Jamo D600 vs SVS PB-2000 - AVS | Home Theater Discussions And Reviews
post #1 of 26 Old 03-25-2015, 09:44 AM - Thread Starter
AllRight's Avatar
Liked: 0
I have the following setup:
Speakers: Wharfedale Diamond 9.4
Subwoofer: Jamo D600
Receiver: Marantz SR4002
I use it mainly for watching movies.
The size of my room is about 1600 cubic feet. I positioned the subwoofer using the crawl method. I ran MRAC and it set the gain of the subwoofer to -5 dB. I set the main volume when watching movies to -10 dB. My subwoofer distorts when watching movies with low bass.
I also have some other problems: the grill is rattling even at moderate levels and the subwoofer stops playing randomly.
I don’t know why the subwoofer distorts (it makes flapping sound). Is it defect or am I driving it to hard?
My only other option is SVS PB-2000, which would cost me 130 eur more. Is the SVS worth the extra cost?
AllRight is offline
post #2 of 26 Old 03-25-2015, 12:02 PM
Blacklightning's Avatar
Quoted: 75 Post(s)
Liked: 58
If you are buying a new sub any way go with SVS.
Blacklightning is offline
post #3 of 26 Old 03-25-2015, 01:53 PM
dsrussell's Avatar
Quoted: 847 Post(s)
Liked: 782
The flapping sound could be a few things. Driving them too hard and they are bottoming out, or perhaps the surrounds have separated (just visually inspect them). Yes, the PB-2000 would be excellent in your 1,600 cu. ft. room.
Music area: Magnepan 3.6, McIntosh MC2205 & C48, SVS SB13-Ultra, Oppo BDP 95 and assorted equipment.
Movie area: EMP Tek R5Bi, PSA XS30, Denon X2000, Oppo BDP 83.
dsrussell is online now
post #4 of 26 Old 03-26-2015, 01:18 AM - Thread Starter
AllRight's Avatar
Liked: 0
I inspected the surrounds and there isn’t any visual damage. I really thought this subwoofer would be big enough for my room, especially because it has THX select 2 certification. However, because of all other problems I’m sending it back (s/w is new).
I can exchange it for a new one or get my money back, but not the whole amount. I’m prepared to lose this money and get the pb-2000 only if there would be some noticeable difference. In my opinion, d600 is a good subwoofer and I like how it sounds, but it is my first s/w, so I don’t have any reference to compare.
I read that a sealed subwoofer is better for a smaller room. Is it true?
AllRight is offline
post #5 of 26 Old 03-26-2015, 01:28 AM
fatbottom's Avatar
Quoted: 793 Post(s)
Liked: 300
"I read that a sealed subwoofer is better for a smaller room. Is it true?"
In my opinion, yes. I had PC Plus, PC Ultra 13, then changed to SB Ultra 13. Much better especially for music. Small room <1000 cu feet
Pivetta Opera
Bose Jewel speakers.
fatbottom is offline
post #6 of 26 Old 03-26-2015, 01:33 AM - Thread Starter
AllRight's Avatar
Liked: 0
Then I guess my room is too big to have any benefit form a sealed subwoofer.
AllRight is offline
post #7 of 26 Old 03-26-2015, 08:28 AM
basshead81's Avatar
Quoted: 68 Post(s)
Liked: 2052
go with the PB or PC2000.
Getting Started with REW: A Step by Step Guide --> http://www.mediafire.com/view/aolmz2..._101_v3.92.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #8 of 26 Old 03-26-2015, 10:06 AM
Quoted: 75 Post(s)
Liked: 58
The only way to know is to test it. eg Sb2000 vs PB2000.
My room is a bit bigger than yours and I run a sealed sub.
If your not music focused go ported if you are music focused... I would still go ported for "must" people.
post #9 of 26 Old 03-26-2015, 10:28 AM
dsrussell's Avatar
Quoted: 847 Post(s)
Liked: 782
No, you will easily see a benefit from cabin gain. You'll also see a benefit with a ported sub, just not as much because of the steeper rolloff.
post #10 of 26 Old 03-26-2015, 11:03 AM - Thread Starter
AllRight's Avatar
Liked: 0
I will probably go with PB2000 now. I didn’t choose it first time, because Jamo was cheaper and better looking.
If I reached dynamic output limit of D600, PB2000 won’t have same problems because it’s ported?
AllRight is offline
post #11 of 26 Old 03-26-2015, 11:36 AM
dsrussell's Avatar
Quoted: 847 Post(s)
Liked: 782
If you drive your PB-2000 to its limits, port chuffing can occur, but like its sealed sibling, has excellent DSP control. The SB-2000 (sealed) won't have a problem with over-driving because of its DSP capability. If you are going to go with SVS, then take a look at their outlet store as well. And any time you reach the $800 price point for a single sub, there are other options to consider. The good thing about SVS (and PSA) is that you can try it out and see if it performs to your expectations. If not, return shipping is on them.
Other options:
Hsu: VTF-3 Mk5 HP (15-inch ported design) @ $799 ($89 shipping): http://www.hsuresearch.com/products/vtf-3mk5HP.html (this should be a fairly big upgrade on the PB-2000)
PSA: XS15se (15-inch sealed design) @ $799 (includes shipping both ways): http://www.powersoundaudio.com/colle...roducts/xs15se (has the same warranty and shipping benefits of SVS, plus it has a 15-inch driver)
Rythmik: LV12R (12-inch ported design) @ $569 (free shipping): http://www.rythmikaudio.com/LV12R.html
post #12 of 26 Old 03-26-2015, 11:47 AM
bgtighe23's Avatar
Quoted: 375 Post(s)
Liked: 109
+1 to the HSU recommendation. If I had an $800 budget, that would be my choice. However, with SVS you get free shipping and a better warranty - so the HSU is a little bit more.
I also thought a company made a $650 15" sealed sub, I can't remember the name, but it was something well known and much better than the SVS SB2000 for only $50 more - like PSA/Rythmik, etc. I just can't remember.
EDIT: apologies, I remember: It's Reaction Audio's S-15 http://reaction-audio.myshopify.com/...aled-subwoofer
The link is a B-Stock sub for $499.
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
HTD Level 3 Review
Receiver : Denon x4000
Speakers : HTD Level 3 Bookshelves - FS52s (surrounds)
Subwoofer : Outlaw LFM-1 Plus and PB1000
Born in 1995 and still continuing my HT journey
bgtighe23 is offline
post #13 of 26 Old 03-26-2015, 11:50 AM - Thread Starter
AllRight's Avatar
Liked: 0
HSU is really nice. But I live in Europe (I updated my profile), so it isn’t an option. I have to hand out $870 for PB2000.
AllRight is offline
post #14 of 26 Old 03-26-2015, 11:53 AM
dsrussell's Avatar
Quoted: 847 Post(s)
Liked: 782
Oops. Never mind. Just go with the PB-2000 and make sure you can return it free of charge if you don't like it.
post #15 of 26 Old 03-26-2015, 11:59 AM - Thread Starter
AllRight's Avatar
Liked: 0
I can return it free of charge, but I have to pay for the shipping back to Norway. That would cost me at least $100.
RA S-15 looks similar to my Jamo D600. If S-15 is much better than SB2000, so it should be D600.
AllRight is offline
post #16 of 26 Old 03-26-2015, 12:26 PM
dsrussell's Avatar
Quoted: 847 Post(s)
Liked: 782
I don't think anyone said the S-15 was much better than the PB-2000. It was a very good alternative to look at (if in the U.S.A.). Jamo is not in the same league with Reaction Audio or any of the other I.D. companies I listed. Didn't you already have problems with the Jamo? It's your choice, of course (and you may like a working Jamo). I understand the problems one can have in Europe vs the U.S. as far as warranty, perks and shipping. In the U.S. we often order a couple different subs and test them in our homes before making a decision. I tested 3 in my home before making my decision.
post #17 of 26 Old 03-26-2015, 12:41 PM - Thread Starter
AllRight's Avatar
Liked: 0
bgtighe23 compared it to SB2000. I did get Jamo for same price as I would get SB2000. Msrp for Jamo is $1700.
Thank you for answering all my questions dsrussell. You’ve been very helpful.
It’s tough decision for me. Anything I buy, I’m then stuck with if I like it or not.
AllRight is offline
post #18 of 26 Old 03-26-2015, 12:53 PM
dsrussell's Avatar
Quoted: 847 Post(s)
Liked: 782
It is indeed a tough decision, especially when you don't have the same recourse as people in the U.S. The Jamo appears to be a good sub and does have DSP capabilities (but obviously not as good as those used by SVS because of the problem you encountered). It also shows a frequency response of 20-200 Hz plus/minus 3 dB. If you can exchange your broken sub (or the amplifier), that might be the easiest and cheapest way to go. In either case, I wish you the best and hope everything turns out well for you.
post #19 of 26 Old 03-27-2015, 07:19 AM
bgtighe23's Avatar
Quoted: 375 Post(s)
Liked: 109
I didn't really mean a lot better as in the RA S-15 blows the SB2000 out the water, but I think its definitely worth the $50 more, given you don't need extension below about 21 or 22hz (in room gain).
Also, I asked about the S-15 B-Stock and this was the reply:
"The S15s are in very good condition with virtually no imperfections. They do come with the same warranty and they will be shipped free."
Now that's a very great deal for $499, free shipping, and a warranty. You might want to try and ask him if you could buy two for $950. I know that is pushing your budget, but if you have experienced nulls, duals will help.
He ended his quick response with:
"Feel free to call at 1 888 315 3437 if you like if you have more questions.
Jeremy
Reaction Audio"
If I had not already purchased my PB-1000, I would have jumped this deal in a heartbeat.
HTD Level 3 Review
post #20 of 26 Old 03-27-2015, 02:21 PM
Kini62's Avatar
Quoted: 543 Post(s)
Liked: 545
Jeremy
Reaction Audio"
OP is located in Slovenia. I think shipping and import duties would add just a "little" to that price.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #21 of 26 Old 03-28-2015, 09:53 AM
bgtighe23's Avatar
Quoted: 375 Post(s)
Liked: 109
Just a little
But a B-stock sub that's under warranty might help save a little cost.
HTD Level 3 Review
post #22 of 26 Old 03-28-2015, 10:38 AM - Thread Starter
AllRight's Avatar
Liked: 0
Bgtighe23, thank you for making inquiry. It is much easier to make satisfactory purchase in U.S. than in EU. My choices are very limited. I only have one sitting position, that’s why I think one good subwoofer would suffice.
SVS has a better warranty than Jamo (5 years vs 1 year). How important is the length of the warranty on a subwoofer?
AllRight is offline
post #23 of 26 Old 03-28-2015, 10:47 AM
dsrussell's Avatar
Quoted: 847 Post(s)
Liked: 782
Obviously, I'd feel a lot better with a 5-year warranty than a 1-year warranty. While drivers rarely fail, the same can't be said for the amplifier. And if your room isn't open to other rooms, your 1,600 cu. ft. room places just outside a small room volume, so any capable ported or sealed design should perform very well within your boundaries.
post #24 of 26 Old 03-28-2015, 01:56 PM
bgtighe23's Avatar
Quoted: 375 Post(s)
Liked: 109
For the most part, I don't think issues are really common in name brand subs. Electronics last a long time. If it works well for the first year, it will probably last for a very long time - I mean, I still have a Nintendo 64 that has no issues! Man, I love it. I know several other people who own much older vintage gear/receivers and amps. The warranty just adds peace of mind so you don't have to worry every time you turn your sub on.
+1
HTD Level 3 Review
post #25 of 26 Old Today, 03:37 AM
MEGATURON's Avatar
Quoted: 101 Post(s)
Liked: 8
The reaction audio is a good deal as well as hsu vtf2 mk4 for $559 i would get that dual hsu instead of 1 svs pb2000. if i could sell my pb2000 for 700 ill get those 2 hsu vtfmk4
MEGATURON is offline
post #26 of 26 Old Today, 10:09 PM
gene4ht's Avatar
Quoted: 73 Post(s)
Liked: 57
I use it mainly for watching movies.....The size of my room is about 1600 cubic feet....My only other option is SVS PB-2000....Is the SVS worth the extra cost?
It's difficult to ascertain the cause or condition of your Jamo subwoofer's performance from afar. If, ultimately, you decide to replace it with an SVS PB-2000, I can (with bias of course) unconditionally recommend it. Your room should accommodate a ported sub without a problem. And if your primary usage is for movies, you will NOT be disappointed. And yes, IMO the PB-2000 is worth the extra money.
Panasonic: PT-AE3000 Front Projector
Elite: 115" Fixed Frame CinemaScope (2.35:1)
Onkyo: TX-NR809
Klipsch: RF-82 II, RC-62 II, RS-52 II, RB-51 II, RB-41 II
SVS: PB-2000 x 2
Panasonic: DMP-BD85
gene4ht is online now
