7.1 w/2 subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-19-2014, 05:06 AM - Thread Starter
prestonrich's Avatar
Quoted: 43 Post(s)
7.1 w/2 subs
Would there be a material loss in music enjoyment by running 2 subs on the mains of a 2.1 receiver using a "Y" connector (I.e., Emotiva Fusion 8100) instead of moving to a different 7.2/5.2 receiver? Mainly listen to classical music.
prestonrich is offline
post #2 of 8 Old 06-19-2014, 05:10 AM - Thread Starter
Quoted: 43 Post(s)
Sorry, need to add that I'll be using 2 SVS SB-2000 active subs w/bose 601 Series II's.
post #3 of 8 Old 06-19-2014, 05:25 AM
Bill Fitzmaurice's Avatar
Liked: 5667
No problem.
Bill Fitzmaurice is offline
post #4 of 8 Old 06-19-2014, 05:38 AM
rcohen's Avatar
Quoted: 1377 Post(s)
Liked: 604
If the subs are different distances from you, you will need to tune the phase individually on the amp panel of each sub. Nothing wrong with that - just an extra step. One way to do this is to use a real time analyzer (REW or RTA) and tune the phase to maximize the volume at the crossover frequency.
By contrast, on a 7.2 receiver, it can usually (but not always) time align the subs automatically, so you can leave the sub phase set to 0.
rcohen is offline
post #5 of 8 Old 06-19-2014, 07:26 PM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 714
Even if the distance is not the same, they may function better with both sub's phase control at 0. The avr may use an average distance of the the two sub's in it DSP calculations. Also the physical and acoustic distance are not necessarily the same thing.
derrickdj1 is offline
post #6 of 8 Old 06-20-2014, 09:09 AM
Alan P's Avatar
Quoted: 5050 Post(s)
Liked: 3727
Or, you could just use and SPL meter (or an SPL meter app on your phone) and adjust phase for highest SPL at the MLP.
Not all people have the equipment for RTA.
Alan P is offline
post #7 of 8 Old 06-20-2014, 12:19 PM
sivadselim's Avatar
Quoted: 260 Post(s)
Liked: 220
Many so-called x.2 AVRs do not offer much more capability (if any) than can be accomplished with a Y-splitter, anyway. There ARE some, though, that DO offer more capabilities in regards to individually adjusting 2 separate subwoofers.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #8 of 8 Old 06-20-2014, 02:23 PM
rcohen's Avatar
Liked: 604
There ya go. Just play a test tone at the crossover frequency, do what he said.
rcohen is offline
