Two Different Subwoofers in the Dedicated HT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-11-2014, 01:00 PM - Thread Starter
AXLCMT's Avatar
Quoted: 182 Post(s)
Liked: 69
I will be using my AV Receivers (Denon) Audyssey Multi-32 to calibrate my HT, but what is the general consensus on using two subwoofers, but if they are different kinds? I know that it is best practice to have two subwoofers that are the exact same model, but will it really be that bad if I use two subwoofers that are different models/companies?
AXLCMT is online now
post #2 of 7 Old 08-11-2014, 02:23 PM
derrickdj1's Avatar
Quoted: 995 Post(s)
Liked: 733
It can really work great if they are carefully setup. I use two different types in my HT and the sound is off the hook.
derrickdj1 is offline
post #3 of 7 Old 08-11-2014, 04:45 PM
craig john's Avatar
Quoted: 567 Post(s)
Liked: 806
What 2 subs are they?
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #4 of 7 Old 08-11-2014, 04:50 PM
Kini62's Avatar
Quoted: 1743 Post(s)
Liked: 1557
I use the two very different subs listed in my signature. They work well together. They were both "set up" by ear. No EQ or DSP of any kind. Sounds great to me.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 7 Old 08-11-2014, 08:51 PM
Alan P's Avatar
Quoted: 5136 Post(s)
Liked: 3836
Don't do it! You just might rip a hole in the space-time continuum!!
Alan P is online now
post #6 of 7 Old 08-12-2014, 04:46 AM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
Audyssey usually handles it pretty well actually. You might have to play with placement a bit, but it should work pretty well. If your model has Sub EQ, you will be fine for sure.
Denon 4520CI
Emotiva LPA-1
Epson 5020ub::::110" Silver Ticket
PS4::::Toshiba HD-A35:::::::::Denon DBT 3313UDCI:::Darbee DVP 5000
Martin Logan Stage(c)::::ML Aerius I(l/r)::::ML Motion FX(s)::::ML Scripts(sb)
PSA XV15:::::PSA XV15se
wadec22 is offline
post #7 of 7 Old 08-12-2014, 08:20 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
No. It's not necessarily that bad. As you pointed out, it's just a best practice to use identical subs.
However, if one sub is of significantly less quality in terms of max output or SQ, it can be a limiting factor in performance depending on how you set it up.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
