Budget sub recommendations please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-26-2014, 07:26 AM - Thread Starter
Signs's Avatar
Quoted: 209 Post(s)
Liked: 983
Hi all
My kef sub (psw1000) has died (constant buzzing) so I'm looking for a replacement , it's a 5.1 set up kef q5
dedicated room ..
amp is a yamaha Rx v675.
when i say budget i mean around £250/$320 mark
Cheers
Rob
Signs is offline
post #2 of 11 Old 06-26-2014, 07:54 AM
bear123's Avatar
Quoted: 1806 Post(s)
Liked: 2684
SVS PB1000. If it is not in the budget, I would save money until it was. Anything less than that is too much of a compromise imo.
bear123 is offline
post #3 of 11 Old 06-26-2014, 08:04 AM
rrskda's Avatar
Quoted: 72 Post(s)
Liked: 35
If you're definitely unable to go higher on the budget, I'd say check out the nxg nx-bas-500. They were out of stock for awhile, but are trickling back in now.
rrskda is online now
post #4 of 11 Old 06-26-2014, 12:50 PM
dsrussell's Avatar
Quoted: 2261 Post(s)
Liked: 3095
Signs: Nice little theater you have there! I agree with rrskda, the nx-bas-500 is probably the best in that price range if you live in the U.S. Otherwise, shipping and other charges eat up the budget.
dsrussell is offline
post #5 of 11 Old 06-26-2014, 01:06 PM
Kini62's Avatar
Quoted: 1741 Post(s)
Liked: 1555
Your screen is crooked.
Other than that, with such a nice theater, I would try and save for a sub to match. The sub has the greatest impact (pun intended) in the system. It really adds a lot to both music and movies, especially movies.
At a minimum you should get nothing less than a PB1000.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #6 of 11 Old 06-27-2014, 02:21 AM - Thread Starter
Signs's Avatar
Quoted: 209 Post(s)
Liked: 983
I went for the early Batman series look
Signs is offline
post #7 of 11 Old 06-27-2014, 02:33 AM - Thread Starter
Signs's Avatar
Quoted: 209 Post(s)
Liked: 983
I had a little play around last night and took my Kef 3005 sub from the lounge into the cinema room , although it sounds good in the lounge(lounge is bigger ) it seemed a little lost in the cinema room (i thought it would be better than the PSW )
I've decided to up my budget to say £500/$850
any recommendations in this bracket would be appreciated
cheers
Rob
Signs is offline
post #8 of 11 Old 06-27-2014, 09:04 AM
rrskda's Avatar
Quoted: 72 Post(s)
Liked: 35
Svs pb-2000
post #9 of 11 Old 06-27-2014, 11:28 AM - Thread Starter
Signs's Avatar
Quoted: 209 Post(s)
Liked: 983
Originally Posted by rrskda View Post
Svs pb-2000
Nooooooo! I wanted a bigger TV and ended up building a cinema room , no more ! Lol
Signs is offline
post #10 of 11 Old 06-27-2014, 11:32 AM
rrskda's Avatar
Quoted: 72 Post(s)
Liked: 35
Ha. Well in the price range you quoted, the PB-2000 seems like a decent option, no?
post #11 of 11 Old 06-29-2014, 08:08 AM - Thread Starter
Signs's Avatar
Quoted: 209 Post(s)
Liked: 983
Yes it does :-) I misread the price to start with , but I have now gone from £250 ish up to £645 !!!
Signs is offline
