Sealed and ported sub in same room for home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-15-2014, 11:38 PM - Thread Starter
hondakilla98's Avatar
Quoted: 22 Post(s)
I have an onkyo tx-sr608, EP2500, DSP1124P, AA AVA 18 in 8.75 cu ft @20hz . I ended up with a blown SI HT18, I'm thinking about reconing it and putting it in a sealed down firing box next to my couch. Sealed to keep it end table size, and next to the couch for more low end impact by the couch.
I have two questions.
1... Can I run a sealed and ported sub of different make in the same room?
2... It looks like my receiver only has processing for one sub, even though it says 7.2. Will that be a problem?
Here's the basic layout of my living room.
hondakilla98 is offline
post #2 of 5 Old 08-16-2014, 06:32 AM
Bill Fitzmaurice's Avatar
Liked: 4459
You may.
It will. Mixing different subs is unpredictable, mixing different formats even more so. If you can separately process them it can work, but I wouldn't attempt it otherwise.
A driver that works well in a ported cab may not work well in a sealed cab, and vice versa. You will have to model it to be sure.
Bill Fitzmaurice is offline
post #3 of 5 Old 08-16-2014, 08:22 AM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
With a receiver with Audyssey Sub EQ I think mixing is okay, otherwise I think it should be avoided.
Denon 4520CI
Emotiva LPA-1
Epson 5020ub::::110" Silver Ticket
PS4::::Toshiba HD-A35:::::::::Denon DBT 3313UDCI:::Darbee DVP 5000
Martin Logan Stage(c)::::ML Aerius I(l/r)::::ML Motion FX(s)::::ML Scripts(sb)
PSA XV15:::::PSA XV15se
wadec22 is offline
post #4 of 5 Old 08-17-2014, 06:13 AM - Thread Starter
Quoted: 22 Post(s)
What if the second sub was a ported 15? What about adding a minidsp?
post #5 of 5 Old 08-17-2014, 06:41 AM
Liked: 4459
You'll get the best results with identical subs. You may be able to get a good result if they're not matched, but there's no guarantee.
