Just noticed a downside to dual subwoofers - AVS Forum
post #1 of 16 Unread 11-22-2014, 08:24 PM - Thread Starter
coli's Avatar
Quoted: 89 Post(s)
Liked: 30
The receiver/processor can run out of power supplying 2 subs instead of 1 with voltage, leading to dynamic compression. Took me 2 week to figure this one out...
Thankfully the solution is easy, turn the volume on the sub up, then rerun calibration.
Assuming noise is not a problem and the receiver/processor has enough range to compensate...
coli is offline
post #2 of 16 Unread 11-22-2014, 09:13 PM
IndianaGeorge's Avatar
Couldn't that happen just as well with just one sub?
IndianaGeorge is offline
post #3 of 16 Unread 11-22-2014, 09:21 PM
deewan's Avatar
Quoted: 30 Post(s)
Liked: 66
Could happen with one I believe. If that subs gain is turned so low that the AVR and calibration system is trying to make up a lot.
coli did the right fix though. Find a sweet spot where the gain on the amp isn't too high and the processor/AVR doesn't have to bump up the output levels as much. On a bigger scale, this problems can also happen when a sub too small for the space. The gain on the amp and the calibration gain can't make up for the lack of driver displacement.
deewan is offline
post #4 of 16 Unread 11-23-2014, 08:01 AM - Thread Starter
coli's Avatar
Quoted: 89 Post(s)
Liked: 30
Hey you are right, it's just happens when I had only 1 sub it sounded sweet enough
coli is offline
post #5 of 16 Unread 11-24-2014, 01:09 AM
If you had a given subwoofer with the gain set at a certain level and all was fine, but then added another identical subwoofer with the gain set at the same level it would increase low level bass output by theoretically 6 dB, so the AVR would be able to drive it at a lower level. Something seems odd
post #6 of 16 Unread 11-24-2014, 01:54 AM
derrickdj1's Avatar
Quoted: 123 Post(s)
Liked: 155
To get 6 db, you added added another power supply and double the displacement. What is odd? LoL.
Klipsch RF 7 based HT 7.4, Pioneer SC 35, Acurus 200 Five, Dayton 18 Ultimxa Dual Sub Cab(2), Dayton 18 Ultimax Large Vented Sub Cab (2), on Berhinger I Nuke DPS amps, Samsung BDP F 7500, Asus/My Book Live HPC 4 TB
Yaquin VK 2100 amp, McIntosh XR 5 speakers, Samsung BDP F 7500
derrickdj1 is online now
post #7 of 16 Unread 11-24-2014, 03:04 AM
lovinthehd's Avatar
Quoted: 509 Post(s)
Liked: 1024
This sounds like 420 logic.
"I realize that somebody playing free music isn't as commercial as a hamburger stand. But is it because you can eat a hamburger and hold it in your hand and you can't do that with music? Is it too free to control?" - Don Van Vliet (aka Captain Beefheart) discussing commercial success in the music biz
lovinthehd is online now
post #8 of 16 Unread 11-24-2014, 05:00 AM
the_abbot's Avatar
Quoted: 65 Post(s)
the_abbot is offline
post #9 of 16 Unread 11-24-2014, 06:25 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 156
Ok, You have to explain this one to me.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #10 of 16 Unread 11-24-2014, 06:44 AM
lovinthehd's Avatar
Quoted: 509 Post(s)
Liked: 1024
Just seems like a bit of stoner logic, 420 http://en.wikipedia.org/wiki/420_%28cannabis_culture%29
post #11 of 16 Unread 11-24-2014, 07:11 AM
Bill Fitzmaurice's Avatar
Liked: 1684
Originally Posted by coli View Post
The receiver/processor can run out of power supplying 2 subs instead of 1 with voltage.
With parallel connections the same voltage will be input to every driven device, no matter what the number. What will happen with a sufficient number of driven devices/amps is that the total load impedance will go too low compared to the output impedance of the line driver, but the average AVR can drive at least six sub amps without impedance loading issues. So whatever is happening isn't what you think is happening. I'd be looking at phase/polarity issues.
Bill Fitzmaurice is online now
post #12 of 16 Unread 11-25-2014, 07:32 PM
The output to the subs should be 6 dB lower after adding the second sub and recalibrating the AVR, yet he says he had to increase the gain on the subs because the AVR went into dynamic compression. Theoretically he would have gained 6 dB of headroom, so something is odd in the assessment of the situation.
post #13 of 16 Unread 11-26-2014, 03:17 PM
qguy's Avatar
Quoted: 23 Post(s)
Liked: 61
How does one find out that the AVR is going into dynamic compression ?
qguy is offline
post #14 of 16 Unread 11-26-2014, 03:20 PM - Thread Starter
coli's Avatar
Quoted: 89 Post(s)
Liked: 30
Your ear + a song you really like. In my case, there's this song with a lot of 30hz+60hz ramp in the 2nd half of the song, it's this part that clued me in the problem.
coli is offline
post #15 of 16 Unread 11-26-2014, 03:57 PM
JHAz's Avatar
Quoted: 119 Post(s)
Liked: 166
In this case the compression is part and parcel of THD. If it is not audibly distorted it is unlikely to be dynamically restricted by the preamp. Its one of the great things about really pushing an old style single channel guitar amp. Distortion sounds cool and the dynamics are more naturally constricted than any compressor could accomplish. Compare Hendrix to Messina (and I like them both).
JHAz is online now
post #16 of 16 Unread 11-26-2014, 04:45 PM
AVS Club Gold
craig john's Avatar
Quoted: 131 Post(s)
Liked: 362
Although you fixed the problem by doing the "right" thing, your diagnosis of the problem is all wrong...
If your subs volume controls are set too low, the receiver has to send them too strong a signal. The excessive signal overdrives the inputs of the sub amps, and THIS is what's causing the distortion you're hearing. It is NOT the receiver running out of power to drive the subs.
Fortunately, the way to correct this is to turn UP the subs' volume control and recalibrate the system, which is exactly what you did.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
