Sub recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-20-2014, 11:11 PM - Thread Starter
Quoted: 43 Post(s)
Liked: 2
Sub recommendations
How's it going gentlemen? Just signed up my membership, seems to be too much great knowledge on here not to become one. Hope my assumption is correct.
I completed my initial 5 channel setup. Have the Pioneer Andrew Jones speakers (which the towers & book shelf speakers are some of the most impressive 'bang for your buck' quality purchases I've ever encountered that was available to the masses) and either going to sell all but the towers & books when the Atmos line is ready to ship.
Purchased the Polk Audio 100 watt 10' sub. Wanted to purchase the 200 watt Polk but it is out of stock for a few days. Finding it harder to trust the reviews of any websites. What would you guys recommend that's under 300$. Also, what frequency should I set it to, & I should keep the low pass filter on my receiver off correct?
TomFord is offline
post #2 of 6 Old 07-21-2014, 02:56 AM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 143
Hi, welcome to the forums! In the $300 price range, the NXG BAS-500 is probably the most recommended.
http://www.amazon.com/gp/aw/d/B008FS...&robot_redir=1
Jim Wilson's review:
http://www.hometheatershack.com/foru...er-review.html
Gmash is offline
post #3 of 6 Old 07-21-2014, 04:07 AM
Quoted: 75 Post(s)
Liked: 113
^^ What he said.
rnatalli is offline
post #4 of 6 Old 07-21-2014, 11:42 PM - Thread Starter
Quoted: 43 Post(s)
Liked: 2
Originally Posted by rnatalli View Post
^^ What he said.
Thanks guys. What makes it better than the 200 watt Polk? Simply more wattage? Try not to put much stock into the watts sometimes from the numbers being meaningless in my past experience (which is mainly car audio)
Just saw the review the 1st member attached, maybe that will answer it
TomFord is offline
post #5 of 6 Old 07-22-2014, 06:58 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
The only Polk subs I would consider are the DSW series when you can get them on sale. There have been reports of a few scoring the DSW660 for 300.00 or less and that would probably rival the NXG.
To answer your question about what makes a sub better. Well for starters the cheaper polk subs are using a fairly inexpensive driver. They also are tuned higher(35-40hz?) and probably will introduce some phase shift around the port tune. Also distortion is probably rather high. The NXG is tuned fairly deep and utilizes a decent driver. I would expect it to do a much better job with movies due to the better extension and sound better with music since the port tune is deep enough that it has no emphasis on the bass in the frequency range where most music bass resides. That means the NXG should blend better with the mains and sound tighter.
basshead81 is offline
post #6 of 6 Old 07-22-2014, 07:25 AM - Thread Starter
Quoted: 43 Post(s)
Liked: 2
Thanks 81, that really helps a lot
TomFord is offline
