What sub or subs would I need a 4000 cubic ft Room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-03-2014, 06:44 PM - Thread Starter
grimed's Avatar
As you can see on the post I have a 4000 cubic ft room.  This also has a large opening in the back off the room.
I will be using 3 JTR 228's or two Sierra 2 towers and a Horizon center channel. May even go for  2 diy speakers the 12 in tempest for the fronts and the Alchemy for the center.
This dosn't have to be a vendor type of Sub but I have few tools to work with for DIY.
grimed is offline
post #2 of 8 Old 06-04-2014, 09:00 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5201
Passive Captivstor 2400's or DIY Mini Marty's with UXL-18 or Dayton UM-18 drivers. For power Peavy IPR 7500 w/ a mini dsp or Inuke 6000dsp
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #3 of 8 Old 06-04-2014, 09:03 AM
JT78681's Avatar
Quoted: 1375 Post(s)
Liked: 898
What's your budget?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #4 of 8 Old 06-04-2014, 03:42 PM
Alan P's Avatar
Quoted: 4694 Post(s)
Liked: 3321
Are you including the room(s) beyond the large opening in your "4000 cu. ft." calculation?
Alan P is offline
post #5 of 8 Old 06-04-2014, 06:07 PM - Thread Starter
grimed's Avatar
No that area is speperat.
Budget wise i think i can swing the FV15hp I called and they said that should be enogh with out working the sub to hard.
I am retuning my speakers until i pay off the sub. I havnt bouht it yet but I would need to spend more for the Mary sub  after buying the amp  driver and all probly.
I wanted to do DIY for a sub but if i get the table saw, router and so on I would be spening a good bit more I belive.
grimed is offline
post #6 of 8 Old 06-04-2014, 06:12 PM - Thread Starter
grimed's Avatar
Quick question if I used a Mini DPS would a Ipad or a Mac pro work. I dont have a lap top so if a Ipad would work, that would cut back some of the cost, if a Mini DSP would help much with just I Sub
grimed is offline
post #7 of 8 Old 06-05-2014, 08:50 AM
Alan P's Avatar
Liked: 3321
It is not "separate" to your sub....you need to include it into your cubic foot calculations. If you are telling Rythmik that your room is only 4000 cubic feet and they are making recommendations based off that number, those recommendations are not going to be accurate.
Not sure if the MiniDSP plugins will run on a Mac. You should contact support.
You will need some way to measure your room (REW + mic) before you will be able to use the MiniDSP.
Alan P is offline
post #8 of 8 Old 06-05-2014, 08:53 AM
JT78681's Avatar
Liked: 898
Can you take a picture of the back of the room? I want to see what this opening looks like.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
