3 Subs. $1200 Recommendation - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 55 Old 07-22-2014, 10:39 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 5
Wow. Okay, it looks like I've found my subs. I'll go with 2 LFM-1 EX subs. One for each room. Thanks guys.
kylbarnes is offline
post #32 of 55 Old 07-23-2014, 05:45 AM
JimWilson's Avatar
Quoted: 1567 Post(s)
Liked: 2098
If you're willing to spend the entire sum on a pair of subs now then the Outlaw's are the way to go. I have heard one of those myself, and for the current sale price it will be very hard to beat.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #33 of 55 Old 07-23-2014, 05:46 AM
JT78681's Avatar
Quoted: 1483 Post(s)
Liked: 1006
The Outlaw LFM-1 EX is a beast. I used to have one and it definitely dug deep and packed a punch. I love the tops on them. I had it in between two couches and it served quite well as an end table with that plexiglass top. The sale needs to hurry up and end, so that I don't end up purchasing another for my other room.
JT78681 is offline
post #34 of 55 Old 07-23-2014, 09:38 AM
PM-Performance's Avatar
Quoted: 255 Post(s)
Liked: 146
Have you considered DIY? I was looking for another SVS the other week for a bigger room and someone mentioned DIY to me. I now have bought 2 18" drivers, a 3000 watt pro amp with DSP, 4 bassshakers and 250w amp for those too for less than what just dual subs would cost me. (about $900 soo far and "should" yeild some pretty rediculous output along with added tactile response from the shakers. Shakers out of the equation and it was under $600)
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
post #35 of 55 Old 07-23-2014, 11:00 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 5
I thought about it. But I don't trust myself enough to build my own.
post #36 of 55 Old 07-23-2014, 11:09 AM
Quoted: 255 Post(s)
Liked: 146
Niether do I, I am convincing a friend to build my boxes for me. Otherwise, the rest is fairly straight forward
post #37 of 55 Old 07-23-2014, 02:49 PM
Rowan611's Avatar
Quoted: 393 Post(s)
Liked: 463
It's not that hard. Plus, if you buy a flatpack from diysoundgroup, all that's required is building it per the instructions. Or, look into a full Marty or mini Marty. Just gotta assemble it - that's where you'll get the most bang for your buck.
HT: Marantz 7702mkII | Crown Amps | 1299 L/C/R | Volt 8s | THTs | 1200Ds | Panamax 5300PM | LG OLED 65B6P | Oppo UHD-203 | PS4 |
Family: Pioneer SP-SB23W | Pioneer Kuro Elite 111 | X1
Rowan611 is offline
post #38 of 55 Old 07-23-2014, 03:36 PM
Quoted: 255 Post(s)
Liked: 146
Plus over 4000 cubic ft and 2 12's may be pushing it unless on subflooring.
This is why I am switching up now too
post #39 of 55 Old 07-23-2014, 04:17 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 5
I put in my order today for 2 LFM-1 EX subs. Can't wait for them to arrive!
post #40 of 55 Old 07-23-2014, 06:08 PM
JT78681's Avatar
Liked: 1006
Well done!
JT78681 is offline
post #41 of 55 Old 07-23-2014, 06:45 PM
Rowan611's Avatar
Quoted: 393 Post(s)
Liked: 463
Nice! I'm sure you'll enjoy them.
Rowan611 is offline
post #42 of 55 Old 08-01-2014, 12:22 PM
K5/SS's Avatar
Quoted: 71 Post(s)
Liked: 128
Any updates?
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
K5/SS is offline
post #43 of 55 Old 08-01-2014, 02:21 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 5
Originally Posted by K5/SS View Post
Any updates?
I got both LFM-1 EX's on Tuesday. So far, I've only tested 1 sub downstairs in my living room. So far, it's pretty good. It doesn't quite have the "shake the whole room" I was hoping for out of 1 sub. But it could be because it's only 1 sub, it isn't broken in yet, or that it's a down firing sub hitting somewhat thick carpet with minimum clearance. This weekend I'm going to try both subs in both rooms at full blast, and see if I get that full rumble I'm hoping for.
I'll post an update this weekend with how it sounds with both subs active.
post #44 of 55 Old 08-01-2014, 02:26 PM
Kini62's Avatar
Quoted: 1748 Post(s)
Liked: 1559
Your rooms are just too large to get the "shake the whole room" experience out of a single mid priced sub. Rooms that large need a lot of power. Down firing has no affect, carpet either.
Put both subs in one room and see how that goes.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #45 of 55 Old 08-01-2014, 02:37 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
A couple bits of advice for more room shaking: run the sub in 2 ports open mode. Make sure the mode switch is set to '2 ports open' on the amp plate. This will give you more punch in the 20 to 40 Hz range, although at the cost of a bit of extension. Next thing, run the subs hotter than whatever your AVR set it to in the calibration routine. Many times Audyssey or whatever room correction calibration the AVR has will set the sub to a 'meh' level of output. Run the calibration, and afterward raise the subwoofer channel output by, maybe, 5 dB, or whatever it takes to rock you. Don't tun the sub extremely when its set to one port mode though. It's OK to beat on it when it's in 2 port mode. One more thing, try different placements for the subs if you can. Placement makes a huge difference in bass sound.
Tdekany likes this.
shadyJ is offline
post #46 of 55 Old 08-01-2014, 02:40 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 5
Yup, that's the plan. Is there a recommended Blu-Ray that has the best Bass? I was trying the Dark Knight movie as my source. Maybe Transformers? Something else? I want to piss off my neighbors this weekend with my test.
post #47 of 55 Old 08-01-2014, 02:55 PM
Kini62's Avatar
Liked: 1559
Either of those movies are pretty good for bass.
There are also quite a few youtube videos that you can use to test your subs.
Take shady's advice on the setup.
Def Tech SC8000
Kini62 is offline
post #48 of 55 Old 08-01-2014, 03:01 PM
JimWilson's Avatar
Liked: 2098
For a raucous bass-fest also consider Battle: Los Angeles.
post #49 of 55 Old 08-01-2014, 09:34 PM
Quoted: 255 Post(s)
Liked: 146
Other good ones are tron legacy and Enders game. Pretty ridiculous lfe
post #50 of 55 Old 08-02-2014, 07:55 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
+1
Might as well see if the two together will achieve what you want in the living room.
For movies to try to test your sub, four to five star movies on this list are generally great
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #51 of 55 Old 08-03-2014, 11:48 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 5
Latest update. I tried both subs in both rooms this weekend, and tested a few Blu-Ray's. I also took Shady's advice and ran Audyssey, both ports open, and jacked up the sub calibration by a few dB. Big improvement from before. I became especially happy when I could hear the stuff on my walls rattling throughout the room. I think the sound quality of the subs are great, and when you throw two in the mix, it will definitely give you that boom effect you want out of a home theater.
The only downside is that I now have to split up my subs, and throw one in each room. I'll probably save up for another sub in six months or so, and then move them both upstairs and run the new one downstairs.
Altogether, I have nothing but nice things to say about the LFM-1 EX.
post #52 of 55 Old 08-03-2014, 11:55 PM
cel4145's Avatar
Liked: 3002
They usually put the EX on sale sometime between Black Friday and the end of the first few weeks of December. So subscribe to their mailing list then and watch for sales
cel4145 is offline
post #53 of 55 Old 08-04-2014, 03:31 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 5
I know what I'm getting myself for the holidays.
post #54 of 55 Old 08-07-2014, 12:31 AM
MIX_MASTER_ICE's Avatar
Quoted: 1427 Post(s)
Liked: 1204
The Outlaw subs are nice. I got the LFM-1 Plus on sale for $500. It will produce some port noise when pushed, which made me wonder if this would only be exacerbated with the EX. The two subs share the same amp, driver and most importantly, the same dual 3" ports. The EX is in a larger cabinet and puts out more dB's and lower extension, but with the same size ports. Wouldn't that make the chuffing worse, especially in max extension (1 port plugged)? Forgive me if I'm way off on this, as I'm very much a novice in regards to these subs.
MIX_MASTER_ICE is offline
post #55 of 55 Old 08-07-2014, 06:32 PM
Tdekany's Avatar
Have you tried 1 sub near field? Could make a difference, until you can purchase one more.
Tdekany is offline
