NEED new sub(s) $800-1500 for HT slam - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 53 Old 06-21-2014, 07:58 AM - Thread Starter
B0dyK0unt's Avatar
Looking for advice on what sub to purchase.
Budget: $800-1500
Size requirement: none
Room size: 14x20x9, but since it is bonus room above garage, the ceiling is sloped on both sides. Approx cu ft is 2400.
Primary use: dedicated home theater room. Mostly movies. Some music from paladia music channel, but I am most interested in a loud tight theater.
Listening habits: reference level if it is a good action flick. Usually loud. I can't help myself.
Appearance: none
Time: none
I use my room wide instead of long. The only place I get a decent bass response on both sides of couch (main listening area) is for the sub to be placed directly behind couch.... Found location by sub crawl. I can close off my room completely. I feel I am missing some lower end freq and slam with current sub (pa120) and time for upgrade. I've been considering an svs pb2000, 2x pb2000, hsu vtf15, psa15, psa30, rythmic fv15hp, svs pb12+, etc. I want bone shaking, chest slamming feel in my room, and open to consider any listed above or other. I want to feel the air move and stuff to rattle. Any suggestions? I'll continue to read other posts for guidance, but any specific advice is much appreciated!
Here's my current gear:
Pani 65 vt30
Onkyo 818 with aud xt32 (but no sub eq)
PSB image t6 front and matching center
Surrounds are nht subzeros
15 homemade 2'x2'x2" acoustic panels in room (no bass traps)
Sub: Pa120
B0dyK0unt is offline
post #2 of 53 Old 06-21-2014, 08:14 AM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
It's too bad you just missed a sale on Outlaw's LFM-1 EX @ $599/ea., shipped.
That said:
- Dual SVS PB-2000s @ $1,499, shipped, should do the trick. (If they don't, return them within 45 days and the in-home demo costs you $0.)
- If you can go a bit over budget, dual PSA XV15se's @ $1,699, shipped, should work even better.
eljaycanuck is offline
post #3 of 53 Old 06-21-2014, 08:15 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
I would go with a PSA XV30se or Rythmik FV15HP. If you have room for duals then a Pair of XV15se could work very well in that room(but slightly over budget).. However I would not go with a single sealed sub. If you can only do 1 sub definitely go ported, if you can go with atleast 2 subs, sealed should be fun and work well. That being said I do not think there is any pair of sealed commercial subs that will net you clean reference playback in your stated budget....atleast not below 30hz.
Another option is DIY. It has never been easier...plenty of sources on these forums offering precut flatpacks. You can source drivers from PE(parts express) such as the Dayton Ultimax, RS390, or Eminence Lab15 and build some killer subs. Power them with a Inuke 3/6000dsp and you will have a mega bass system that will play reference down to 15hz fairly easily.
basshead81 is offline
post #4 of 53 Old 06-21-2014, 08:17 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
I believe PSA is now offering a 45 day in home demo fwiw.
Last edited by basshead81; 06-21-2014 at 08:25 AM. Reason: typing from a N3 can be a pain in the arse!!
post #5 of 53 Old 06-21-2014, 08:20 AM
Liked: 1962
Originally Posted by basshead81 View Post
I believe PSA is not offering a 45 day in home demo fwiw.
I believe you're right...and that's why I didn't say they do.
post #6 of 53 Old 06-21-2014, 08:24 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
That was a typo Eljay I meant to say "NOW".
post #7 of 53 Old 06-21-2014, 08:55 AM - Thread Starter
B0dyK0unt's Avatar
Elijay and basshead, thx for the quick replies and suggestions! I had not considered DIY, although I am fairly handy and should maybe look into it. Always seemed like more trouble than it was worth, and was worried about creating something that was a big bloated boom box vs something that was a finely tuned machine created by folks/engineers who had proven products out on the market.
So, are 2 psa xv15se generally considered better than 2 svs pb2000 for my application? And, would 2 xv15se be better than 1 psa xv30se or 1 rhythmic fv15hp? I don't mind giving up floor space if duals are significantly better, but only needing to consider placement of one sub seems significantly easier than two, so would want clearly better performance.
One other question.... How do dual outlaw lfm1ex compare to dual pb2000 or xv15se?
Thanks again guys.
post #8 of 53 Old 06-21-2014, 09:10 AM
bear123's Avatar
Quoted: 1804 Post(s)
Liked: 2679
I would recommend two options:
Dual PSA XV15se
or
Start with one Rythmik FV15HP. I can see you ending up with two of these down the road based on your post. I think this would be the best long term solution. One will rock your room quite well, two will solve upgradeitis when it hits and be a good, long term solution for clean reference level output.
bear123 is offline
post #9 of 53 Old 06-21-2014, 09:52 AM
Liked: 1962
Understood.
post #10 of 53 Old 06-21-2014, 10:01 AM
enricoclaudio's Avatar
Quoted: 1484 Post(s)
Liked: 1613
One FV15HP should be more than enough in your room. We have a couple of FV15HP B-Stock with a blemish on one amplifier corner. They are 15% discount ($1138 + shipping).
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #11 of 53 Old 06-21-2014, 10:18 AM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 580
i have 2 PSA xv15's and more ft^3 than you do. you would not be disappointed at all. you may even consider the sealed version in your room if you go duals (xs15). trust me, you wouldn't be disappointed in any PSA offering, and tom is one of the best people to work with because he really knows his stuff...and the customer service is hands down fantastic.
digler84 is offline
post #12 of 53 Old 06-21-2014, 10:20 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
DIY designs here like the Marty sub series have been well designed and tested (in the sense of successfully being built by many rather than something like the data-bass.com type testing). The extent and quality of the box construction is up to you but there's lots of information here.
By the way while the 818 doesn't have SubEQ it does eq subs just fine, it just can't set two subs' different level/distance automatically (so with single sub doesn't come into play at all).
lovinthehd is offline
post #13 of 53 Old 06-21-2014, 10:24 AM
bear123's Avatar
Liked: 2679
That's a great deal on a great sub.
bear123 is offline
post #14 of 53 Old 06-21-2014, 11:11 AM
JT78681's Avatar
Quoted: 1478 Post(s)
Liked: 1005
Pretty damn good deal! If not this spend a few hundred more and get the XV30Fse and lay it on it's side behind the couch. Seems like this would give some serious slam.
JT78681 is offline
post #15 of 53 Old 06-21-2014, 11:40 AM
dsrussell's Avatar
Quoted: 2261 Post(s)
Liked: 3095
B0dyK0unt: Your room falls into the medium size category (under 3,000 cu. ft.). A single FV15HP should have no problem blasting that room. Neither would an XS30se for that matter, or anything else mentioned here. I have the original XS30 in a large size room (around 3,400 cu. ft.) and have no problems shaking the walls, floors, seats and myself. Two may be required if you have problems with nulls at your seating position. If not, one should do fine.
dsrussell is offline
post #16 of 53 Old 06-21-2014, 12:24 PM - Thread Starter
B0dyK0unt's Avatar
All great feedback. I really do appreciate it, all of you! Sounds like there is very good potential I can be satisfied with a single fv15hp or dual xv15se's (or sealed xs15's).
Enricoclaudio... Do you happen to have a pic of the corner blemish? Or if not, can you let me know how big/bad it is? If I choose that route, I don't want to be penny wise and pound foolish if it's a real eye sore.
Still deciding between to two options that appear to be in the lead - 1 fv15hp or 2 xv15se.
post #17 of 53 Old 06-21-2014, 12:38 PM
Tom Vodhanel's Avatar
Quoted: 2021 Post(s)
Liked: 5980
From PSA, in this room size I would lean toward dual XS15se. I'd expect extension into the single digits with a good amount of headroom(dual XS15se = the $9000 paradigm sub 2 in Josh's testing for example). Also, going with duals (over a single XS30se for example)is almost sure to offer audible benefits in regards to bass smoothing at the seats. Also, our sealed XS15se will mirror the room transfer function here really well which helps the overall SQ as well. Really, either way you go you are getting high quality bass, the 15hp is a real monster.
PS---we're offering free shipping both ways on the XS15se and XV15se now so you can audition them in your home for 30 days risk free.
Tom V.
Power Sound Audio
Jahjd2000 and dsrussell like this.
Tom Vodhanel is online now
post #18 of 53 Old 06-21-2014, 01:28 PM
Liked: 1613
I don't have a pic but I can ask Brian for it. Also know that full warranty apply to all b-stock units.
post #19 of 53 Old 06-21-2014, 06:14 PM
JT78681's Avatar
Liked: 1005
Tom V.
Power Sound Audio
Tom,
Very classy giving credit to the FV15HP. Your a frequent poster on the forum and I like that. Always willing to help other members out even if they don't own your subs nor are looking to buy your subs. Very admirable and this speaks volumes about your company.
JT78681 is offline
post #20 of 53 Old 06-21-2014, 07:24 PM
tvuong's Avatar
Quoted: 1789 Post(s)
Liked: 1083
^^ I read Tom's reply as he was trying to push the op to buy his subs which he is entirely free to do so.
tvuong is online now
post #21 of 53 Old 06-21-2014, 07:27 PM
lovinthehd's Avatar
Liked: 4781
Well, we have both Rythmik and Power Sound Audio putting deals in front of the OP. I like it.
post #22 of 53 Old 06-22-2014, 06:20 AM
JT78681's Avatar
Liked: 1005
Yeah I got that from his post, but he also said this.
JT78681 is offline
post #23 of 53 Old 06-22-2014, 08:50 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
He said the FV15HP "is a real monster". Imo that speaks highly of Tom's character and why his business will continue to be successful.
post #24 of 53 Old 06-22-2014, 10:54 AM
dsrussell's Avatar
Liked: 3095
^^ Yep, I was a little taken aback when I read tvuong's statement, although I don't think he meant it to sound as negative as it did. The OP stated his favorite two options from the list he created were the Rythmik and PSA and he was undecided. It is neither a PSA- or Rythmik-specific thread, so if the owners / representatives want to come aboard and clarify something to the OP about their products, I'm a huge fan of this. Both Rythmik and PSA did just that and both have great reputations. The point tvuong may have missed is that Tom gave high praise to Rythmik (a clear competitor). This is a great indication about what type of person Tom is. Of course, everyone who has had any dealings with Tom and PSA already knows this.
post #25 of 53 Old 06-22-2014, 02:54 PM - Thread Starter
B0dyK0unt's Avatar
It's good to see all the feedback, and as the OP, I certainly think I took Tom in the correct context.... If I am going psa, I should consider dual sealed vs the ported based on my application (tom's the expert, and I'd be foolish not to consider sealed vs the ported which, to be honest, I had not up until now), and if I consider the rythmik, then that is not a bad choice either. Seems like he's someone who would like to move his own product (who can blame him), but isn't going to mislead on other solid choices. Standup guy.
As for the rythmik, I am still curious if I could get more scoop on the "blemish" b-stock. Is it a new sub but just a manufacturer defect, or is it used/returned? I'm not an expert at these forums, but I'd be happy to provide an email if enricoclaudio and those that control this forum think that discussion is better taken off of this forum. I don't want to break any rules.
Tom, specific to you... I honestly do appreciate the direct interaction you have on this topic, and psa still in the running on my decision. I have to say my first reaction to the sealed vs ported psa15 was "am I going to feel the sealed as much as the ported?" I really do want the feeeeel of a sub at the low end and whatever frequencies make your chest feel like something is thumping it... Know what I mean? Your ported 15 wouldn't perform as well as the sealed in your opinion?
post #26 of 53 Old 06-22-2014, 04:07 PM
Liked: 1613
It's a brand new unit, not used, not returned. The blemish happened during the assembling process. I'll get the pic to you no later than tomorrow.
post #27 of 53 Old 06-22-2014, 04:38 PM
JT78681's Avatar
Liked: 1005
Both my FV15HP's were b-stock and still to this day I can't find the defects.
JT78681 is offline
post #28 of 53 Old 06-22-2014, 04:49 PM
Liked: 5980
Really, it comes down to one question----how much headroom will you need? If the dual XS15se meet your headroom requirements that is the way to go for two and possibly three reasons.
1)Less expensive ($1499 versus $1699)
2)Deeper extension
3)Smaller
You mention reference levels. With all speakers set to small this can require 115-121dB from the subwoofer(s). Can dual XS15se offer this output? Yes, but not down to 7-11hz. I'd say 22-25hz is a very safe bet. But 15-20hz may be limited to the 112-115dB range.
Dual XV15se would be fine at full reference levels down to the 16-18hz range but they wouldn't extend as deep as the XS15se.
For me, the deciding factor may come down to your bass channel calibration. If you prefer to have the bass a bit on the hot side (3-5dB over the rest of the channels) go with the XV15se combo..
Tom V.
Power Sound Audio
post #29 of 53 Old 06-22-2014, 05:15 PM
JT78681's Avatar
Liked: 1005
If Rythmik hadn't been local to me I most likely would be enjoying dual XV15's right now.
JT78681 is offline
post #30 of 53 Old 06-22-2014, 08:22 PM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 580
good ol' tom, always selling the RIGHT product versus the most expensive one. that's why i love psa!
digler84 is offline
