2 subwoofers a pain? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-05-2015, 01:51 PM - Thread Starter
torii's Avatar
Quoted: 1561 Post(s)
Liked: 852
I have an option of using 2 subwoofers vs the 1 I use now. both older subs(velodyne hgs12 + velo va1512)
my options are to put 1 on side wall and 1 on front wall(right now I have just the hgs 12 on side wall)
are any advantages/disadvantages i should consider?
its a pretty big open room.
the va1512 is a lot boomier than the hgs 12 sealed
curious to hear any thoughts on the 2 vs 1 sub idea?
torii is offline
post #2 of 5 Old 06-05-2015, 04:12 PM
derrickdj1's Avatar
Quoted: 998 Post(s)
Liked: 740
Two subs can help the FR in the room if placed properly. The wrong placement can also result in a worse FR. Do the sub crawl to figure out placement. This may not be where you want them.
derrickdj1 is offline
post #3 of 5 Old 06-06-2015, 06:39 AM
ChromeJob's Avatar
Quoted: 1216 Post(s)
Liked: 641
Send a message via Yahoo to ChromeJob Send a message via Skype™ to ChromeJob
All the articles Ive read recommend subs opposite each other, or along the front wall, not 90º out (front and left-or-right). YMMV.
“He couldn't sign his name any faster than he could duck.”
Are ya new here? Please read FAQs and forum stickies. Like posts that help you. Don't ask a question and then disappear. You will RTFM, even if I have to shame you into doing it.
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen.
ChromeJob is offline
post #4 of 5 Old 06-06-2015, 10:52 AM
derrickdj1's Avatar
Quoted: 998 Post(s)
Liked: 740
Just remember, symmetrical subs will reinforce the same peaks and dips.
post #5 of 5 Old 06-08-2015, 02:36 PM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
The room size and layout are not mentioned and will come into play, especially if one wall is far away or there are large openings to other rooms. Experimentation is your friend, even if you only have two physical locations you can place the subwoofers, try different orientations and see what happens. You may also need to experiment with phase depending upon if the drivers are facing each other or not.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is offline
