Need a Sub for a Large Room - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By dsrussell
  • 1 Post By tvuong
post #1 of 18 Old 07-20-2014, 08:41 PM - Thread Starter
royalstud02's Avatar
Liked: 0
Question Need a Sub for a Large Room
I am trying to decide what sub would be a good fit for my home theater. The room is very large and has 16 foot ceilings and is adjoined by the kitchen and entry and has an open floor plan. I would prefer one sub and really don't want to spend more than $1000. I'm not concerned with how nice it looks or how big it is. I mainly watch movies and rarely listen to music so I'm thinking a large ported sub might be best. I appreciate any and all input. Thanks!
royalstud02 is offline
post #2 of 18 Old 07-20-2014, 09:00 PM
dsrussell's Avatar
Quoted: 2177 Post(s)
Liked: 2954
With your requirements, including an extreme room volume, you could try PSA's XV15se. It's $899 shipped with free shipping back during their 30-day trial period.
Reaction Audio has a similar model for the same price, the PV15x.
dsrussell is offline
post #3 of 18 Old 07-20-2014, 09:00 PM
shlitz501's Avatar
hi. im a newbie. but i have a infinity PS-8 in a 30x40 room 9' ceilings. it pounds and extends all the way to dining room 60' away bass hits just as good in living room as dining room with in wall paradigm AMS-300's. bass just as good 60' away. all wood house all wood floors and all open concept. house parties are amazing. just have to adjust freq settings for your liking. movies require different settings than music. Just make sure to have lots of room for sub to breathe.. My sub is a late model infinity. no problems. thing gets the **** beat out of it every time wife leaves. lol.
hope that helps. no need to spend 1000$. unless everything else is comparable quality. cheers. I am a newbie and am going to get blown away from the experts but I too am learning and hope it helps. cheers.
shlitz501 is offline
post #4 of 18 Old 07-20-2014, 09:51 PM
K5/SS's Avatar
Quoted: 71 Post(s)
Liked: 127
I guess everyone has a different definition of "pounds".
The PSA and Reaction audio suggestions are very good ones. I would also keep an eye out for the Outlaw Audio LFM-1 EX. They are a little over your budget right now but they go on sale occasional and you might be able to get a better deal when ordering duals.
That's a huge room to fill with that budget. DIY might be the way to go.
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
K5/SS is offline
post #5 of 18 Old 07-20-2014, 11:02 PM - Thread Starter
Liked: 0
I appreciate the feedback and have never really given any thought to the DIY subwoofer. Is there a certain thread that you would recommend? I'm sure there are 100's on avs regarding that topic. How difficult is DIY and are there certain components you would recommend?
post #6 of 18 Old 07-20-2014, 11:29 PM
BassThatHz's Avatar
Quoted: 1996 Post(s)
Liked: 1503
It's very easy. You'll want to ask questions in the DIY Sub section.
OEM subwoofers are weak and expensive, which is a bad combination.
With a budget of $1000, DIY subs tend to be 4 times louder, play 25% deeper, and usually higher SQ too by comparison.
BassThatHz is offline
post #7 of 18 Old 07-21-2014, 12:03 AM
derrickdj1's Avatar
Quoted: 812 Post(s)
Liked: 550
Most likely the PSA and RA sub will not fit the bill as a single sub. DIY is a great recommendation. If this is the final piece for the HT setup, don't undersize the wooferage. A Danley sub is a consideration or a couple of large Marty cubes.
derrickdj1 is offline
post #8 of 18 Old 07-21-2014, 12:13 AM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
You have a sub with an 8-inch driver that retailed for $200 that manages to pressurize an enormous space? My recommendation is to make sure you never get to hear a buddy's setup with a more capable sub. I'd also stop reading on this forum. Seriously, there's a lot to be said for staying off the hedonic treadmill--if you're happy with what you have, keep it up and spend your money in less frivolous ways than some of us on here do.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #9 of 18 Old 07-21-2014, 12:22 AM - Thread Starter
Liked: 0
I guess I am just concerned with the level of technical difficulty involved since I have no experience and very few tools at home to fabricate a box. If there is a sub building "for dummies" guideline it sounds like it would be worth the extra effort to have a better product in the end.
post #10 of 18 Old 07-21-2014, 12:46 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1348
If you can DIY, that would be your best bet. For a beginner, I would be looking at a martycube flat pack or a Stonehenge flat pack. Add in a SI18 or maybe a Dayton Ultimax 18 when it comes out, and a Behringer iNuke amp, and you will have a serious subwoofer. If that doesn't appeal to you, for $1k I would look at a Hsu VTF15h or Reaction.
shadyJ is offline
post #11 of 18 Old 07-21-2014, 12:53 AM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
If you don't go DIY, I predict that after substantial research you'll push your budget up a bit and go for a Rythmik FV15HP. I say that because that's what I ended up doing, and I don't think I'm alone there, this sub seems to be the current AVS darling in the $1-$2K price range. Which is not to say that there aren't lots of other good choices out there (and unlike many others on here, I have no experience with most of the alternatives).
Rythmik FV15HP sub
niccolo is offline
post #12 of 18 Old 07-21-2014, 04:09 PM
derrickdj1's Avatar
Quoted: 812 Post(s)
Liked: 550
a
Parts Express has step by step videos for building their subs. No saws or cutting, just glue and clamps. Last step is paint!
post #13 of 18 Old 07-21-2014, 04:29 PM
dsrussell's Avatar
Liked: 2954
The FV15HP is a great sub. No one would ever say otherwise. I don't think Rythmik makes anything but great subs. However, at a price of around $1340 (black matt or black oak) and $1560 (piano black), not including shipping, puts it well above the O.P's $1,000 window. With either the PSA and RA the O.P. is at $900 including shipping, leaving him comfortably under that window, and both should come reasonably close in output to the Rythmik. And if the O.P. thinks he may need a second sub in that huge room, the price for duals is not that far above a single FV15HP @ $1700 shipped (with discounts on the second sub). Hard to go wrong with any of the ones mentioned.
post #14 of 18 Old 07-21-2014, 11:00 PM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
I don't disagree, especially since the OP mentioned rarely listening to music. And kudos for taking the stated budget seriously--I came on here with a $5-600 budget and ended up getting talked into an FV15HP. Not that I'm unhappy with that decision...
Rythmik FV15HP sub
niccolo is offline
post #15 of 18 Old 07-21-2014, 11:06 PM
dsrussell's Avatar
Liked: 2954
^^ LOL! Ain't that the way it goes around here? I bet it was the best tripling (or close to tripling) of your budget that you could imagine. Congratulations on a terrific sub!
niccolo likes this.
post #16 of 18 Old 07-23-2014, 11:27 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 2670 Post(s)
Liked: 2462
Why not get an SVS PC12 NSD cylinder sub? I have a 7 year old less powerful version - the 20 - 39 PCI sub, and it can produce incredible bass in my 3500 cubic foot theater. AV Science sells them, or go to SVS directly if you prefer. Well under $ 1000.00 too. A PC12 Plus would be even better, but they are over $ 1K.
I love my cylinder sub !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #17 of 18 Old 07-23-2014, 01:18 PM
tvuong's Avatar
Quoted: 1487 Post(s)
Liked: 831
Someone came here asking about buying a $100 Polk PSW10 and ended up with an FV15hp.
niccolo likes this.
tvuong is online now
post #18 of 18 Old 07-23-2014, 02:20 PM
JT78681's Avatar
Quoted: 1290 Post(s)
Liked: 813
Typical around these parts.
JT78681 is offline
