Single SVS PB1000 or dual BIC PL200? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By MIX_MASTER_ICE
post #1 of 4 Old 08-24-2014, 08:47 AM - Thread Starter
fl81's Avatar
Quoted: 22 Post(s)
I am in the market to upgrade my subwoofer. I do not have a huge room around 16 by 12 with 7.5 feet ceilings, so about 1400 cubic feet. I'd like to keep the price around $500.
I’m looking at a single SVS PB1000 or dual BIC PL200. It/They will be used for about 70% movies 30% music, any suggestions, comments or concerns.
Im going from a DEFTEC prosub 800, so any sub is an upgrade.
Setup 5.1
Yamaha rxv673
Fronts mythos 4
center mythos 3
surrounds promonitor 600
prosub 800
fl81 is offline
post #2 of 4 Old 08-24-2014, 10:16 AM
jwtallguy's Avatar
Quoted: 119 Post(s)
Liked: 55
Setup 5.1
Yamaha rxv673
Fronts mythos 4
center mythos 3
prosub 800
Well normally id say get two over the single but since movies are 70% of use id get the pb1000 now and add another when you can .
The bic is solid to 30 hertz in a small room and the pb1000 is solid to 20 hertz
jwtallguy is offline
post #3 of 4 Old 08-24-2014, 10:21 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6573
skip both of those options and go this route.
http://www.chanemusiccinema.com/chan...product_id=178
and one of these...
http://www.guitarcenter.com/Crown-X1...53-i2670626.gc
now you have a bass system that would absolutely destroy both options mentioned above for only a 100.00 more.
basshead81 is offline
post #4 of 4 Old 08-24-2014, 11:56 AM
MIX_MASTER_ICE's Avatar
Quoted: 1424 Post(s)
Liked: 1195
Setup 5.1
Yamaha rxv673
Fronts mythos 4
center mythos 3
prosub 800
A PB-1000 would likely be enough in a small room such as yours, especially if it isn't an open floor plan with other rooms. Skip the PL200 for your needs, mostly movies. If you can wait a few days, it's possible, although unlikely, that Outlaw will have a Labor Day sale on their LFM-1 Plus, priced at $499. That sub will give you better output and extension than the PB-1000 for the same price. If no Labor Day sale, then they'll have a Thanksgiving sale.
fl81 likes this.
MIX_MASTER_ICE is online now
