Epik Phoenix amp not coming on? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-31-2014, 03:13 PM - Thread Starter
Liked: 0
Please understand I have just registered to avs and have searched the near 700 pages to come go a resolution. A few days ago I was still rocking and went to turn it on again only nothing.. Has anyone successfully repaired these amps or is an external the way to go? If so what options? Your input would be greatly appreciated..
David@TNT is offline
post #2 of 18 Old 07-31-2014, 03:58 PM
Alan P's Avatar
Quoted: 4707 Post(s)
Liked: 3335
Still under warranty? Have you contacted Epik? Checked the fuse(s)?
Alan P is online now
post #3 of 18 Old 07-31-2014, 04:10 PM
daveds50's Avatar
Quoted: 64 Post(s)
Liked: 38
Epik does not exist anymore...
daveds50 is offline
post #4 of 18 Old 07-31-2014, 04:13 PM
Alan P's Avatar
Liked: 3335
Oh...well then disregard my post.
post #5 of 18 Old 07-31-2014, 07:46 PM - Thread Starter
Liked: 0
Its all good, I appreciate any help.. I have been following avs for some time but mainly for research.
post #6 of 18 Old 07-31-2014, 08:12 PM
Bill Fitzmaurice's Avatar
Liked: 4708
Do a thread search for 'Epic'. The problems with their amps has become the stuff of legend.
Bill Fitzmaurice is online now
post #7 of 18 Old 07-31-2014, 08:28 PM - Thread Starter
Liked: 0
I guess I have been searching with the "epik" instead of the "epic" and I have heard the screams from the legend owners but from the pics its not the same amp they have.. I know you have all heard this before but I am trying to salvage this sub. If it went out while I was jamming or went up in smoke a repair would prob not be on my agenda. I would certainly be looking for a external amp, possibly a crown but its not going to happen any time soon. And I think we can all agree here that a movie or music just isnt the same with out the depth. Thanks again for the input and hoping to hear some optimistic results from a repair or replacement amp..
post #8 of 18 Old 07-31-2014, 10:12 PM
derrickdj1's Avatar
Quoted: 884 Post(s)
Liked: 596
Get an external amp and you will be good to go. This is cheaper and the amp will have a warranty. Berhinger I Nuke DSP amps will do the job with ease and grace.
derrickdj1 is online now
post #9 of 18 Old 08-01-2014, 06:20 AM
Liked: 4708
Originally Posted by David@TNT View Post
hoping to hear some optimistic results from...replacement amp..
Take your pick:
http://www.parts-express.com/cat/sub...amplifiers/332
post #10 of 18 Old 08-06-2014, 04:32 PM - Thread Starter
Liked: 0
Out of the options which would you go with?
post #11 of 18 Old 08-07-2014, 06:33 AM
KidHorn's Avatar
Quoted: 1380 Post(s)
Liked: 889
They had a bad batch of amps with their legends. Other than that, as far as I know, they haven't had any more problems than other vendors.
The Phoenix is an older model so the amp probably failed due to fatigue. Not because the amp was faulty.
KidHorn is offline
post #12 of 18 Old 08-07-2014, 06:40 AM
KidHorn's Avatar
Liked: 889
If you go with a plate amp, the most important thing is the amp fits in the hole. If the hole is too small, then you can cut a bigger hole, but if it's too big, you can't use it.
What you need to do is take out the existing amp and measure the hole. You need to get something that fits in the hole and once screwed in, completely covers the hole.
Other factors are amp power, whether you want dsp, an whether you want a boost at a certain frequency.
KidHorn is offline
post #13 of 18 Old 08-07-2014, 11:08 AM - Thread Starter
Liked: 0
I agree with this and to be honest I have run the heck out of it.. I know very basic audio so when you get into the roll off and db boost in the frequency range I get a bit lost. Daveds50 has been helping me and hopefully get it lined out for me. Thanks for all the input! Any suggestions are appreciated.
post #14 of 18 Old 08-08-2014, 07:50 AM
graphicguy's Avatar
As mentioned, the Phoenix was a generation before Epik's last batch of subs. They were robust. I had heard about what happened with the last batches of subs/amps, which was touch and go. Never a good sign for a small boutique manufacturer.
I've used PartsExpress for my AV!@# sub. So, I'd look at them for the Epik, too.
BTW....I have a Phoenix, too. It's been doing great. Still the most "kicking" sub I've heard in anyone's system.
Good luck.
Music so high you can't get over it....music so low you can't get under it!
graphicguy is offline
post #15 of 18 Old 08-08-2014, 04:11 PM
daveds50's Avatar
Quoted: 64 Post(s)
Liked: 38
i'm not sure about this. David's Phoenix amp is here, is fixed, and ready to come back. i also have a late model Legend amp here that is burned up due to a driver failing. the amps are identical, even down to the date codes on the transistors. that pretty much tells me that they came from the same batch. David's amp was actually in really good shape. some parts were replaced with new, but did not really need to be.
it is quite possible that the Legend drivers were a downgrade from the Phoenix... ( i do not know much about Epik's drivers ) after all, that is what caused Elemental Designs downfall. when a company gets into financial trouble, or finds a way to cut costs, sometimes quality suffers.
sometimes, it is the manufacturer of the product that downgrades parts without telling the customer. they will change parts to cut costs. this is not the case with the amps, but may be for the drivers. but i have seen this happen to many companies that i work with. that's the typical peril of dealing with an overseas manufacturer, and companies have to keep a close watch on this.
the problems here is, is that low quality drivers are often hard to detect... some of them appear to be quality. they look beefy and well made... yet, are not. some of eD's Philippines made drivers fit that description perfectly.
drivers do not last forever. and when using a low quality driver, one can expect a shorter life than usual... or in the case of some of the ones eD sent me, bad right out of the box brand new.
either way, a low quality/bad/old driver is a sure way to insure an amplifier's short life.
daveds50 is offline
post #16 of 18 Old 08-21-2014, 07:16 AM - Thread Starter
Liked: 0
Just wanted to say thank you for everyones help and daveds50 got me right back on the road!! It does seem to sound much cleaner than it ever has. Could be the new driver or daveds50 special touch!! I am quite pleased with the pheonix and seeing my wife's face when I unboxed it was priceless.. Might as well said acme on it lol. Thanks for helping a newbie out.
post #17 of 18 Old 08-21-2014, 03:10 PM
grubadub's Avatar
Quoted: 92 Post(s)
Liked: 97
good to hear you are up and running. i have a phoenix that went out in the fall of '12. got a replacement amp via warranty (shortly before he went down the tubes) so i feel pretty lucky. it's been great ever since. i've had it for almost 5 years now.
grubadub is online now
post #18 of 18 Old 08-22-2014, 07:22 PM - Thread Starter
Liked: 0
Man its good to hear from a satisfied Phoenix owner cause my only regret was not getting 2!! I do wonder how much more could be had out of the config, ie external amp and possibly stronger driver..
