AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Subwoofers, Bass, and Transducers (http://www.avsforum.com/forum/113-subwoofers-bass-transducers/)
-   -   Any point in having floor standing speakers if also using a subwoofer? (http://www.avsforum.com/forum/113-subwoofers-bass-transducers/1612089-any-point-having-floor-standing-speakers-if-also-using-subwoofer.html)
Fjodor2000 07-21-2014 03:06 PM
Hi,
I just wonder if there is any point in having floorstanding speakers in a home theater system if they are also combined with a subwoofer (compared to using e.g. bookshelf or satellite speakers instead of the floorstanding speakers)?
If the system is configured so that the subwoofer will handle all frequencies below 60/80 Hz and the bookshelf speaker is able to play down to 60/80 Hz, what's the point in having floorstanding speakers that can play lower frequencies than that? Because anything below 60/80 Hz will be handled by the subwoofer anyway.
Would anyone please care to elaborate and perhaps share some experiences?
fatbottom 07-21-2014 03:08 PM
Yes.
JHAz 07-21-2014 03:21 PM
Originally Posted by Fjodor2000 (Post 25927521)
Hi,
Strictly imo it only makes a sonic difference if the stand mounted speakers compress in the lows at your loudest peak lisrening levels (or below). Seems possible that a speaker that's flat to 80 Hz with typical content at a loudish 85 dB might be a little bass shy at 100 or 105 dB.
Also it has seemed to me that at least some floorstanders sound different from their stand mmounted siblings likely because of different drivers or driver alignments covering the critical 1KHzish band. Which means its all different. Likely favors the smaller speakers.
Right now I am relatively bucks shy or I would have floorstanders simply because I prefer the appearance and like the sound of the floorstanders I would get
derrickdj1 07-21-2014 04:48 PM
Floor standing speakers can add to the sound stage for the HT. By the time you by stands, the cost may be pretty close and they take up the same amount of floor space. It all comes down to personal choice and the aesthetic that you want for your system and room.
Kini62 07-21-2014 04:53 PM
I currently run my floorstanders full range, even with two subs running.
I find that it fills in the front sound stage. Especially at low to mid volumes.
Bill Fitzmaurice 07-21-2014 05:40 PM
Not really, but you'll get as many responses in favor of them one as you do otherwise, with 99.9% of respondents basing their answer on what they use rather than any objective considerations.
Fjodor2000 07-22-2014 02:08 AM
Thanks for all the feedback. Just wondering, is there anyone who has tried both setups (i.e. subwoofer combined with floor standing vs bookshelf speakers), and can share some experiences on the differences that were noticed, if any?
fatbottom 07-22-2014 03:29 AM
I have both standmounts and floorstanders, two systems, both have subs. The towers allow me to run pure direct, full range, with no subwoofer. So ideal for music.
It depends on the room, speaker type, what system it is, whether you have bass management or not.
ie, floorstanders in a small room, in a dedicated pure 2 channel hifi isn't a good idea- can't tailer bass to suit.
standmounts in a large room with no sub woofer isn't a good idea- not enough low bass range.
Skytrooper 07-22-2014 06:02 AM
Posted this before. Borrowed my brothers Paradigm 60's. I have the 20's (bookshelves) I preferred the floor standers. My brother couldn't wait to get his 60's back. Both models use the same drivers.
KidHorn 07-22-2014 06:22 AM
It really depends on the specific speakers. If you look a specific speaker lineup and compare the floorstander to the comparable bookshelf that uses the same midrange and tweeter, the bookshelf may or may not sound the same as the floorstander crossed over at the cutoff for the bookshelf. The again, it may sound pretty much the same. If they sound the same, then you likely won't gain anything getting the floorstander over the bookshelf assuming your subs can adequately handle the low end.
I've heard enough systems where the floorstanders sounded much better than the bookshelf and vice versa to make any general statements. The same is true for center channels.
wwinkler 07-24-2014 05:58 AM
In almost all situations, I think you can go with bookshelves if you have good subwoofers.
I have two ~7 cubic foot ported 15" subwoofers in a small AV room. When I replaced my 15+ year-old floorstanders, I used bookshelves.
PM-Performance 07-24-2014 06:42 AM
132 Attachment(s)
Do you just mean not really over bookshelves, or not really even over satellites?
VinhT 07-24-2014 07:10 AM
The advantage of floor standing speakers over their bookshelf counterparts is not bass extension, but rather, dynamic capability. If bookshelves are all you can do, then that's fine. Otherwise, the floorstanders are preferred if possible.
Bill Fitzmaurice 07-24-2014 07:24 AM
Which would you say has greater 'dynamic capability', a floor standing Klipsch RF-82 II or a stand/shelf mounted JTR Triple 8? The answer to that question reveals the inherent fallacy of making a speaker choice based on whether it sits on the floor or on a stand/shelf. ;)
VinhT 07-24-2014 07:28 AM
You got me there! I was thinking more within the same product line.
Kini62 07-24-2014 04:47 PM
The JTR triple 8 is also a speaker that is not what people consider a "bookshelf" speaker when bookshelf speakers are mentioned in threads like these.
89grand 07-25-2014 01:30 PM
I used to be a floor stander only person myself, but a few stand mount speakers had opened my eyes. I now use stand mount speakers in all three of my setups. Not only are they less expensive than the floor stander of the same product line because the cabinet is much smaller, but they also have stronger cabinets unless the floor standers are heavily braced, and most medium to lower priced towers are not. I also get just as much dynamics in my setup as I did with any floor stander. I also like being able to use stands that put the speakers at the exact height I want them rather than having to live with however tall the floor stander may be.
Case in point, I run JBL Studio 530's in my main setup, I paid $479 for them (a complete steal for this speaker by the way) and the next model up, the Studio 570 is twice the price, and it's only about 32" tall which is way too short in my opinion, so you'd still need to use some sort of stand between 10-12" or so which kind of defeats the purpose. Of course this is just one example, and the other towers in the line, while continuing to get more expensive, are taller and don't need stands.
Bill Fitzmaurice 07-25-2014 02:40 PM
Originally Posted by 89grand (Post 26039474)
Not only are they less expensive than the floor stander of the same product line...
That's one way to look at it, but the other is that by going bookshelf you can go to a higher product line for the same money.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
