Sub is triggered without signal - AVS Forum
 1Likes
  • 1 Post By 123
post #1 of 7 Old 08-27-2014, 11:30 AM - Thread Starter
123
123's Avatar
I have a Klipsch RW-12D that I have had for about a year and a half, purchased brand new. It has worked perfectly up until now. I moved the sub location slightly, but it is still plugged into the same outlet it has always been plugged into. Other than that, nothing has changed with my setup, so I know it was perfectly functional for a long time. When I turn the sub on, it makes some light crackling noises, which come and go. I kinda ignored it, but then I was watching tv and the sub hit HARD every 10 minutes or so. For no real reason (i.e. there was definitely not that kind of signal coming from my media). The crackling occurs even with the signal wire completely unplugged from the sub. So basically, there is a phantom signal. The other thing I noticed, when I was playing around with it, is that even with a bass-heavy signal, the sub is not hitting very hard (I can see it firing, but it's very sub-par compared to how it used to perform). I am not very knowledgeable about this stuff, but I assume the most likely culprit is the sub's amp? I just want to have a basic idea of what the potential culprits are before I deal with customer support. Thanks all!
123 is offline
post #2 of 7 Old 08-27-2014, 11:34 AM
DonH50's Avatar
Quoted: 159 Post(s)
Liked: 261
Sounds like the amp is going bad. Could be bad coupling cap in the amp. Or any one of a myriad of other things. Get it fixed before it takes out the driver.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 7 Old 08-27-2014, 01:05 PM - Thread Starter
123
123's Avatar
Thanks, that's where my head was at. Hopefully it's under warranty.
123 is offline
post #4 of 7 Old 08-27-2014, 01:08 PM
lovinthehd's Avatar
Quoted: 194 Post(s)
Liked: 779
IIRC only 2 years warranty involving the amp....but never hurts to contact them....
lovinthehd is online now
post #5 of 7 Old 08-27-2014, 01:19 PM - Thread Starter
123
123's Avatar
That would be great, because I've definitely had it less than 2 years
123 is offline
post #6 of 7 Old 09-04-2014, 08:45 AM - Thread Starter
123
123's Avatar
So I used Klipsch's online warranty form - 2 days later (today), they responded that they are sending me a new amp in 7-10 business days.
+1 for their customer support - talk about easy. I don't mind swapping it out myself - in fact, I prefer it compared to driving or shipping to a repair center. But what about the technically uninclined customer? Anyway, just thought I'd follow up since they treated me well. I'll update one final time in about 2 weeks after I swap the amp out to see if it fixes the issue.
123 is offline
post #7 of 7 Old 09-12-2014, 08:46 AM - Thread Starter
123
123's Avatar
Got the parts, and replaced the amp - sub works perfectly again. Very pleased with Klipsche customer service on this one. For future reference if anyone finds this thread, you will need a size T20 torx screw driver to remove the torx screws holding the amp to the sub.
lovinthehd likes this.
123 is offline
User Tag List
