Who here has done MiniDSP with Audyssey XT32? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By zeus33
post #1 of 11 Old 08-15-2014, 01:45 PM - Thread Starter
Sdiver2489's Avatar
Quoted: 184 Post(s)
Liked: 116
Hello all,
I am happy with my PB12-Plus' performance but am curious if I can get a little more out of it. I saw a huge difference in my experience with using XT32 AFTER I dialed in the PEQ's on the sub and I'm wondering if it would be that much better if I created a custom profile to truly flatten the response before Audyssey got its hands on it.
I am just curious how many of you may have done this and what your experience was like. I don't want to waste my money but its not that expensive of an upgrade for if it justifies itself.
Sdiver2489 is offline
post #2 of 11 Old 08-15-2014, 03:14 PM
Alan P's Avatar
Quoted: 5131 Post(s)
Liked: 3825
I (and many others) have had mixed results with EQ before Audyssey. See here for some discussion on the subject.
Alan P is offline
post #3 of 11 Old 08-15-2014, 05:55 PM
derrickdj1's Avatar
Quoted: 992 Post(s)
Liked: 731
With only one sub, there is not a lot of benefit with the addition of the mini DSP.
derrickdj1 is offline
post #4 of 11 Old 08-15-2014, 08:43 PM
Alan P's Avatar
Liked: 3825
I completely disagree with this.
Alan P is offline
post #5 of 11 Old 08-16-2014, 04:48 AM
Rowan611's Avatar
Quoted: 392 Post(s)
Liked: 463
I would think the minidsp would be even more help with 1. Either way, if you use a minidsp to get a nice curve, why run you sub through Audyssey? You'd be better served telling your receiver that you're not running a sub, then turn it back on when it's done.
HT: Marantz 7702mkII | Crown Amps | 1299 L/C/R | Volt 8s | THTs | 1200Ds | Panamax 5300PM | LG OLED 65B6P | Oppo UHD-203 | PS4 |
Family: Pioneer SP-SB23W | Pioneer Kuro Elite 111 | X1
Rowan611 is offline
post #6 of 11 Old 08-16-2014, 11:11 AM
zeus33's Avatar
Quoted: 1558 Post(s)
Liked: 1405
Agreed. You are more prone to have big peaks and dips with only one sub.
zeus33 is online now
post #7 of 11 Old 08-16-2014, 11:18 AM
zeus33's Avatar
Liked: 1405
No you wouldn't. Audyssey would make calibrations and apply filters based on that setup and then you would mess them up by changing the configuration.
The best way to do it is to set the Mini DSP to flat and then run Audyssey. After the Audyssey calibration, you can apply your tweaks in the Mini DSP to achieve the desired curve/sound that you want.
If you run Ausyssey after adjusting the Mini DSP, then Audyssey will undo your adjustments and "flatten" the curve negating most of the effect of the Mini DSP.
One of the main reasons people use a Mini DSP is because they don't like the "flat" sound that Audyssey calibrates to and it allows them to add a house curve, etc. to achieve the desired result.
Alan P likes this.
post #8 of 11 Old 08-17-2014, 01:11 PM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
Originally Posted by Sdiver2489 View Post
Hello all,
IIRC, XT32 EQs down to the -3dB point, so if you flatten out your response before running XT32, it should EQ more of the audio range (which does, of course, also include time alignment, not just flattening the curve).
I can't remember where the cut off point is but it's either 20Hz or below, I'm sure I read that somewhere.
MemX is offline
post #9 of 11 Old 08-17-2014, 10:23 PM - Thread Starter
Sdiver2489's Avatar
Quoted: 184 Post(s)
Liked: 116
Yeah I hadn't heard that before but I am guessing it must be true. It must have seen the drop in response at 40Hz and assumed that's where my PB12-plus gave out (right...). So dropping the response down in this area gave Audyssey more to work with. Still debating about trying the minidsp. I do love gadgets though...especially ones that are cheap upgrades...
post #10 of 11 Old 08-19-2014, 10:09 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
I've just swapped from a PB12-Plus/2 to a dual sealed 18 and am currently relying on Audyssey alone to EQ the system. Apart from the obvious differences in bass presentation (it seems tighter with more chest punch) it seems as though my response is a flatter a lot lower than it used to be - notes that used to boom out are now a lot more refined, so I can only imagine that it is either Audyssey doing its stuff because the response curve is flatter, or perhaps it stops the EQ higher up the scale, meaning I need to boost lower down before I run audyssey, like you are looking at!
Either way, for the price you can't really go wrong with a MiniDSP - even if it doesn't work for your room or you don't need it, you can sell it on at a fairly minimal loss
MemX is offline
post #11 of 11 Old 08-19-2014, 10:49 AM
Spanglo's Avatar
Quoted: 493 Post(s)
Liked: 436
A device like MiniDSP is essential, especially if you're running multiple subs. You need that level of control of all your speakers to negate room influence.
I run quad subs, use mini dsp mostly for the HP and LP filters, delay, and some EQ for flat response. Audyssey is icing on the cake at that point, and I use Dynamic EQ for the "house curve." I prefer to use dynamic EQ rather than EQ'ing a house curve with MiniDSP, because of the loudness correction. My listening volumes are all over the place, so dynamic eq really comes in handy.
PSN - Hapi_Kilmore_v3
My 6.4.4 Living Room HT
Spanglo is offline
