Dual PB12-Plus vs. Dual XV30Fse for Articulate Bass - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Dual PB12-Plus vs. Dual XV30Fse
Dual PB12-Plus 17 43.59%
Dual XV30Fse 16 41.03%
Something else (recommendation in comments below) 6 15.38%
Voters: 39. You may not vote on this poll
 5Likes
  • 1 Post By basshead81
  • 2 Post By dsrussell
  • 1 Post By DualMono
  • 1 Post By Kini62
post #1 of 28 Old 07-19-2014, 06:40 AM - Thread Starter
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
I'd appreciate any comments you have on deciding between dual SVS PB12-Plus subs, dual PSA XV30Fse subs, or some other option you might recommend. The additional output of the XV30Fse is apparent, but I want to be sure I am not giving up sound quality for quantity. I had an early SVS 16-46 that dug deep yet sounded very smooth. I suspect sub design has improved greatly over the years to the point that I'd be happy with either option above, but I want to be certain that going for the XV30Fse would not come at the cost of losing some of the smooth sound I loved from my prior SVS. I also want to ensure good sub-20 Hz extension. It seems like both options will provide this sufficiently based on the data-bass.com info (although it only reports the PB13 and not the PB12, which are fairly different animals).
My room is fairly small at 11 x 17 x 7.5 (approx. 1400 cu. ft.), but behind the screen wall it currently opens to an unfinished portion of my basement. The subs will be placed outside the room, firing from the unfinished part of the basement into the theater room through GOM acoustically transparent fabric. I plan to eventually build a wall behind the screen wall to fully enclose the theater, but until then, the subs will have open space behind them. I say this mainly to see if I should also consider some other dual-sub option at approximately the same price point that would work for my situation (around $2500-$3000 total). I'm concerned that a downward firing sub would disperse much of its energy into the unfinished part of the basement and not into the theater room.
Thanks for your thoughts on whether I should go with dual PB12-Pluses, dual XV30Fses, or something else.
jstach500 is offline
post #2 of 28 Old 07-19-2014, 08:00 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6519
Both subs are using quality components, sound quality should be great between both. To answer your question about downfiring, bass waves are omnidirectional so the placement of the driver does not matter.
Last edited by basshead81; 07-19-2014 at 08:30 AM. Reason: one suggestion was over budget
basshead81 is offline
post #3 of 28 Old 07-19-2014, 09:25 AM
oneeyeblind's Avatar
Quoted: 262 Post(s)
Liked: 482
Check out the XVF30SE on data bass and compare it to the PB ultra 13
http://www.data-bass.com/data?page=s...d=106&mset=118
http://www.data-bass.com/data?page=system&id=55&mset=53
The Pb plus will likely be a bit behind the ultra...
How big of a room are you working with?
ShaunH
oneeyeblind is offline
post #4 of 28 Old 07-19-2014, 09:45 AM - Thread Starter
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
Thanks. My room is about 1400 cu. ft.
post #5 of 28 Old 07-19-2014, 09:53 AM
Quoted: 262 Post(s)
Liked: 482
Sorry I missed that in your first post.
ShaunH
post #6 of 28 Old 07-19-2014, 10:48 AM
Quoted: 75 Post(s)
Liked: 112
Either option will make you crap your pants in that room. You might take a look at Rythmik; something like dual D15SE subs or E15 subs.
rnatalli is offline
post #7 of 28 Old 07-19-2014, 10:53 AM
Kini62's Avatar
Quoted: 1723 Post(s)
Liked: 1539
An option would be to try both in your room. Maybe just to get an idea how they sound order one of each and compare them directly at the same time. I believe PSA has free return shipping for the summer on the Power X series.
Another sub to consider would be the Reaction Audio BP215X or their vented PV15X. The PV should be an output monster and it can be had as in a passive version so you could run any amp you want with it.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #8 of 28 Old 07-19-2014, 08:43 PM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 722
I voted other since both sub can give you articulate bass. The key for good bass is setup and taming room interaction. My guess is they will sound very similar as most subs do if setup correctly.
derrickdj1 is offline
post #9 of 28 Old 07-19-2014, 09:41 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
Why wouldn't you consider the Rythmik FV15HP? It bests them both for about the same price, especially for articulation.
shadyJ is offline
post #10 of 28 Old 07-20-2014, 09:06 AM - Thread Starter
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
Thanks for your thoughts, everyone. I had originally dismissed the Rythmiks because some had said they lacked in build quality, particularly compared to the SVS. It sounds like I shouldn't be so concerned about that given the endorsements here. I'll add it back to my list of things I am considering.
post #11 of 28 Old 07-20-2014, 09:13 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6519
Yes the FV15HP is a fine sub, actually one of my favorites, but I would not say it is more articulate then the other 2 subs. All 3 will serve you well, contact each company, get a feel for the perks that each company offers and go from there.
post #12 of 28 Old 07-20-2014, 10:34 AM
tvuong's Avatar
Quoted: 1789 Post(s)
Liked: 1083
Rythmik uses quality driver and amp. Matter of fact, it is the only company I know of that uses toroidal transformer in its amp.
tvuong is online now
post #13 of 28 Old 07-20-2014, 12:00 PM
Romans828's Avatar
Quoted: 141 Post(s)
Liked: 71
SVS and PSA both have 5 year warranties on the the electronics. Rythmic only has a 2 year warranty on electronics (unless it has recently changed). I'm going to be looking to buy dual high quality subs next year for a new build...so I've been going doing the same path. I'm leaning toward dual SVS PB13-ULTRA's due to positive reviews, company stability/support. I don't hear much about PSA. I had never really considered them until viewing this thread. I will have to investigate them further.
Romans828 is offline
post #14 of 28 Old 07-20-2014, 12:27 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6519
The owner of PSA is the former co-founder of SVS. Tom Vodhanel is the "V" n SVS(Stimpson Vodhanel Sound).
Romans828 likes this.
post #15 of 28 Old 07-20-2014, 12:32 PM
dsrussell's Avatar
Quoted: 2261 Post(s)
Liked: 3095
Romans828: It would be nice if Rythmik increased its amplifier warranty. However, amplifiers, if they are going to go bad, will usually do so earlier instead of later. All companies will have a certain percentage of amplifiers that go bad. Rythmik subwoofers are extremely well thought of and is a top tier I.D. company. They make amazing products.
I own an SVS SB13-Ultra and can say it is a marvelous subwoofer, especially for music (which is why I purchased it). The customer service from SVS is top tier all the way, and dealing with Ed Mullen was a pleasure. Can't say enough good things about Ed and SVS.
Not surprisingly, I also own a PSA XS30 subwoofer, which I feel is a powerhouse for movies. The new versions of all their subs, the "se" versions, take them to a new level. Tom Vodhanel was the "V" in SV Sound, so no one knows SVS better than Tom. He designed many subwoofers for SVS before creating his own company and was one of the main reasons I chose PSA. The customer service from PSA is also top tier, and like Ed Mullen, Tom was a pleasure to deal with. When I stumbled and my knee hit the edge of the grille panel and broke the plastic seating dowels, Tom sent me a new grille, plus dowels and instructions to repair the old one (so I'd have a backup if needed). No charge. Now that is customer service!
cchunter and Romans828 like this.
dsrussell is offline
post #16 of 28 Old 07-20-2014, 04:51 PM
Romans828's Avatar
Quoted: 141 Post(s)
Liked: 71
Cool...thanks for the information. The PSA Triax looks like a monster!
post #17 of 28 Old 07-20-2014, 06:27 PM
DualMono's Avatar
That baseless rumor was probably started by fanboys of brand X subs.
Tdekany likes this.
DualMono is offline
post #18 of 28 Old 07-21-2014, 05:40 AM
JT78681's Avatar
Quoted: 1478 Post(s)
Liked: 1005
Solid options and recommendations here. I have to say though that I'm a little shocked that the title reads "Articulate Bass" and Rythmik is not even in the running
JT78681 is offline
post #19 of 28 Old 07-21-2014, 11:24 AM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 832
For articulate detailed bass with a small footprint I would suggest the SVS SB13 Ultra. Incredible little sub that will do very well in 1400 cu ft. Good luck!
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
Klipsch RF7II's, RC-64II, RS-52's Cherry
SVS Dual SB13 Ultra's
Oppo UDP-203 Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #20 of 28 Old 07-21-2014, 12:28 PM
jwtallguy's Avatar
Quoted: 119 Post(s)
Liked: 55
I have 2 pc12+s in a 2800 cf room that opens up to another 1800 cf through a door size opening and in 16 Hertz tune I get a very flat response to 20 hertz at 116 db plus and thats not the best spot for 10-22 hertz but gave me the +-4 db to 100 hertz I needed.
The pb12+ has about 3 db more output at 16 hertz over the pc version
jwtallguy is offline
post #21 of 28 Old 07-25-2014, 08:42 AM
retro124's Avatar
Quoted: 1289 Post(s)
Liked: 997
I do also have dual PC12 -Pluses in 1680cf room with open kitchen. Set both in 16hz mode and those do amazing job. PC12-Plus and PB12-Plus have almost same output if any different you can't tell. 3db more output is between PB13-Ultra and PC13-Ultra( this is what people from SVS told me).
I never had a change to listen PSA subs but if I will count Company popularity, how easy is to return it if you want to step up or even down in 45 days( lot's of free playing time), customer service and 1 year full price trade up you can't and will not go wrong with SVS.
P.s. And their outlet section will safe you some extra $$$ like I did, brand new dual Pluses on end cost me $1900 witch I think is great price!!!!
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses, Emotiva XPA-200
Sony XBR65X930E , Oppo 203
Projector and scren shopping now :D
Apple Mac mini, Sony PS3,
retro124 is offline
post #22 of 28 Old 08-20-2014, 05:12 PM - Thread Starter
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
Thank you, everyone, for your suggestions. I decided to take some of the "other" suggestions and purchased two SVS PC12-Plus cylinders. I am working to integrate them into my system. At the moment I am getting some hum from my balanced 2x4 miniDSP, but I hope I can get that worked out. Anyway, I just wanted to close out this thread by updating you on my decision. I appreciate everyone's help.
post #23 of 28 Old 08-20-2014, 06:21 PM
Kini62's Avatar
Liked: 1539
You can't close out the thread without letting us know how you like (or don't) them in your room. So once you get them setup come back and give us your impression.
retro124 likes this.
Def Tech SC8000
Kini62 is offline
post #24 of 28 Old 08-20-2014, 07:14 PM
retro124's Avatar
Liked: 997
Agree with Kini62 you need to let us know how do you like them.
Denon X6200W
retro124 is offline
post #25 of 28 Old 08-21-2014, 05:37 AM - Thread Starter
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
Once I get them integrated, I'll let you know how I like them. They do have plenty of power in my room. I ended up building the wall to close the room off from the unfinished part of my basement, so the room is now around 1800 cu. ft. As an aside, I was able to eliminate the hum in the miniDSP last night by grounding the chassis. I ran a wire from one of the screw mounts where the PCB attaches to the chassis to the screw on the outlet where I plugged in the miniDSP's power supply. It completely eliminated the hum and put me one step closer to getting these things integrated. I am going to see about a more elegant and permanent way to achieve the necessary grounding, but at least I know it works and I will be able to keep the miniDSP in the chain.
post #26 of 28 Old 10-11-2014, 05:42 AM - Thread Starter
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
I spent much of the last month buying a new receiver, discovering it was broken in a couple of different ways, and then waiting an extended amount of time to get it fixed. Everything seems to be working now and I am very pleased with the way the SVS subs have integrated with my system. They have plenty of authority in my room (to the point where I set them to -19 dB in the SVS amps), yet they blend so well with my other speakers that I sometimes forget they are there. The sound just seems to emanate from the other speakers. It was a great solution. My thanks to everyone here for their help.
post #27 of 28 Old 10-11-2014, 12:04 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
^^^^^ +1 both options in the poll would give you articulate bass. Its all about placement, placement, placement, taming peaks and avoiding null spots. Is not like Rythmic is magically immune to all those factors.
| Panasonic TC-P65S2 HD Plasma | Oppo BDP-93 | Paradigm Studio 100's v2 (mains) | Paradigm Studio CC-690 v5 (center) | Paradigm ADP-370 v3 (sides surr.) | Paradigm Studio 20's v2 (sides + back surr.) | SVS PB13-Ultra(x3) | Marantz AV-8801 pre/pro | Emotiva XPA-5 (x2) |
Luis5150 is offline
post #28 of 28 Old 10-11-2014, 08:35 PM
Kini62's Avatar
Liked: 1539
Glad to hear that you are satisfied with your SVS subs. I know I like mine, I just need another one. The SC8000 does a fair job a taking some of the load off but it's just not the same.
Thanks for following up.
Def Tech SC8000
Kini62 is offline
