AV123 MFW-15 pops when I unplug it. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-12-2014, 01:50 PM - Thread Starter
Liked: 0
dmbaile2 is offline
post #2 of 3 Old 07-12-2014, 03:47 PM
Tom Vodhanel's Avatar
Quoted: 1980 Post(s)
Liked: 5866
Originally Posted by dmbaile2 View Post
I just bought this thing used. The price was fair and the the seller guaranteed this sub had the v3 amp. My first question is, how can I tell if this indeed has a ver 3 amp? Believe it or not i have searched up and down and cant find an answer to this.
Secondly, I noticed that even when switch on the amp is in the "off" position, a red light stays on and the amp stays warm. I hooked a power reader inline with the outlet and power cord to see that the amp draws 35 watts, when the amp switch is in the off position. I figured I would just unplug it when not in use, but every time I unplug the amp i get pop from the subwoofer.
As all of this normal behavior? Is there anyway to keep the sub from popping when i unplug it?
I could be way off here as I never kept up on all the versions and the issues associated with each....but....I believe page 2 here shows V3? Wasn't V3 the all new amp that didn't have any connections to the top control panel?
NEW MFW-15 amps (May 2010) *pics*
see post 40,
Tom V.
Power Sound Audio
Tom Vodhanel is offline
post #3 of 3 Old 07-16-2014, 01:16 PM
murrel's Avatar
I attached a picture of the V3 amp. Yes it is normal for it to pop when you unplug it. let me know if you have questions or need some help.
Murrel
Murrel J Gray
murrel is offline
