My subwoofer is running away PSA XV15 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By eljaycanuck
  • 3 Post By Tom Vodhanel
  • 1 Post By Rowan611
post #1 of 14 Old 08-01-2014, 05:31 PM - Thread Starter
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Seriously! I purchased my XV15 about three months ago now and am only moderately pleased in its performance due to my great room being entirely tile flooring (except for my 8x10 area rug). With that being said, I have my subwoofer right next to my two couches (kind of being used as an end table) and when the bass really hits the subwoofer starts moving!
As a result, I have turned the dial way down and generally keep the volume to a reasonable level. I am in the process of purchasing a larger area rug (some complications because of my corner fire place) but in the meantime I was thinking about placing something under the sub to help keep it in place and also to make it sound better. Right now it is on tile and I think I'm really missing out on better sound from it.
How about this:
http://www.homedepot.com/p/Auralex-S...i_src=17588969
jhughy2010 is offline
post #2 of 14 Old 08-01-2014, 07:09 PM
Bill Fitzmaurice's Avatar
Liked: 5687
This will do the job for a lot less $$$.
http://www.homedepot.com/p/TrafficMA...0300/202015909
Bill Fitzmaurice is offline
post #3 of 14 Old 08-01-2014, 07:17 PM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
Or $20 for a six-pack of these.
I have one square under each of my subs...and the subs don't move.
jhughy2010 likes this.
eljaycanuck is offline
post #4 of 14 Old 08-01-2014, 07:41 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6579
So how are the diy subs working out?
basshead81 is offline
post #5 of 14 Old 08-01-2014, 07:45 PM
JimWilson's Avatar
Quoted: 1567 Post(s)
Liked: 2098
Isolators will definitely help quiet down things vibrating in your room, so if that's your concern then a Auralex SubDude might indeed be the way to go. My only beef with their products is they charge too much for what they are, so if you're handy it may be better to build one then to buy one.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #6 of 14 Old 08-01-2014, 07:53 PM
Liked: 1964
Cabinets are ready, one driver is on its way (and I'm waiting for an ETA on the second one), and the amp is on back-order.
More info in this thread.
basshead81 likes this.
post #7 of 14 Old 08-02-2014, 07:46 AM
Tom Vodhanel's Avatar
Quoted: 2059 Post(s)
Liked: 6058
How about this:
We have peel/stick pads that you can add to the bottom of your subwoofer legs that eliminate this. Just shoot me an email (support@powersoundaudio.com) and I'll have a handful on the way to your first thing Monday. No charge of course.
Tom V.
Power Sound Audio
Rowan611, trog69 and jhughy2010 like this.
Tom Vodhanel is offline
post #8 of 14 Old 08-02-2014, 05:44 PM
Rowan611's Avatar
Quoted: 393 Post(s)
Liked: 463
Tom V.
Power Sound Audio
That's what I call service.
HT: Marantz 7702mkII | Crown Amps | 1299 L/C/R | Volt 8s | THTs | 1200Ds | Panamax 5300PM | LG OLED 65B6P | Oppo UHD-203 | PS4 |
Family: Pioneer SP-SB23W | Pioneer Kuro Elite 111 | X1
Rowan611 is offline
post #9 of 14 Old 08-02-2014, 11:54 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
How about this:
Is this unusual? Should a well-designed sub exhibit enough vibration to move around on a hard flooring surface? Not a rhetorical question, I'm genuinely curious.
niccolo is offline
post #10 of 14 Old 08-03-2014, 10:02 AM - Thread Starter
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Tom V.
Power Sound Audio
Thank you thank you... I would like to explore the idea of having a pad under the sub like the ones mentioned on this thread. I noticed PSA went away from the base plate. What was the reasoning behind this? Did the base plate help with sound?
I agree... however, I think that the sub and amp is extremely powerful and the cabinet is relatively light... thus allowing for some movement for punchy songs. My tile floors are rather smooth as well.
post #11 of 14 Old 08-03-2014, 10:24 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6579
a down firing sub that fires into a wood/tile floor can move around if it is powerful enough such as the XV15. All one needs to do is put sorbothane/rubber pads under the feet and problem solved. Or spend the extra 100.00 and order it with a base plate.
post #12 of 14 Old 08-03-2014, 10:34 AM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
Makes sense, since the sound waves will literally lift it up a little.
niccolo is offline
post #13 of 14 Old 08-03-2014, 11:19 AM
dsrussell's Avatar
Quoted: 2261 Post(s)
Liked: 3095
^^ My son has a 15-inch down-firing sub that is corner loaded. While he plays at fairly high levels, he usually doesn't play them at reference levels. I forgot what movie he was watching, but he indicated he was playing it at higher levels than normal and the drink setting on his sub flipped in the air and spilled on him and the couch. So his sub actually jumped. Lesson in all this? Don't put drinks on your sub unless it has opposing drivers .
Subs walking is a fairly common occurrence and can happen at extremely high volume levels. Most of the time the weight of the sub is enough to keep them in place.
dsrussell is offline
post #14 of 14 Old 08-03-2014, 01:52 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
Sound waves do not lift these subs up. You would need a hell of a pressure wave to move a 50 lbs sub. Sub walking is more common in microsubwoofers, where the cabinet mass is exceeded by the driver's mms, which is the moving assembly plus the weight of the air being pushed. I have only heard of it happening with larger subs when they have spiked feet on a hard floor, but spiked feet are meant for carpeting anyway.
shadyJ is offline
