No sound from Morel is9a - AVS | Home Theater Discussions And Reviews
post #1 of 4 Old 12-06-2014, 04:23 PM - Thread Starter
Gkore's Avatar
Liked: 0
Hey everyone, I know this is the best site to be asking questions in, so here I go
I recently bought a second hand Morel is9a in working condition (heard it myself), and now it's not!
The chain of events is as follows:
1. Heard the sub working in the seller's place using his system (Marantz AVR).
2. Switched the sub to "off" at the back panel, and disconnecting RCA and power cable.
3. Moved the sub to the trunk of the car (5 door Seat Ibiza).
4. Drove about 35min, with one break being a bit hard, heard the sub 'falling' in the back (was standing, and "fell" about 15 degrees to a position in which it leaned against the back seats).
5. No physical damage whatsover (At least not visible, front or back).
6. Moved the sub from the car to the apartment, removed previously connected subwoofer using the same RCA (conncted to Denon X1000).
7. Switching power cable to the one I got from the seller (working).
Now, this is where the problem starts...
Switched the sub to "On", the green light is steady on (no thump or anything).
Anddddd no sound...
Things I've tried:
1. Switching power cable and RCA cable.
2. Using a splitter.
3. Connecting a 3.5mm mini-pl to 2 RCA from iPhone to the back of the sub.
4. Connecting to a different power socket in another wall.
5. Opening the back of the amp to look for damage... Couldn't see anything burnt, leaking, damaged, disconnected...
One wierd thing that does happen is when I put the sub on "Auto on", and pushing some volume to it (around 45db from the AVR), I hear a "pop" sound, and the subs goes "on" (as in green light, still no sound at all).
Btw, when I say no sound, there's no movement at all of the membrane, so it's not faint, it's off.
Pretty bummed about having to deal with it right after I heard it working and payed for it :\
I would greatly appreciate any advice!
Needless to say... there's no warranty, and I'm trying to avoid sending it to a random speaker fixer, and pay about 50% of the cost on this repair.
Thanks for reading and Thanks in advance for helping!
Gkore is online now
post #2 of 4 Old 12-06-2014, 05:26 PM - Thread Starter
Gkore's Avatar
Liked: 0
Hmm okay... so now I'm confused but happy...
I checked the main fuse to see if it's okay, seemed fine so I put it back in, and now it works flawlessly!
Pretty wierd I must say, but I'm glad I somehow managed to get around it... just my luck I guess.
Anyway, if anyone is reading this, I still need help in my other thread regarding the Clark Synthesis TST239...
Thanks :P
Gkore is online now
post #3 of 4 Old 12-08-2014, 11:44 AM
Alan P's Avatar
Quoted: 1526 Post(s)
Liked: 765
Sounds like there just might have been some oxidation on the fuse contacts and you worked it loose by re-seating it. Glad it worked out!
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC-64ii, SUR: Polk LS/FX x4, FH: Klipsch RB-51ii x2, SUB: PSA T-18 x2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #4 of 4 Unread Today, 03:38 PM - Thread Starter
Gkore's Avatar
Liked: 0
Sorry to bump and old thread... but the problem is back :'(
About the same symptoms, except tha fact that when I opened it up again, I saw one big capacitor which has some dried out liquid of something on it...
So I went out and bought a new capacitor (63v 6800uF) and replaced it... and... nothing, same symptoms :\ (also checked the fuse btw... all good)
Symptoms are as described in the first post, but in short it's like this:
1. subwoofer is connected, set to auto (red light on).
2. while connected to an audio source via RCA, turning up the volume a bit brings the subwoofer to "ON" (green light), a quiet thump is heard, correlated to how much volume was set.
3. well... that's it basicly, not output at all... not even quiet, just nothing.
What can I do more? except send it out to a proffestional repair (need to find one I can trust...) and pay about 50% of the initial cost...
Anyone knows how can I get the schematic for the amp perhaps?
ID:	578761   Click image for larger version
Gkore is online now
