A couple years back, I purchased some Martin Logan Motion 40 towers, a Motion 8 for a center, and a Dynamo 500 sub. Recently, I've been working on upgrading and I'm switching out the Motion 40's for a pair of Martin Logan Theos speakers. Taking advantage of the current special ML is running, I'm getting a Dynamo 700w included. This presents me with some interesting options--I'd love to get some thoughts here. Keeping in mind that my room is very large with high vaulted ceilings.
Proceeds from any sale would most likely be put towards a new ML Motif X center or a new AV rack.
1. Sell the 500. While they share the same driver, the 700 has a more powerful amp and is in a sealed box (having tested in the past, I tend to prefer the tightness of sealed enclosures over ported). I'm sure I could get $250 - $300 for it.
2. Sell the 700 new in box. I could either try to do this online and get full price (or very close to it) or my shop has offered me $500 for it despite knowing that I got it free.
3. Run both the 500 and the 700 for 2 subs. I'm not sure how this would play out; but, it's an option and one I am considering.
4. Sell both the 500 and 700 and go with something higher end than either of them (missing the opportunity to add other gear at this time).
Well, since you're getting the ML Ethos, one of maybe two or three of the very best speakers that I've heard in recent years, I'd say you deserve a top-end sub as well. The problem is, I don't know what you mean by a very large room. What is the cubic footage and is it open to other rooms? That will be the number one parameter as far as what sub. If you're looking at under 5,000 cu. ft., I'd say a Seaton SubMersive is the top dog as far as sealed subs are concerned, unless it is now the PSA Triax (3 opposing 18-inch drivers!!). Or you could think about dual PSA XS30se's. Both the XS30se and Seaton SubMersive have similar designs (dual opposing 15-inch drivers). If you're looking at over 5,000 cubic feet, then dual Seatons or dual Triax ... or triple XS30se. I'd also look at dual Rythmik subwoofers. The FV15HP is Rythmik's top dog and a terrific sub, but it's ported. They do have some really nice sealed subs, so take a look.
I'm no expert but how would a single 10' suffice over two Ethos subs that drop to 34hz? The 700w might be stretching it's legs to keep up. I have a 700w and my two Spires that dip to 29hz felt more powerful. Although not an exact side by side comparison
Thanks both of you for your thoughts. The main thing to point out is that you both read "Ethos" when the model I'm getting are the "Theos" (same panel, different woofer config).
The Theos' response goes down to 43hz and features one 8" passive woofer
The Ethos' response goes down to 34hz and features one 8" passive woofer (identical to Theos) and an 8" active woofer (200w powered amp).
The basic advice among everyone buying and selling Martin Logan is that if you're going to have a dedicated sub, there's no reason to buy the Ethos over the Theos--you can use the $2k price difference to do dedicated subs better. That said, after purchasing the Theos (and a pre/pro and an amp) I don't have another $2k to spend on subs at the moment. Since I have access to a couple of decent (understandably not awesome) options, I want to evaluate my options.
When I demoed the Theos, I heard them paired with a Dynamo 700 and it provided very clearly defined low-end that (at least in the well-set-up demo room) worked very nicely. I'm open to getting rid of both both Dynamos and doing something different; but, I wouldn't have much of a budget to work with above the $750 or so that I'd get out of selling both of those--probably a max at the moment of like $1200.
I got the free Dynamo 700 with my new EM ESL's. Its a capable sub,that will match your Theos well to fill the lower end. A passive 8" woofer is not going to beat a powered sub. You would be fine with music,but for movies,its not going to work. I don't know if you need a pretty sub because of your wife,but if you don't,you could probably get by easily with 2 PSA 15se's. They will be great with music also. I had a PSA XV 15 and it worked great with my ESL's. Also,the wireless on the Dynamo 700 works awesome. I opened mine and used it for a while and still got $500 for it.
Again, room volume is important. You haven't mentioned it other than very large. If your need is only for music, subwoofer requirements go down. A $1200 budget could get you a very nice sub from any of the I.D. companies. Just take a look at what they have to offer. In the meantime, do a subwoofer crawl with your current Dynamo 700 and place it in the best sonic location. That should give you an idea if you have any hope of filling that volume. Then experiment by placing your second sub at different locations to see if it helps or hurts.
Yeah, totally understood! I meant to mention this morning that I'll post the dimensions this evening--a quick back of the envelope estimate put the "open area" right at 5000 sqft--but I don't know how accurate that is. I'm at work today; so no chance to get the measuring tape out!
Ok, took some measurements when I got home this evening. My primary room is 4290 cubic feet with the entire top open to another 1980 cubic feet in a loft for a total just shy of 6200 cubic feet. There's also a small open doorway into the kitchen representing another representing another 2000 or so cubic feet. So, as I said, large room situation (one of the many reasons I dislike my vaulted ceilings).
Been thinking a lot more on this topic tonight--and been doing a bit of research. Subwoofers are an area in which I am way behind in terms of my knowledge and you guys have given me a lot to think about. Outside of this forum, I've honestly never heard of the companies that folks are suggesting--the most experience I've had with subwoofers has been in car audio when I was younger.
All that said, there are a few factors at play here:
Between the new Theos towers, new AV7702 pre/pro, and new XPA-5 amp, I've already almost tripled what I'd originally set out to spend. My original plan was to replace my Motion 40's with a pair of ElectroMotion ESLs...then I demoed the Theos. So, the position I'm in is basically that I won't have any budget for more audio gear for at least 6 months. With that in mind, I'm OK with something that's an "interim solution."
My room is a total of about 6200 cubic feet--far more than I want it to be.
This is not a dedicated theater or even listening room; it's my family room. As such, my primary use for a subwoofer at the moment is to "round out" the low frequencies that my main speakers won't reach. I'm not looking for "gut punching" bass--at least, not as a primary concern.
I like the sound of a good kick drum--and I like a sub to be punchy and crisp with it. Boomy, one-note bass has been the bane of my existence with every subwoofer I've owned (including the quality JLAudio stuff I had in my car) and I honestly don't fully know what I'm doing wrong.
My current use is probably split about 50/50 between Movies/TV and music. I'm far more critical about music and I'm willing to lean towards subwoofers that will provide more accuracy if it means giving up a bit of that "movie theater rumble." I suspect this is why I tend to prefer sealed to ported enclosures.
Lastly, the other items I first listed, a new cabinet and new center are both priority items for me as well. The cabinet especially to clear the large "TV stand" type cabinet out of our living room to free up space.
Thank you all for your suggestions; I'm seriously considering selling what I've got and ordering something from PSA or Rhythmik (honestly, it brings a smile to my face on the PSA site to see the "free shipping + free returns" icon). I hope the extra information I've provided helps with any other advice.
nalthien: Thanks for more detail information. And don't worry about waiting. Get what you need done first. These subwoofers will be available when you decide to purchase your sub. And when you get that sub, you'll need to do a subwoofer crawl test in order to place that sub where it will sound the best at your listening position. The correct location of a subwoofer is critical to your enjoyment.
I fully understand your preference for sealed designs to go along with your ESL panel speakers. I felt the same way for my Maggies. I tested out 3 sealed subs for my panel speakers and was surprised that only one sub passed all of my tests in what I was looking for in music reproduction. However, there are accurate ported subs, so don't let that dissuade you from putting a known accurate ported sub on a short list (such as Rythmik's top dog, the FV15HP -- $1339 for black matte or black oak and $1559 for piano black).
But more in line with your maximum budget, there are two sealed subs that come to my mind, and I've already mentioned one you should really consider for your large room … the PSA XS30se @ $1249 in matte black (I own their previous version, the XS30). The other subwoofer that is worthy of considering would be the E15SE from Rythmik. Price starts at $1024 for black matte, $1174 for black oak and $1349 for piano black (check with Rythmik on the shipping). While I doubt the E15SE will have the output of the XS30se and I'm positive it won't have LFE capability (it is a smaller box than the PSA and has a single 15-inch driver vs. two 15-inch drivers), it's an impressive sub that has accuracy written all over it. Jim Wilson reviewed this sub, along side the $1600 SVS SB13-Ultra (the subwoofer I own -- for music only) and Jim slightly preferred the Rythmik. That's saying something, because the SB13-Ultra is one terrific sub.
I'd also look at the Rythmik F15HP ($1074 in matte black, $1224 black oak and $1399 in piano black. This is the subwoofer I wanted to audition along side the SB13, but there was a 6 month back log at the time (over 1-1/2 years ago), so that didn't happen.
So, it's funny: the 3 models i spent some time comparing this evening were the 3 you mentioned here. I was actually going to ask folks about the comparison between the F15HP vs the FV15HP--folks seem extremely high on the FV15HP and I don't see as much mention of the sealed variant.
Can you elaborate on what you mean by the phrase, "LFE capability?" I know what the LFE channel is; however, I'm not sure how a subwoofer wouldn't be "capable" of reproducing it.
Thanks for all of your help--I really appreciate it!
Wanted to give a quick update. My Theos towers were delivered the other night. I've (for now) paired them with the Dynamo 500 that I had already hooked up. Two reasons: first, I can easily get $500 for the 700 if it's sealed in box and I don't really believe the 700 would be an upgrade over the 500.
Unfortunately, I discovered when I was rewiring for my Emotiva XPA-5 that the thing is an absolute BEAST in terms of dimensions and my current cabinet isn't really adequate. I can make it work if I replace my XLR cables with longer runs that let me put the AV7702 and XPA-5 on opposite sides; but, for now, I'm running everything with the cabinet open. With that said, the new cabinet became a much higher priority than just something I was hoping to add.
So, for now, I'm sticking with my Dynamo 500--I will use the credit from the 700 towards a new cabinet (leaning towards the Salamander Synergy series--though I'm not sure it's even big enough for the XPA-5). It's definitely showing its limits as the low end is FAR less defined than the Theos. Once I sell my Motion 40s and Motion 8, I will be looking at the Rhythmik and PSA options listed above. Thank you for your all of your help! I'll check back when I do make a purchase.
I'm doing some research as I'm really interested in finding out if all this talk about Martin Logan subs are so amazing and just read an Amazon review that was rather strange. I didn't know that a lower model dynamo 500 is bigger than the 700. Why would the mfg do that?
Since dsrussell already answered the first one, I'll answer this: generally speaking, the Dynamo 500 is not a very good subwoofer. It's rated for 29-200hz. Higher end subwoofers will have response down to at least 20hz--many of the better ones go down even lower than that before dropping off. ML doesn't publish response graphs for the 500 and I haven't seen one; however, ML tends to be pretty forthcoming in their literature. I imagine the true usable range is pretty close to what they've published.
In certain room situations, does that equate to no response below 40hz? Yeah, probably.
Joining the party kind of late. I owned the ML Dynamo 300 and it is a brutally awful sub that could NOT make bass in a small closet- boomy noise, but not bass. Haven't heard the 500 or 700, but I just cannot imagine them being very good.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
