Subwoofer switcher - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-13-2014, 06:16 AM - Thread Starter
qwerty_88's Avatar
Quoted: 60 Post(s)
Subwoofer switcher
Do you guys know of any RCA switch box with 1 input and multiple outputs?
I've been trying to find online with no results.
I need this because the room have 4 subwoofers. I need them to work one at a time only.
My AV Receiver Sub out will be connected to the RCA switcher input and my 4 subwoofers will be connected to the outputs of the switch box. Thus, I can select which subwoofer will work.
qwerty_88 is offline
post #2 of 13 Old 08-13-2014, 06:28 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
A pre-amp would work, with record & listen switches
fatbottom is offline
post #3 of 13 Old 08-13-2014, 06:41 AM
ebsebs's Avatar
Here's an inexpensive audio/video switcher (you can ignore the connections you don't need):
http://www.amazon.com/BIRUGEAR-Selec.../dp/B0031IIXW0
I don't have any personal knowledge of this unit, and there are probably many other similar models.
Eric
ebsebs is offline
post #4 of 13 Old 08-13-2014, 06:45 AM - Thread Starter
qwerty_88's Avatar
Quoted: 60 Post(s)
Eric
i need it the other way around. multiple outputs and single input.
the subwoofers will be connected to the outputs and the AV Receiver will be connected to the input.
post #5 of 13 Old 08-13-2014, 06:46 AM - Thread Starter
qwerty_88's Avatar
Quoted: 60 Post(s)
or will it work the same way? please correct me if i'm wrong. i'm actually not sure as well.
post #6 of 13 Old 08-13-2014, 06:53 AM
ebsebs's Avatar
Based on the product reviews, I was assuming that the RCA connections are just mechanical switches (no electronics), so that the input/output designation doesn't make any difference.
ebsebs is offline
post #7 of 13 Old 08-13-2014, 07:02 AM
fatbottom's Avatar
Liked: 518
Basically something like this minus volume control, tone controls
http://1.bp.blogspot.com/-pPW7J0BF7L...0/DSC02526.JPG
post #8 of 13 Old 08-13-2014, 09:30 AM
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
Possibly this?
http://www.amazon.com/TC-716-Stereo-...xp_grid_pt_0_0
Denon X4000 | Paradigm Studio 60s | Paradigm Studio CC-590 | Dual SVS PB-2000s | Sony VPL-HW40es | 110" Seymour Ambient Visionnaire 1.3 | Intel NUC i5 HTPC
swargolet is offline
post #9 of 13 Old 08-13-2014, 09:36 AM
Quoted: 40 Post(s)
Originally Posted by swargolet View Post
I have one of those for switching a self powered computer
speaker to four different computers. It's all mechanical inside.
There is a small resistor, I think 1k, that is put in series with
your source.
wilcal is offline
post #10 of 13 Old 08-15-2014, 04:45 PM
Alan P's Avatar
Quoted: 4642 Post(s)
Liked: 3257
Am I the only one curious as to WHY the OP doesn't want to run more than one sub at a time?
Alan P is offline
post #11 of 13 Old 08-15-2014, 06:40 PM
derrickdj1's Avatar
Quoted: 867 Post(s)
Liked: 582
That's what I was thinking. Why does he only want to run one at a time. The four subs should work as one unit in the system. For calibration, just turn off the other subs.
derrickdj1 is online now
post #12 of 13 Old 08-16-2014, 04:25 AM - Thread Starter
qwerty_88's Avatar
Quoted: 60 Post(s)
it will be actually a demo room.
post #13 of 13 Old 08-16-2014, 04:32 AM
fatbottom's Avatar
Liked: 518
Say it again, a used second hand stereo pre-amplifier will do. Granted it has pre-amp in the chain, but it will you to switch several stereo inputs and stereo outputs, so you could have several stereo subwoofers matching pairs
http://www.hifiengine.com/images/mod..._amplifier.jpg
