Supercube 2 replacement - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By pony9134
  • 1 Post By jwtallguy
post #1 of 26 Old 07-24-2014, 08:40 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
Will the SVS PC12-NSD be a good replacement for a DefTech Supercube 2? My wife has given me the OK to get a replacement and the PC12 ergonomics are perfect for where I want to put it. I'm just not sure if it will sound better.
Sharp Elite Pro 60
Pioneer Elite VSX-52 Receiver
Pioneer Elite  BDP-62FD BluRay
XBRSteve is offline
post #2 of 26 Old 07-24-2014, 08:50 PM
pony9134's Avatar
Quoted: 66 Post(s)
Liked: 69
With svs having a no hassle return. order a couple different ones and send the ones you dont want back. Im sure that it will out do the def tech.
XBRSteve likes this.
pony9134 is offline
post #3 of 26 Old 07-24-2014, 09:03 PM
Kini62's Avatar
Quoted: 1410 Post(s)
Liked: 1293
I have sc8000 (not sure if it's the replacement for the 2). 11" driver etc.
I have the pc12 plus. The plus is a much better sub all around. Output, sound quality, extension and the like.
That said having recently added the sc into the mix has made a noticeable improvement.
The pc12 will extend deeper and higher. Should sound better and have about the same output above 20-25hz.
Kini62 is offline
post #4 of 26 Old 07-24-2014, 10:20 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
Thanks. I need to find a way to swing a Plus
Sharp Elite Pro 60
XBRSteve is offline
post #5 of 26 Old 07-25-2014, 11:17 AM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
The finance department put the Kibosh on the PC 12 Plus so I ordered the PC12 NSD. Should receive it sometime next week.
Sharp Elite Pro 60
XBRSteve is offline
post #6 of 26 Old 07-25-2014, 11:58 AM
Kini62's Avatar
Liked: 1293
Congrats. I'm sure you'll like it.
Are you keeping the deftech?
Dual subs really do make a difference even if they are quite different.
Kini62 is offline
post #7 of 26 Old 07-25-2014, 04:52 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
I would love to but probably not. The room is fairly small and I only have one corner to place a sub and I don't think putting them side by side will do well. The wife probably will not go for it anyway but before I sell it I will try it out.
Sharp Elite Pro 60
XBRSteve is offline
post #8 of 26 Old 07-25-2014, 04:56 PM
FattyMcButterPants's Avatar
Quoted: 875 Post(s)
Liked: 813
You don't mess around do you? That was quick!
FattyMcButterPants is offline
post #9 of 26 Old 07-25-2014, 05:25 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
Free returns if I don't like it not much to lose and I hear great things about SVS.
Sharp Elite Pro 60
XBRSteve is offline
post #10 of 26 Old 07-25-2014, 06:02 PM
Quoted: 875 Post(s)
Liked: 813
SVS is awesome, I have bought many items from them, including a pb12-nsd. These are great subs, I think you will be very happy, congrats on the purchase!
post #11 of 26 Old 07-31-2014, 03:09 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
Got it today. Initial thoughts is it gets lower than the supercube 2. I pretty much did a plug and play no tweaking yet but it does not seem to hit as hard as the SC2. I'm guessing that the higher bass frequencies of the sc2 are more prominent. I will run the calibration in the receiver and tweak some more.
Sharp Elite Pro 60
XBRSteve is offline
post #12 of 26 Old 07-31-2014, 04:11 PM
Tom Vodhanel's Avatar
Quoted: 1562 Post(s)
Liked: 4467
The SC 2 and SC4000 are similar models. You can see the measurements for the 4000 here
http://www.soundandvision.com/conten...-labs-measures
http://www.soundandvision.com/conten...-speaker-and-1
Basically the SC2/4000 does well in the mid and upper bass(40hz and up) but they start to really struggle <35hz and by 30hz they look to have a SHARP rolloff.
A sub like the svs is going to provide much deeper extension and output in the 15-35hz range. This is often interpreted as "less punch" because RELATIVE to the upper bass output....the svs will maintain a good sense of linearity.
When you say "hit as hard" is this will music demos mostly? I'm thinking if you popped in say...War of the Worlds....you might *feel* differently..
Tom V.
Power Sound Audio
Tom Vodhanel is offline
post #13 of 26 Old 07-31-2014, 08:16 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
Tom V.
Power Sound Audio
Maybe hit hard is the wrong word "punch" is more accurate. As you stated it is the upper bass range that I am missing. After running calibration it does sound better but I am not sure I am satisfied. The PC12 PLUS has a +/-3db point all the way to 250Hz where the NSD is at 130Hz. I think I may have to return this one and bite the bullet and get the Plus.
Sharp Elite Pro 60
XBRSteve is offline
post #14 of 26 Old 08-01-2014, 09:30 AM
Liked: 4467
I'm not sure if that will really help. I'm assuming you are using a typical 5.1 system with an AVR and 5 speakers that you have set to 80hz? If so, the upper frequency extension of 130hz should be plenty.
If you have some way of EQing the bass signal you can try bumping up the 50-80hz range a bit.
Be sure you have the crossover on the sub set to its highest setting/bypassed. Also, experiment with the sub distance setting and/or phase setting.
Tom V.
Power Sound Audio
post #15 of 26 Old 08-01-2014, 10:26 AM
Kini62's Avatar
Liked: 1293
The SC models fall off pretty fast after about 90-100hz. They have a pronounced "hump" in the mid bass range say 40-70hz or thereabouts.
The PC12 is flat throughout as are most good subs so you don't notice the mid bass as much. One of the benefits of the Plus and Ultra is the three band PEQ that allows you to put some of the "hump" back in if that's what you like.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #16 of 26 Old 08-01-2014, 10:47 AM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
Yes. I spoke with SVS and that is more or less what they stated. What I am missing in the PC12-NSD is somewhere in the range of 60-80Hz. The PLUS (and Ultra) performs better in that range than the NSD. I ordered the Plus this morning (wait till the wife sees the CC charge) and will return the NSD.
Sharp Elite Pro 60
XBRSteve is offline
post #17 of 26 Old 08-01-2014, 11:11 AM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
The pc12+ is in a different league vs the pc12-nsd, especially with regards to music playback, at 30hz and up its 6-10 db more output
jwtallguy is offline
post #18 of 26 Old 08-01-2014, 02:01 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
I hope you are right
Sharp Elite Pro 60
XBRSteve is offline
post #19 of 26 Old 08-01-2014, 02:07 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
I have 2 pc12+s in my room and they get so loud I cant stand it for to long if im just testing them out for someone, at 40 hertz im pegging my spl meter at 128 dbc, if that isnt loud enough nothing will be, even with 1 I was at 121-123, without eq its well into the 130s from my room mode peak
post #20 of 26 Old 08-01-2014, 02:08 PM
Liked: 4467
The pc12nsd should have more output capability than the super2/4000 even in the mid and upper bass.(at least up to 80hz). So I don't think it is a question of having more headroom. More likely, you are used the shape of the DT frequency response.
Tom V.
Power Sound Audio
post #21 of 26 Old 08-01-2014, 02:12 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
Wow 128dB! Yeah couldn't listen to that for long either.
Sharp Elite Pro 60
XBRSteve is offline
post #22 of 26 Old 08-01-2014, 02:50 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
As Tom stated you are probably use to hearing a large hump in the frequency response and if that is the case the max output of any flat response subwoofer wont change that but also not all subs react the same in the same spot in a room. Spending a little money on a spl meter or mic for REW will give you a better idea of what you're hearing
post #23 of 26 Old 08-08-2014, 08:54 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
Recieved the PC12 Plus today and wow what a beast! Very satisfied thanks for the suggestions.
Sharp Elite Pro 60
XBRSteve is offline
post #24 of 26 Old 08-08-2014, 09:57 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
Congrats, lets us know how its going with the upgrade and your impression of it
post #25 of 26 Old 08-09-2014, 03:25 PM - Thread Starter
XBRSteve's Avatar
Quoted: 12 Post(s)
The frequency range and output are much better. The low end is amazing, watch Oblivion around the 19:00 mark when the rope breaks... Impressive! Battle Los Angeles never sounded so good. Still making some minor adjustments but so far very impressed.
Only down side it is big! Doesn't take much floor space but it is nearly as tall as my 5' wife....
At least she is not complaining about the size only about the walls shaking...
XBRSteve is offline
post #26 of 26 Old 08-09-2014, 06:45 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
Great to hear that, next up is duals!!!
