Vary, very small subwoofers? - AVS Forum | Home Theater Discussions And Reviews
 9Likes
Old 07-15-2014, 08:54 AM - Thread Starter
Alan P's Avatar
Quoted: 4694 Post(s)
Liked: 3321
I'm trying to find a sub for my little office (at work) iPod setup. I've got the Micca MB42X Bookshelf Speakers hooked up to a Lepai t-amp. Sounds great but could use just a little help in the bottom end.
My problem is I only have 10" height under my desk to fit a sub...no room on top of the desk either. Was looking at the Dayton SUB-800, but it's too big. I found this Velodyne that would fit, but it's quite a bit more than I wanna spend on my office setup.
What decent quality sub would fit my space? Anything under $100? What about more expensive? I'll only be playing at low levels, since it's in my office after all.
Alan P is online now
Old 07-15-2014, 09:03 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Yamaha makes an unorthodox low profile sub: http://www.accessories4less.com/make...specifications
I don't really know anything about it, or how it sounds, but I suppose it would be better than no sub at all. There is also the PSB SubSeries1 which is a little more expensive but I would wager sounds better. http://www.crutchfield.com/p_760SS10...00.html?tp=187
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 07-15-2014, 10:29 AM
rrskda's Avatar
Quoted: 56 Post(s)
Liked: 25
Pinnacle has a small dual-6.5" sub that should just fit under your desk:
rrskda is offline
Old 07-15-2014, 11:36 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
I have a mirage MM6 which would fit. I think there are many manufacturers that market the exact same sub as their own. The Velodyne in your post may be the exact same sub. I got mine for $200 and it's an excellent under the desk computer sub. It's not worth $400.
KidHorn is online now
Old 07-15-2014, 12:02 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
As an option, consider putting beside your desk rather than under it.
FMW is offline
Old 07-15-2014, 12:46 PM - Thread Starter
Alan P's Avatar
Liked: 3321
Oooh, that has promise! Thanks.
Not an option unfortunately. My office is pretty tight, full of video editing equipment.
Old 07-15-2014, 01:30 PM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
This sub is a very good recommendation. I had one and was amazed what this little sub could do. I agree as for price $200 is good. If the OP could find the mirage satellite 5.1 kit with this sub for less that $450 it too is an amazing combo deal. Small speakers / subs but great sound.
Shift is offline
Old 07-15-2014, 02:00 PM
Tom Vodhanel's Avatar
Quoted: 1563 Post(s)
Liked: 4474
Glue two of these
http://www.parts-express.com/tang-ba...oofer--264-909
To one of these
http://www.amazon.com/Quality-Park-M.../dp/B0006UXOJ8
Add a 99 cent binding post and a cheap amp like this
http://www.parts-express.com/lepai-l...upply--310-300
You can stand it up in a corner behind you and people would just think it is work related?
Tom V.
Power Sound Audio
Tom Vodhanel is online now
Old 07-15-2014, 02:05 PM
LastButNotLeast's Avatar
Quoted: 1472 Post(s)
Liked: 1066
How about a buttkicker?
http://www.thebuttkicker.com/gamer2
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 07-15-2014, 02:13 PM - Thread Starter
Alan P's Avatar
Liked: 3321
Can't seem to find the Mirage right now for less than $450.
Originally Posted by Tom Vodhanel View Post
Glue two of these
To one of these
Tom V.
Power Sound Audio
Now that's funny Tom.
But, seriously...would that actually work?
BTW, that's the exact amp I already have.
Considered it, but my chair needs to be mobile. I slide from my work desk to my editing desk all day long.
Old 07-15-2014, 03:04 PM
Liked: 4474
Oh I bet it works as good as the <$200 options in this thread..
You would need to ensure an air tight seal between the drivers and the tubing but that shouldn't be that difficult. Also, you could do a curve enclosure too if it helps with the limited space aspect.
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
this might make the air tight seal easier?
http://www.parts-express.com/precisi...e-kit--268-350
I don't have time to model any of this (There's probably 10 DIYers that will in that section.. but if all you are looking for a a bit of bass down to say 35-40hz I bet this works fine. Of course as soon as you turn up the 20w amp you'll think...."man, this sounds GOOD, I just wish it were a little louder" And then you'll find yourself shopping for a 40w or 80w amp.
Before you know it you'll have co-workers and friends asking for custom versions. And then it is APSpeakers inc!
Tom V.
Power Sound Audio
Old 07-15-2014, 03:13 PM - Thread Starter
Alan P's Avatar
Liked: 3321
Tom....you're crazy.
That's why you design speakers and I buy 'em. I could probably build something like that (with help) but I'm the kinda dude who likes to buy stuff already assembled....just ask my wife as she witnessed the last grill I had to put together.
Anyways, I just ordered that Pinnacle from Woot....seemed like a screaming deal at $180 (MSRP $750, going for around $600 retail right now, $400 used). I'll let you all know how it works out in a few days.
Old 07-15-2014, 03:14 PM - Thread Starter
Alan P's Avatar
Liked: 3321
Oh, and thanks again rrskda for posting this great deal!!
Old 07-15-2014, 03:34 PM
Liked: 4474
another option,
http://www.markertek.com/Audio-Equip...FQ1gMgodP04A-Q
Tom V.
Power Sound Audio
Old 07-15-2014, 03:46 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5204
Just ordered one myself to replace a junk logitech sub for my computer. -3db @ 28hz with 107db output should be plenty!
basshead81 is offline
Old 07-15-2014, 03:52 PM
rrskda's Avatar
Quoted: 56 Post(s)
Liked: 25
Great, let us know how it performs. Hard to find reviews of Pinnacle subwoofers.
rrskda is offline
Old 07-15-2014, 04:39 PM
sivadselim's Avatar
Quoted: 160 Post(s)
Liked: 154
yeah, thx for the link (I guess )
feelin' kinda froggy, myself
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
Old 07-16-2014, 11:05 AM
KidHorn's Avatar
Liked: 877
This one might fit if you turn it on its side and remove the feet...
http://www.amazon.com/Acoustic-Audio...nch+subwoofers
Old 07-17-2014, 09:02 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5204
Well I recieved my Pinnacle Subsonic today. It came packaged very well. Thick single layer cardboard lined with 3" thick heavy duty foam. After Unboxing, the little 8" cube is a stone weighing 25-30lbs. It came with a fairly detailed intruction manual along with a quick setup sheet. I was also suprised to see a sub cable included with 4 heavy duty brass spiked feet. The amp is a class a/b that draws some decent heat and the heat sink is half the size of the sub.
I ended up setting the sub up in my 2.5 car garage. I had a pair of Polk RTI-4 book shelfs and a old Sony AVR lying around. So after work I began "project garage bass".
Initial impression, this little sub is amazing. Now bear in mind it's not going to knock pictures off the wall, but for being placed in a 4000^3 garage with concrete floors, this little sub manages to slightly shake all the walls including the garage door. In a small den with a computer setup, this little bastage would be amazing!! For 699.00 retail its waaaayyy over priced, but for 179.00 closeout its a steal. Tight, clean, accurate bass that digs pretty deep for a little cube. I can say there was no way I expected this kind off bass from such a tiny sub.
Old 07-17-2014, 09:58 PM - Thread Starter
Alan P's Avatar
Liked: 3321
That's very encouraging BH! Mine will be here tomorrow and I'll let you know how it does in my 700^3 office.
I think my boss (office next door) is gonna hate me......or fire me!
Old 07-18-2014, 03:08 PM - Thread Starter
Alan P's Avatar
Liked: 3321
WTF?!
This morning my tracking said it would be delivered today....now my little sub is taking a cross-country trek.
Old 07-18-2014, 04:07 PM
LowerFE's Avatar
Liked: 41
You can listen to music on speakers at work??? Even if you have your own office, wouldn't people notice?
LowerFE is offline
Old 07-18-2014, 04:16 PM - Thread Starter
Alan P's Avatar
Liked: 3321
Yeah, nobody's complained....yet. But I don't have the sub yet either.
LowerFE likes this.
Old 07-21-2014, 11:10 AM - Thread Starter
Alan P's Avatar
Liked: 3321
OK, got the Pinnacle sub hooked up in my office this morning...all I can say is good thing my boss is on vacation this week.
This little sub has way more output than I would ever use in my office! Nice tight, clean bass even at lower levels. This thing was a steal at $179! Much heavier than it looks too.
All I need to do now is bring my SPL meter in so I can calibrate the level. Can I just use any of the "pink noise" vids found on Youtube??
i.e.:
basshead81 likes this.
Old 07-21-2014, 12:35 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5204
I agree alan! I was going to make a you tube video of the little sub hammering in my 4000^3 garage. From 6" I recorded 115db peaks playing bass music, from 3ft away I was still seeing 112-113db, from 12ft away 100db, and most of the garage space shows atleast 96db output. Now that is damn respectable for a 8" cube imo. I would of never imagined....179.00 was a steal no doubt!!
Old 07-21-2014, 12:53 PM - Thread Starter
Alan P's Avatar
Liked: 3321
Hey basshead, where do you got the gain on your sub set? Mines at about 10:00 and seems about right.
Old 07-21-2014, 04:03 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5204
About 9-10:00
Old 07-21-2014, 04:35 PM
rrskda's Avatar
Quoted: 56 Post(s)
Liked: 25
Originally Posted by basshead81 View Post
About 9-10:00
Great to see it getting such good reviews. Any idea how low the frequency response goes, +/-3dB?
rrskda is offline
Old 07-21-2014, 04:52 PM - Thread Starter
Alan P's Avatar
Liked: 3321
According to this, it's 28hz.
Old 07-21-2014, 05:14 PM
rrskda's Avatar
Quoted: 56 Post(s)
Liked: 25
Yep, which is why I'm curious about how low it actually goes
rrskda is offline
