds's Avatar
Quoted: 276 Post(s)
Liked: 213
So you guys are basically telling me that there is no way to load down a preamp's output, increasing distortion. I disagree. I am not conducting an educational class on it. Are you done talking yet or do you want me to keep repeating the same thing?
Shreds is offline
post #22 of 24 Old 06-06-2014, 09:38 AM
A9X-308's Avatar
Liked: 954
I have about a hundred channels or SS power amp here. None has a Zin of less than 10k. So I could put 5 of those 10k Zin units in parallel and drive them with a typical cheap opamp the 4580 a very common and typical unit at the lower end of the market and get the following result.
Image is from the TI datasheet. Note the 1-2V region which is what most power amps need to drive them to full output. None of the distortion there is audible. This easily fulfils the OP's requirement of 4 units in parallel and I'd put money on being able to do 10 in parallel with not much worse, and certainly not audible performance.
Good. You don't have the knowledge or the skills required.
Feel free, but repeating the same incorrect thing will not make it any more true.
A9X-308 is offline
post #23 of 24 Old 06-06-2014, 09:38 AM
MKtheater's Avatar
Liked: 1120
I did not say that, I am saying I ran 8 subs on one lfe output with no problems and I measured my output and THD to be very low.
Marantz 7702 Atmos
post #24 of 24 Old 06-06-2014, 10:36 AM
Shreds's Avatar
Quoted: 276 Post(s)
Liked: 213
Loading an op amp increases distortion and can cause the device to overheat. Sounds like my point. If you have different amps all with different input Z, the resistance can drop a lot faster than if they are all the same amp. What if you run a short cable to one but a long cable to another with a lot of capacitance? What if the output of the preamp is of a poor design? Every situation is different. I pointed out that most of the time there was no problem at all in splitting a signal that way but sometimes there is. That is my point. Sometimes there is. Yeah, it isn't most of the time, I GET IT. Problems are possible though. Actively distributing a signal rules them out.
Shreds is offline
