Would you spend a mere $200 for the best bass you've ever had? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 07-31-2014, 07:39 PM
Liked: 0
yep,think so,many that have not already done so, will be dismayed, once they do measurements, by how much their room effects frequency response. I will go further and say even the best subwoofers cannot over come[IMG]http://*******/prvoPz[/IMG] the rooms response unless they too include a measurement mic and DSP.
ltionsipow is offline
Old 07-31-2014, 09:37 PM
|Tch0rT|'s Avatar
Quoted: 183 Post(s)
Liked: 128
Originally Posted by 89grand View Post
I was on there from maybe I don't know, 2006 or so, and quit being active around 2009 or there about as I shifted towards home audio. Ant...LOL!
I don't drive like I used to so car audio is a waste of time and money now. That forum used to be so great when npdang ran it but went to poop after Ant bought it.
89grand likes this.
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
Old 07-31-2014, 09:49 PM - Thread Starter
89grand's Avatar
Quoted: 288 Post(s)
Liked: 163
I agree. I learned a lot on that forum early on.
|Tch0rT| likes this.
89grand is offline
Old 08-01-2014, 11:16 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Originally Posted by primetimeguy View Post
This is incorrect information. All but the extreme lowest end of Audyssey versions EQ the sub (2EQ). The highest version, MultEQ XT32, does it extremely well but MultEQ and MultEQ XT also EQ the sub. Audyssey SubEQ simply sets distance and level for two subs independently, that is all.
It doesn't perform the EQ anything near what an external EQ does. Audyssey EQ is basically setting level and phase. It's not adequate.
Bassment is offline
Old 08-01-2014, 11:32 AM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
I think you are confusing a couple things or haven't researched Audyssey enough to know. Your previous comments were incorrect and so are these. SubEQ sets level and phase for multiple subs, that is it. I agree, having EQ in the name for it is a bad thing. But MultEQ, MultEQ XT and MultEQ XT32 all EQ the subwoofer. SubEQ is an add-on only available on some receivers already with XT32. A previous poster listed the versions and capabilities above. Search around and you will found how good of a job XT32 does.
primetimeguy is online now
Old 08-01-2014, 11:54 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Can you link information? I've always read/heard that audyssey doesn't sub EQ properly except on the XT32 SubEQ ones. My MultEQ XT didn't do anything for my sub response.
Bassment is offline
Old 08-01-2014, 12:07 PM
Quoted: 556 Post(s)
Liked: 359
Someone already shared this but here it is again. Note the specifics on the subwoofer filter resolution.
http://www.audyssey.com/technologies/multeq/flavors
You can read a bit about SubEQ here
https://audyssey.zendesk.com/entries...vs-MultEQ-XT32
I have had versions MultEQ, MultEQ XT and now XT32 and have seen corrections in the subwoofer in all versions. Obviously much better correction in XT32.
Just did a quick Google search to find an image as an example
http://www.hometheatershack.com/foru...fore_after.jpg
Old 08-01-2014, 12:13 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is offline
Old 08-01-2014, 12:23 PM
Alan P's Avatar
Quoted: 4696 Post(s)
Liked: 3322
XT does a fine job with my response:
Red off, blue on:
primetimeguy likes this.
Alan P is offline
