what would you all recommend me to get for my car? subwoofer and amp for under $600 t - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By its phillip
  • 1 Post By basshead81
  • 1 Post By zeus33
  • 1 Post By Archaea
post #1 of 17 Old 07-29-2014, 12:16 PM - Thread Starter
Liked: 0
Hi all this is my first post. I know this question has been asked many times but I wwant to know the CURRENT best set up I can get.
In reality I don't want to spend more than $500 total but Will go to $600 if necessary. I'm not looking to be in the world class side of things, I just want a really nice hard hitting system. Personally I prefer low to mid bass subwoofers. Doesn't everybody? .
I have only had one system in my life and it consisted of two 12" memphis subs. Whatever the lower end ones are called? They were 250 watts rms a piece and I had a 500 watt rockford Fosgate mono amplifier.
I have a 1984 Nissan 300z and it's a hatchback so it carried the sound very well. What's your guys's opinions on what to get? I was looking at either dual 12" subs or a single 15" sub possibly. I don't want a 10" sub however.
Please let me know what your opinions are on this so $600 MAX for the sub and amp together. I have a head unit and wiring. Also I will make my own box.
Thanks all in advance have a great day everyone
bman13spang is offline
post #2 of 17 Old 07-29-2014, 12:40 PM
its phillip's Avatar
Quoted: 62 Post(s)
Liked: 115
its phillip is online now
post #3 of 17 Old 07-29-2014, 12:54 PM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 899
Awkward...............
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #4 of 17 Old 07-29-2014, 03:29 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Go to www.polkdirect.com
Get the PA600.1 amp and (2) MM 1240 subs = 485.00
That leaves you enough money for a enclosure and wiring kit.
I have a pair of MM840's with a PA400.1 in my Yukon and they will pump out a clean 124-126db. I went with 8's so I could hide them in the stock locations without taking up any cargo space.
basshead81 is offline
post #5 of 17 Old 07-29-2014, 07:56 PM - Thread Starter
Liked: 0
Thanks for the reply. That link doesn't work unfortunately. Isnt Polk a cheapy brand though? Or am I wrong?
This is what I had before.
http://www.memphiscaraudio.com/products/subwoofers/power-reference-subwoofers/15pr12d4v2/
post #6 of 17 Old 07-29-2014, 09:11 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
there MM drivers are pretty solid.
http://stores.ebay.com/Polk-Audio-Direct
http://www.polkaudio.com/products/mm1240
The MM1240 - 425watts rms, 92db efficiency.
The Memphis 124d2- 250 watts rms, 86db efficiency.
Another option which is probably better then both is the Dayton Ultimax.
http://www.parts-express.com/dayton-...-coil--295-512
I would of went with these but they do not make a 8".
bman13spang likes this.
post #7 of 17 Old 07-30-2014, 10:59 AM
zeus33's Avatar
Quoted: 1329 Post(s)
Liked: 986
Originally Posted by bman13spang View Post
Thanks for the reply. That link doesn't work unfortunately./
zeus33 is online now
post #8 of 17 Old 07-31-2014, 10:59 AM - Thread Starter
Liked: 0
Nice! Okay, I'm going to check those out. That's awesome that it isn't even $500 for everything. I rolled my car 3 times and it landed in a river awhile back and my amp and subs got demolished to bits and pieces. Lucky I made it though !
post #9 of 17 Old 07-31-2014, 11:02 AM - Thread Starter
Liked: 0
Originally Posted by zeus33 View Post
If I got two of these like basshead said MM1240 what would be my better option? Getting two of these 12 ' s or something by the same brand/ same rms wattage in a single 15? I have only heard two 12 ' s which is what I had and liked them but would it be better sounding getting a single 15 or what?
post #10 of 17 Old 07-31-2014, 12:49 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
If it were me, I would hop on this deal a forum member just found.
http://m.ebay.com/itm?itemId=111423003878
These are normally 300.00 drivers. Very high quality!!
post #11 of 17 Old 07-31-2014, 12:53 PM
Archaea's Avatar
Quoted: 2841 Post(s)
Liked: 2420
Ah man I miss my old infinity kappa perfect 10.1s in my Acura hatchback. Those were fun!
Archaea is online now
post #12 of 17 Old 08-01-2014, 11:27 AM
zeus33's Avatar
Liked: 986
Nice deal, but this concerns me:
Sold as is, no warranty.
post #13 of 17 Old 08-01-2014, 12:13 PM
zeus33's Avatar
Liked: 986
A post I found on another site. I'm not sure if it's correct. One of the members here can check the math:
Well lets see. lets say both the 2 12" subs and the 1 15" sub have a flat piston. and that the diameter of usable surface area is truely 12" diameter and 15" diameter.
A=Pi R^2
A=3.14*6^2
A=3.14*36
A=~113 sqin.
2 12's=226 sqin.
A=3.14*7.5^2
A=3.14*56.25
A=~176.5
in order to gain 1dB with the same ammount of excursion the surface area must be increased by 33% (in a sealed and IB aplication. ported is another story)
226-176.5=49.5
49.5/226=x/100
x= ~22%
the difference is very slim to none as far as your ears are concerned. and any phase change between the 2 12's will cause cancelation.
but this is with all other things being the same. basically look at over all displacement of the woofers at full excursion and wether or not they can reach full excursion with you given power input. i would go with a single 15 but others would say 2 12's for cosmetic or power handleing reasons.
post #14 of 17 Old 08-01-2014, 01:53 PM - Thread Starter
Liked: 0
That's an amazing deal! I just put that on my watch list lol. It sounds almost too good to be true but who knows. I sent them a message asking if it works for sure. If so, I'm probably going to go with that. I could always get another 12 later I suppose
DUHHH... never mind. I just realized that sub is a 15
post #15 of 17 Old 08-01-2014, 01:53 PM - Thread Starter
Liked: 0
That's true, I just sent them a message and hopefully they message back soon.
post #16 of 17 Old 08-01-2014, 01:58 PM - Thread Starter
Liked: 0
A=Pi R^2
A=3.14*6^2
A=3.14*36
A=~113 sqin.
2 12's=226 sqin.
A=3.14*7.5^2
A=3.14*56.25
A=~176.5
226-176.5=49.5
49.5/226=x/100
x= ~22%
Nice man, thanks for the information! I think* I will get 2 12 ' s or just maybe one for now ( if that ebay sub posted above turns out for the better ). I was really happy with my memphis 12'S I had in the past and they were only 250 watts. I mean, of course they could have been better, but they were waaaaay better than anything stock. Lol. I have never heard a 15 in my life but with the information you provided , it doesn't seem like there will be much of a difference if any. I have read on previous forums that 15's provide a little deeper bass since they are bigger. Is that right ? I mean, it would make sense since they have more surface area .
DUHHHH... that sub is a 15. I thought it was a 12
post #17 of 17 Old 08-01-2014, 02:38 PM - Thread Starter
Liked: 0
Sorry for all the questions guys but you are all so helpful and I can't thank you all enough for all of your time and effort in helping me get a good system going, so thanks .
What do you all think about this amp? http://kicker.shptron.com/p/cx6001?pp=12
Kicker cx600 mono class d amplifier.
With my memphis subs, I had a rockford 250 watt mono amp that I started with and it was pretty good. But obviously something went wrong and it was fried and was not fixable.
I then got a 250 watt mono kicker amp and used it and it sounded waaaay better. Much more clear sound and was waaaay louder as well. Even though it was the same wattage.
So do you guys think this would go well with the LAB 15 listed above? I mean, It sounds like a perfect match and I have had good experience in the past with only my 250 watt kicker amp. And this one is 600 watts rms and 1200 peak so it matches with the subwoofer
