Subwoofer for my definitive tech setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-11-2014, 09:55 AM - Thread Starter
Liked: 0
Hi fellow audophiles, need some suggestions on my setup in a townhouse with living and dining rooms together 25 x 21.
I bought a Yamaha RX-V677 7.2-Channel Receiver + Definitive Technology ProCinema 600 5.1 Speakers for $600 without subwoofer from Newegg couple of weeks back. I only use it with my HTPC running Windows 8 Pro, Biostar Motherboard (TZ77XE3) with a GIGABYTE GV-R645-1GI Radeon HD 6450, i5-3570K, 16GB RAM, 128GB SSD, 6 TB data. Connected using HDMI ( video card )from HTPC to Receiver.
The sound quality is not satisfactory. Is it because of missing subwoofer or definitive speakers or no audio card. Ready to invest to upgrade.
1) Please advise on subwoofer - thinking about getting SVS SB 2000 or 1000 from their outlet or BIC.
2) Can any generic wall mounts work for definitive speakers
3) Are there any recommended changes to be done on HTPC.
5) Shall i get bookself type front speakers and make it 7.1
halfgeek is offline
post #2 of 3 Old 08-11-2014, 10:02 AM
Sdiver2489's Avatar
Quoted: 163 Post(s)
Liked: 106
What about the sound quality is not satisfactory?
Sdiver2489 is offline
post #3 of 3 Old 08-11-2014, 10:05 AM
adrock7309's Avatar
Liked: 0
I have a def tech set up with mythos and a couple in ceiling speakers and i have two SVS SB2000s that are seeming to marry really well so far. I mainly watch movies with my setup and i have been blown away by the value and power of the SVS SB2000s.
AVR: Pioneer SC-67 (5.2 set-up)
Display: Samsung PN60F8500
LCR: Def Tech Mythos 2, 8, 2
Subs: 2 x SVS SB-2000
Blu Ray: Oppo 103D
adrock7309 is offline
definitive , htpc
