Is there a forumla for changing from vents to ports? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-17-2014, 03:25 AM - Thread Starter
functionalfool's Avatar
I have an extremely nice enclosure that I'd like to use but my new sub requires 0.38 ft^3 for it's vent which basically makes this this box useless because it's too small when you add .38ft^3! I'm from the old school and have never used a vented box, only sealed and ported. Is there a way to find a proper port size instead of a vent or do these new subs require vents and porting is a thing of the past?
Thanks guys!
Edit---I can convert the volume of a cube to the volume of a cylinder, that is not the issure...I am just wondering if the cyinder port differs in some way from a vent, ie less?
functionalfool is offline
post #2 of 7 Old 06-17-2014, 07:08 AM
Bill Fitzmaurice's Avatar
Liked: 4660
Vented and ported are the same thing.
For calculating speaker enclosure dimensions use WinISD.
http://www.linearteam.dk/default.aspx?pageid=winisdpro
Bill Fitzmaurice is online now
post #3 of 7 Old 06-17-2014, 08:41 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
This brings up a speaker design question. Are these calculations aimed at creating the smallest possible box or at creating the exact size for best performance?
FMW is offline
post #4 of 7 Old 06-17-2014, 09:47 AM
Liked: 4660
The program will default to the flattest possible response and lowest possible extension for the given driver specs. In the event that the default cabinet size is too large you can alter the box size and, in the case of a vented enclosure, tuning. But where going smaller than optimal is concerned Hoffman's Iron Law always constrains the result.
post #5 of 7 Old 06-19-2014, 03:38 AM - Thread Starter
How is this possible? It would take a 4inch diameter cylindrical port of 53 inches long to equal that large of a volume! Volume of a cylinder is V=h*pi*r^2 ---> (55*3.14*2^2)= 665.7 inches, converting to ft you dived by 1728 which equals 0.385ft^3 (ideal vent size per manufacturer). This vent is virtually the size of a compact sealed enclosure! Am I way off here or missing something in my calculations?
I, personally, am not worried about size because this will be used in home audio so can be 6ft^3 if the specs called for that! I am just new to this vent thing, been 15 years since I bought a current model subwoofer before last weekend. I can absolutely make a vented enclosure with the long slit (vent) in the box but was hoping to use my old box is all.
Also, I am powering this with a dedicated amp that can handle 4 ohms and put out proper wattage so all that is left is the box.
post #6 of 7 Old 06-19-2014, 06:07 AM
Liked: 4660
The volume of a port/vent alone does not determine the Fb of the cab. Wherever you got that information from is incorrect. You also keep referring to vents and ports as if they were different terms. They are interchangeable. Suggested reading:
http://techtalk.parts-express.com/sh...Building-Bible
post #7 of 7 Old 06-20-2014, 02:31 AM - Thread Starter
I'll give that a read and post back with any questions if I have any, thank you guys for all the info and help!
