Subwoofer crossover question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-03-2014, 05:08 AM - Thread Starter
soksok's Avatar
Hi,
I'm using a pair of JL Audio e-sub 112. When I run a frequency test say 50hz, and I adjust the subwoofer crossover frequency to 40hz, the sub still produce frequencies.
Is this normal? should't the subwoofer only play 40hz and below?
The test tones I'm using are from the SoundDoctor CD.
soksok is offline
post #2 of 5 Old 09-03-2014, 05:15 AM
eljaycanuck's Avatar
Quoted: 1239 Post(s)
Liked: 1811
Generally speaking, subs should handle content below 80Hz.
(Audyssey routinely sets the crossover settings in my AVR to 40Hz for all speakers. I always bump them back up to 80Hz.)
eljaycanuck is offline
post #3 of 5 Old 09-03-2014, 05:18 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Crossovers aren't a brick wall, so frequencies above the crossover will still be heard, they should be at a reduced volume, however you may have a peak above your crossover so the room is effecting the crossover slope.
fatbottom is offline
post #4 of 5 Old 09-03-2014, 10:17 AM
Alan P's Avatar
Quoted: 4700 Post(s)
Liked: 3329
Alan P is offline
post #5 of 5 Old 09-03-2014, 12:43 PM
DonH50's Avatar
Quoted: 1804 Post(s)
Liked: 1343
^^^ Actual numbers depend upon the crossover design, of course. That said, an excellent plot to illustrate hoe sound does not immediately die way on either side of the crossover. This is also why getting the subs in phase with the mains at the crossover frequency is important to prevent cancellation of sound.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
