ED A7S-450 stopped working/suggestions?/recommendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-28-2014, 07:09 AM - Thread Starter
barlav's Avatar
I have a 5+ year old A7S-450 subwoofer that has been working great until the other day. I just had new carpet installed and I had to unhook and move the sub out of the room and back in. I slid it out and back in very slowly and carefully and rehooked it up exactly the way it was before. I am also using the eQ.2 equalizer with it. When I powered it back up it made a "thump" sound, not very loud, just like an abbreviated version of the sound it makes when the AVR does a channel test. I get nothing from it when doing channel test with AVR. The green light is on on the back of the sub but no sound from it. I took the eQ.2 out of the loop with the same result. I also notice that if I turn on and off the eQ.2 and/or the AVR I get that "thump" when those devices power on but that's it. No other output after that point.
So, I am at the point where I need to figure out what's wrong with it and see if I should try to fix or have fixed. Any ideas as to what the problem may be? And if it's fixable?
Or, if it's time to go with a new sub, then what would be a good one that will give me the same performance or better? I was thinking Rythmik F15HP might be a decent choice? But I'm not sure what else might be out there.
Thanks for any input/advice
barlav is offline
post #2 of 9 Old 08-28-2014, 09:04 AM
basshead81's Avatar
Quoted: 164 Post(s)
Liked: 4722
Try hooking a different source directly to it...cd player, ipod, smart phone etc... If nothing then try pressing on the cone with signal being fed to it. This will determine if there is a detatched VC wire.. You could also run a continuity test with a volt meter to check for a broken VC wire.
Being the green light is on tells me the amp should be working. Normally when a amp fails there will be no green light...it will be red or nothing.
basshead81 is offline
post #3 of 9 Old 08-28-2014, 10:47 AM - Thread Starter
barlav's Avatar
Thanks, so it turns out that my AVR has 2 subwoofer ports. One for multi ch input and one for pre-out. It was dark and late last night when I hooked it up and guess what...I chose the wrong one. Ugh!!! Crisis averted! It's back.
barlav is offline
post #4 of 9 Old 10-12-2014, 08:27 AM
Randybw1's Avatar
A7s-450
I have the same sub. Last night it started popping and crackling. I unhooked everything and with nothing going through it, it's still doing it. Sounds like I need a new driver...Any suggestions? Thanks!
Randybw1 is offline
post #5 of 9 Old 10-12-2014, 11:05 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1348
Sounds like the amplifier is the problem. It is very unlikely to be the driver. I would add binding posts to the cabinet and use an outboard amp like a Behringer iNuke.
shadyJ is offline
post #6 of 9 Old 10-13-2014, 07:07 AM
Randybw1's Avatar
Thanks for the information, can you point me to the model I would need? Thanks again!
Randybw1 is offline
post #7 of 9 Old 10-13-2014, 06:09 PM
dominguez1's Avatar
Quoted: 807 Post(s)
Liked: 546
I had this same problem with the a7s and it turned out to be the driver. Does the amp still show a green light when powered on? If so, it's likely the driver. You can take out the driver and make sure the connections are seated properly to the driver. I've had them come loose before and cause this issue. If they are connected correctly, it's probably the driver. To test to see if it's the driver, take a 9volt battery and connect wires to the driver and touch them to the battery. You should get a solid thump...if you still get crackling, it's the driver.
The good news is that the UXL-18 from mach5 is a great fit into that enclosure. Pretty much plug and play I believe. The lt 1300 amp in you Ed is solid...great amp and one that delivers a true 1300w or more.
dominguez1 is online now
post #8 of 9 Old 10-13-2014, 06:28 PM
primetimeguy's Avatar
Quoted: 495 Post(s)
Liked: 314
Maybe try posting over here
Official Elemental Designs Subwoofer Thread
davidse50 has been repairing amps for ED subs. I just sent him an amp that does the exact same thing you mention...green light on but nothing.
primetimeguy is online now
post #9 of 9 Old 10-14-2014, 09:45 PM
Randybw1's Avatar
Turns out I need a new Driver, any suggestions to replace the 18" eD? I looked at the UXL-18, but would like other options if anyone knows of some? My 1300 Watt amp should be okay. Thanks
Randybw1 is offline
