How to configure my westra sub maestro 10" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-13-2014, 08:19 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
So I'm wondering, where would be the best place to put it and I have 3 options (see pictures)
How far minimum from the wall is recommended to put my sub and my other question is regarding the HI-CUT dial (40 - 150hz ), where to set it and what crossover in the receiver should I set it at, so far its between 60 to 80 but my knowledge on the subject is far from prefect(at the least the recommended position) and what volume should I put it at.
Some info on my setup. My 3 fronts are wharfedale zaldek s2000's with the center. On the back it says nominal impedance 6ohms with a power handling of 250wts and the center is the same ohms but with 150 wts.
I know sounds has to do alot with the room so ill give screens of that too.
Any help would be appreciated.
Pics:
Subwoofer
http://i58.tinypic.com/1zxtnbs.jpg
Options :http://i59.tinypic.com/jtnhx2.jpghttp://i58.tinypic
http://i59.tinypic.com/2884j9g.jpg
http://i57.tinypic.com/b3omjb.jpg
P.s - this is where my front facing side speakers go, let me know if its good please.
http://i61.tinypic.com/111thmp.jpg
http://i59.tinypic.com/10h3dq8.jpg
soler37 is offline
post #2 of 11 Old 06-13-2014, 01:46 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
If you have three options for placement pick the one that gives you best bass at your listening position (s). Turn the hi-cut/crossover setting on the sub to max and let your receiver manage the crossover. I'd start with 80 for crossover. Does your receiver have an auto setup/room correction routine to run?
lovinthehd is offline
post #3 of 11 Old 06-13-2014, 02:02 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
I have a mic but when I do the setup the end resault is wrong.
Gives me 160 crossover on reciever and leaves my left and right fronts on large
soler37 is offline
post #4 of 11 Old 06-13-2014, 02:28 PM
lovinthehd's Avatar
Liked: 4775
What receiver do you have? The avr manufacturer doesn't want to "insult" you that your speakers are "small" so they generally do that despite the lack of bass management that ensues. Turn the speakers to small in any case when using a sub.
What are the +/- 3dB specs for your speakers? Unless they're small sat speakers that 160 setting doesn't make much sense...
post #5 of 11 Old 06-13-2014, 02:39 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
The only small sat are my back 2 which are pure acoustics.
The front 3 are definitely large speakers.
soler37 is offline
post #6 of 11 Old 06-13-2014, 02:42 PM
lovinthehd's Avatar
Liked: 4775
Doesn't matter if your speakers appear to be large, if you want bass management set them to "small". What make/model of receiver? What are the specs on your main speakers?
post #7 of 11 Old 06-13-2014, 02:48 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
My receiver is yamaha rx v371 and my main 2 speakers say 6 ohms. Besides that no other info on them
soler37 is offline
post #8 of 11 Old 06-13-2014, 03:10 PM
lovinthehd's Avatar
Liked: 4775
The impedance (6 ohms) doesn't mean much as far as frequency response goes but I couldn't find any spec for your speakers with a brief search. Didn't see that model has Yamaha's YPAO, but it does utilize a mic and test tones to establish levels and distance/delay? I'd still start at 80 hz crossover in the avr but possible if your speakers do not have much capability at lower frequencies that you may need a higher crossover point.
ps Your avr may have selected the lowest common denominator for crossover in your surrounds....
post #9 of 11 Old 06-14-2014, 01:17 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
Well do I need to set all of my speakers to small, including my center?
Edit: found the specs for the r/l/c
fronts:
sensitivity - 91db
Frequency response - 30 - 23khz
Bass unit - 2×200mm
Midrange +treble - horn loaded
Center:
90db
70-39khz
2×170mm
Horn loaded
Hope this helps
soler37 is offline
post #10 of 11 Old 06-14-2014, 02:46 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
Up
soler37 is offline
post #11 of 11 Old 06-15-2014, 07:30 PM
lovinthehd's Avatar
Liked: 4775
fronts:
sensitivity - 91db
Bass unit - 2×200mm
Center:
90db
70-39khz
2×170mm
Horn loaded
Hope this helps
Yes, all speakers to small, this enables the receiver to manage the bass for your subwoofer (which is generally the best option as most speakers do not handle lower bass frequencies as well as a dedicated subwoofer). The spec for frequency response without a definition (like +/- 3 dB) doesn't mean much and I seriously doubt your speakers are capable of 30 Hz at +/- 3 dB spec. In any case I'd still crossover at 80 and see how it sounds. May not be best for your surrounds but unless you have adjustment for each speaker's crossover separately I wouldn't worry about it (and I'd use 160 as suggested by the receiver for your sats, altho somewhat dependant on what they are).
