How much bass is overkill? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Jon S
Old 07-02-2014, 11:43 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
Crazy question right?? How much bass would you consider overkill for a room? I have dual SVS PB-2000's and thinking of upgrading to dual PB12 Plus's. Room is about 12x15. Would this be overkill?
mpjmeyer is offline
Old 07-02-2014, 11:57 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
That wouldn't be overkill. So many subs that it takes up a large volume of your room is overkill
As long as the subs are level matched there will never be overkill, just headroom. And the more subs the smoother the response.
Bassment is offline
Old 07-02-2014, 12:10 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
You recommend the switch?
mpjmeyer is offline
Old 07-02-2014, 12:26 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
switch? Oh I thought you meant adding them. I don't think switching would be a huge noticeable upgrade, it would add MAYBE 6 dB. Adding them would add about 12 dB though. I guess it depends how much you can sell the 2000's for.
Personally, I wouldn't buy the PB12-Plus's, as I could beat their performance for half their cost with a DIY sub.
Bassment is offline
Old 07-02-2014, 12:31 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
LOL OK. Def. not add 2 more subs in my little room. I'll probably just keep the PB-2000's then if there won't be a noticeable difference.
mpjmeyer is offline
Old 07-02-2014, 12:42 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Why are you wanting to upgrade? Are your subs getting maxed out? You want more volume? Want lower extension? Don't like the sound?
Adding bass traps in the corners will greatly improve bass quality, you can build them for like 40 bucks a corner out of insulation, plywood and burlap.
If you want lower extension, dual sealed subs would be pretty awesome in a small room like that, you would get huge gains in volume at like 8 to 18 hz compared to ported.
You could also consider a usb measurement microphone, and a miniDSP to EQ your subs.
Bassment is offline
Old 07-02-2014, 01:35 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
I went from PC Ultra 13 to a SB Ultra 13, as I never needed the output levels on a ported sub
fatbottom is offline
Old 07-02-2014, 01:43 PM
kelch's Avatar
What cubic feet is your room?
kelch is offline
Old 07-02-2014, 01:45 PM
fatbottom's Avatar
Liked: 518
2.5 M x 3.5 M x 2.5 M.
SB sounds better in this sized room.
Old 07-02-2014, 01:59 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
But there would be a noticeable difference. 6db is a LOT. Plus you could easily run them in 16hz mode and drop your in room response to a solid 14-15hz.
If you can afford it, I would go for it.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Old 07-02-2014, 02:11 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
It's a $2800.00 upgrade, without knowing his speakers, room, amplifier, listening habits, etc. it would be hard to justify the upgrade IMO.
Bassment is offline
fatbottom's Avatar
Liked: 518
Yeah but he might not even need that 6dB. It's like saying get a Ferrari for pootling around town. Same for me, even with PC Plus never bottomed it out.
I don't think he needs to upgrade his dual PB2000.
Old 07-02-2014, 02:19 PM
Kini62's Avatar
Liked: 1300
Seeing that he has PB2000s I'm guessing he's within his one year trade in- upgrade period, in which case it would not cost $2800.
And only the OP can say whether or not he needs it.
There's a forum member here with 2 PC13 Ultras in a similar size room. My room is not much larger than the OP's and I could easily appreciate and use the extra output a second PC12 plus would give.
Def Tech SC8000
Kini62 is offline
Old 07-02-2014, 02:49 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
Overkill is when you watch "Saving Private Ryan" and the neighbors 100 ft away complain their windows are rattling...
Bassment and nexxest like this.
If it's not a BIG screen, it's not a theater...
Jon S is offline
Old 07-02-2014, 03:40 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
The room is appx. 12x15x7.5
7.2 setup with
Yamaha Aventage RX-A1030
SVS Ultra center and 6 SVS Ultrabookshelf
2 PB-2000's
SVS suggested I wouldn't notice a difference in upgrading in my room size, even if my room was bigger
mpjmeyer is offline
Old 07-02-2014, 03:45 PM
fatbottom's Avatar
Liked: 518
I'd get quad PB Ultra 13's and a ATI 3007. You know you want to. or
http://i14.photobucket.com/albums/a3...S/IMG_9563.jpg
Old 07-02-2014, 06:28 PM
Kini62's Avatar
Liked: 1300
7.2 setup with
2 PB-2000's
Can't see how they could or would say that. The Plus in 16hz mode obviously digs a little deeper, has more output at that range, has more output over the rest of the range, so you end up with more headroom allowing you to boost the low end even more if you want.
I had to turn my PC12+ down about 5dbs and run it in 20hz mode just to try and alleviate the chuffing. I'm actually a little bummed I get so much chuffing at levels I don't think are that loud, at least to me.
If it weren't for being out in Hawaii I'd have traded it in for a PC13 or SB13 Ultra by now.
Def Tech SC8000
Kini62 is offline
Old 07-03-2014, 04:27 AM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1555
BassThatHz is offline
Old 07-03-2014, 04:28 AM
BassThatHz's Avatar
Liked: 1555
Is it just my paranoia or is he trying to suggest something?
Old 07-03-2014, 10:30 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
Has anybody actually stuck to a budget while building a home theater? I caved and ordered dual pb12's. Just sent the pb-2000 back home with fedex
mpjmeyer is offline
Old 07-03-2014, 01:57 PM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 900
Sure, but stay off of here once it's built.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 07-03-2014, 02:00 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
That was fast. What didn't you like?
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
