Speaker question - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2014, 12:16 PM - Thread Starter
curtissp's Avatar
Quoted: 72 Post(s)
Liked: 3
Speaker question
Hello again everyone.
Had a question..
Since, I went with a NXG's Nx-bas-500 a mid range priced sub and have Polk 65T's as my fronts a kind of not so great speaker.. will the sound equal out from the sub and make them sound better or will just the sub just out perform the Polk's and make my system sound worse?
curtissp is offline
Old 06-28-2014, 04:32 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Had a question..
The level and crossover point on the sub are adjustable. Adjust them properly.
FMW is offline
Old 06-29-2014, 07:20 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
+1
Use your receiver's automatic room calibration. Then, try setting the crossover at 60 or 80hz (the receiver will often set the lowest possible value), whichever sounds better to you. If your receiver comes back with a subwoofer channel level that is a low negative number (e.g., -10 db or -12 db), turn the gain (volume) down on the sub and rerun the calibration. You want a to end up with a number much closer to 0.
Finally, you can always turn up the subwoofer channel on the receiver a few DB after calibration for a bit more bass output.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 06-29-2014, 04:27 PM - Thread Starter
curtissp's Avatar
Quoted: 72 Post(s)
Liked: 3
Wasn't really meaning the calibration I know about that I can adjust the levels so it doesn't out perform it on DB levels.
I meant will it sound any better adding the sub or will it make it sound worse being as the sub is high performance and the Polks are just entry level.
curtissp is offline
Old 06-29-2014, 04:52 PM
Kini62's Avatar
Quoted: 1421 Post(s)
Liked: 1308
It will sound better as the sub will fill in the low end and mid bass that the Polk's lack in.
Kini62 is offline
