Connecting Klipsch rsw-10d to yamaha rx-v775 - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2014, 12:33 PM - Thread Starter
Liked: 0
Question Connecting Klipsch rsw-10d to yamaha rx-v775
Hello!
I am interested if someone has experience how to connect the Klipsch rsw-10d sub to a yamaha receiver? The "problem" is that I read that I need a seperate amp for the sub, becouse the sub has an active woofer and a passive one. Is this true or can I just connect the sub normaly to the sub out on the receiver?
Thank you
T0m1sl4v is offline
Old 10-07-2014, 12:45 PM
eljaycanuck's Avatar
Quoted: 1234 Post(s)
Liked: 1808
I'm willing to bet you didn't read that in the owner's manual (PDF).
From Wiki:
Passive radiators are used instead of a reflex port for much the same reasons—to tune the frequency response, particularly in small volume enclosures and when small diameter drivers are used, for better low frequency performance.
All you need to do - as Figure 5 in the owner's manual shows you - is connect:
- from your receiver's SUBWOOFER 1 PRE OUT output,
- to the L[eft] input on the sub.
eljaycanuck is offline
