Optimizing subwoofers and integration with mains: multi sub optimizer - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 162Likes
post #391 of 777 Old 12-01-2016, 03:18 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 391
Originally Posted by AustinJerry View Post
I have been following the MSO guide that was posted on the MiniDSP forum. The guide recommended setting up three PEQ's, so that is what I did.
You might try using all 6, especially if you go with gain matching. It will take longer to get the best possible answer than it would with fewer PEQs, but I've found that increasing the number of PEQs causes MSO to, in a reasonably short period of time, come up with better answers than it obtained with fewer PEQs and a much longer time. Then it gets better from there with time.
You can add more filters quickly with copy and paste of filters.
This is the first I've read about an experience using MSO with such a tight cluster of measurement points. I never envisioned using it in this way. I think Mike has completely nailed the nature and cause of what can occur with the excessive attenuation of the subs with the least flat response. Some great insight there.
andyc56 is offline
post #392 of 777 Old 12-01-2016, 03:55 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7562 Post(s)
Liked: 4224
I am honored to be a guinea pig. Thanks for the tips. I'll apply them tomorrow.
AustinJerry is online now
post #393 of 777 Old 12-03-2016, 01:54 AM
markus767's Avatar
Quoted: 4189 Post(s)
Liked: 1577
@AustinJerry
Did you also do a wider mic pattern? Would like to see verification that points other than the mic locations do benefit the same as the mic positions themselves.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #394 of 777 Old 12-03-2016, 05:08 AM
Liked: 4224
Originally Posted by markus767 View Post
@AustinJerry
Not yet. I am still working on finalizing the results of my first mic pattern, based on the most recent recommendations from Andy and Mike.
edit: if I do a wider pattern, what mic spacing do you recommend? The first was 1ft radius of the MLP.
post #395 of 777 Old 12-03-2016, 07:12 AM
markus767's Avatar
Liked: 1577
I'd do 2 ft left and right to the MLP. The mic locations like those shown in DLCT. The control points could be an "inverse" of the DLCT locations.
Markus
post #396 of 777 Old 12-03-2016, 07:46 AM
Liked: 4224
Here are the most recent MSO results (labeled "Project 8"). I am now going to run Dirac Live. Changes since the last iteration:
- Removed the individual gain blocks, allowing consolidation of gain in the Shared Filters gain block
- Added three more PEQ blocks per sub (Center freq min value 20Hz), for a total of six PEQ's
- Allowed optimization to run for four hours
post #397 of 777 Old 12-03-2016, 08:20 AM
Liked: 4224
I have to admit, the attenuation of sub2 has me concerned. And what is also strange, Sub's 3&4 are much closer to the MLP. Since all four subs are gain matched, one might think that MSO would attenuate the closer subs more than the further subs. I could be wrong.
post #398 of 777 Old 12-03-2016, 08:24 AM
markus767's Avatar
Liked: 1577
The optimization tries to minimize point to point differences. It doesn't optimize SPL capabilities.
Markus
post #399 of 777 Old 12-03-2016, 08:40 AM
Liked: 4224
I understand, but there is something psychologically unsettling about having one sub's output so severely attenuated. Probably just something I need to get used to.
post #400 of 777 Old 12-03-2016, 09:10 AM
markus767's Avatar
Liked: 1577
Well, you can use your knowledge about specific circumstances and exclude or limit optimization for single speakers. That's the beauty of MSO.
Markus
post #401 of 777 Old 12-03-2016, 10:26 AM
sdurani's Avatar
Quoted: 5072 Post(s)
Liked: 3546
Par for the course when using subwoofer optimization programs, like Harman's SoundField Management (SFM), where one of the subs can be pounding it out while another loafs along. But if that's what it takes to minimize seat-to-seat variance, then so be it. At least in theory.
When SFM was deployed in the field as part of Harman's ARCOS room correction system, the level adjustment capability was usually turned off. They discovered that the algorithm was willing to sacrifice overall bass levels by 9dB in order to gain 0.5 dB of consistency; not worth it.
BTW, even though solving for lowest spatial variance has become synonymous with SFM, the algorithm has the option to solve for max output or flattest response at a single seat, though I've never heard of it being used those ways in actual practice.
Sanjay
sdurani is online now
post #402 of 777 Old 12-03-2016, 10:53 AM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 391
The default maximum attenuation for a PEQ in MSO is 15 dB. It looks like you're getting quite a bit more than that. Did you change that parameter limit in any way, either in the application options or on an individual filter basis?
andyc56 is offline
post #403 of 777 Old 12-03-2016, 11:02 AM
AV_mike's Avatar
Quoted: 115 Post(s)
Liked: 105
Hi Andy,
MSO could be 'stacking' PEQs - giving a much higher overall attenuation. Would need to see the filter report.
Regards, Mike.
andyc56 likes this.
AV_mike is offline
post #404 of 777 Old 12-03-2016, 11:26 AM
Liked: 4224
Interesting parallel, Sanjay. It takes me back to my original question--can an optimization program designed to minimize seat-to-seat variance also optimize a single seating spot? At this point I am not sure it can, at least not without sacrificing some of the principles I have become attached to.
andyc56 likes this.
post #405 of 777 Old 12-03-2016, 12:17 PM
sdurani's Avatar
Liked: 3546
That's like asking if the optimization program can make the peaks & dips the same at all the measurement locations. If all your measurements are from one location, meaning they already have the same peaks & dips, what is left for the optimization program to do?
andyc56 likes this.
Sanjay
post #406 of 777 Old 12-03-2016, 12:22 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 391
I've added a note to the documentation about this issue.
sdurani, AustinJerry and AV_mike like this.
andyc56 is offline
post #407 of 777 Old 12-07-2016, 01:22 PM
Liked: 1
It looks like Dirac has the same issue, and has a similar warning and recommendation:
https://www.minidsp.com/images/docum...r%20Manual.pdf
5.5.1 Listening environment
"The subsequent eight measurements should be well spread out over the entire listening area so that Dirac Live can acquire a good set of measurements that capture the acoustic behavior of the room. Placing all microphone locations too close to each other may result in “over-correction” that will sound dry and dull.
For example, if using the Chair listening area, spread the microphone positions over a circle with a diameter of at least a meter (three feet) and vary the microphone height from the central position by at least 30 cm (one foot) up and down. If using the Sofa listening environment, spread the measurement locations over the full listening area and vary the height up and down by at least 30 cm (one foot)."
andyc56 likes this.
jrett is offline
post #408 of 777 Old 12-15-2016, 12:23 PM
dannut's Avatar
Jerry, sample the room around the single lisening chair as instructed by Dirac - MLP and >6 random positions around that inside a 2m radius. That way you capture most of the modal 'blueprint' of your room that MSO will correct. MSO could be thought of as genuine 3d 'room correction' solution. Others, including Dirac Live, are just one-dimensional EQ.
How are your sources positioned? If you are getting <-15dB gain one one channel then something is not optimal. Upload your measurements.
dannut is offline
post #409 of 777 Old 12-15-2016, 03:43 PM
Liked: 4224
Based on the recent interaction with Andy, MSO does not seem to be a solution designed for me, so I have moved on. No disrespect to you, or to Andy.
post #410 of 777 Old 01-22-2017, 03:18 PM
Quoted: 995 Post(s)
Liked: 522
I'm thinking about buying a new sub amp, and in the process removing a piece from my signal chain.
Has anyone used MSO with a Crown DCI-n or QSC PLD amp? I understand Crown and QSC define Q differently from miniDSP, and perhaps even from each other.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #411 of 777 Old 01-23-2017, 05:14 AM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 391
I can't help with that, but I do plan on removing any recommendation of the iNuke DSP for MSO. The reason is that the resolution for Q adjustment with these amps' DSP is very poor. That's something worth checking when considering other hardware too.
Also, for those who haven't seen it, I wrote an article discussing some of the different PEQ "Q" definitions for different DSP vendors. It may be hard finding out which convention is used.
dgage likes this.
andyc56 is offline
post #412 of 777 Old 01-23-2017, 11:16 AM
Kelvin1965S's Avatar
Quoted: 283 Post(s)
Liked: 184
That's unfortunate Andy; I'm nearing the end of my room build and had planned to spend some time with MSO. I have four subs powered by 2 x iNuke 6000DSP amps. Currently I've used the DSP for some limited pre-Dirac eq and also to fine tune the end result, but I wanted to try out MSO to see if I could further improve my results.
I have only recently got the second 6000DSP so it's unlikely I'll be changing the amp for sometime now, so is it a waste of my time learning MSO with the iNukes? I haven't been able to import my existing REW sweeps into MSO either, but it may not be an issue depending on your response.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #413 of 777 Old 01-23-2017, 12:11 PM
dwaleke's Avatar
Quoted: 1127 Post(s)
Liked: 526
MSO works great with my INUKE dsp. Even if it is not as accurate as other options.
dwaleke is offline
post #414 of 777 Old 01-23-2017, 03:33 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 391
Interesting.
In looking at the iNuke DSP software, the maximum Q for PEQs is 10, and it adjusts in increments of 1 when the Q is 1 or greater. But I have only tested it with no hardware hooked up, as I don't actually have an iNuke DSP. Is this how it behaves with the hardware hooked up too?
Maybe I'll reconsider that change.
andyc56 is offline
post #415 of 777 Old 01-23-2017, 03:38 PM
dwaleke's Avatar
Liked: 526
Interesting.
I'm going off of memory at the moment but iirc you get two decimal places for Q. One decimal place for frequency. .5db accuracy for gain.
dwaleke is offline
post #416 of 777 Old 01-24-2017, 02:10 AM
3ll3d00d's Avatar
Quoted: 1652 Post(s)
Liked: 630
the step size on the adjustment is not linear though, e.g. it steps down from 10 to 9.5 to 9.1 at the top end but increments in 0.02 or 0.03 steps at the very low end. It's a similar story for frequency response in that it is a step of about 0.25 (i.e. 0.2 then 0.3 then 0.2 repeat) in the 20s but is around 0.5 in the 50s. It's been a while since I tried this but REW didn't used to produce filters that agreed with the inuke either (http://www.hometheatershack.com/foru...tml#post621444)
3ll3d00d is online now
post #417 of 777 Old 01-24-2017, 08:53 AM
markus767's Avatar
Liked: 1577
I've done some testing to answer my own question whether only the measured locations get optimized or all points within the measured area. Here's first results (2 subs; red = MLP, grey = other locations; optimization range 30-200Hz).
Optimization points before/after
Control points before/after
ID:	1916521   Click image for larger version
ID:	1916529   Click image for larger version
ID:	1916537   Click image for larger version
Markus
post #418 of 777 Old 01-29-2017, 04:49 AM
markus767's Avatar
Liked: 1577
I've run some more optimizations and added a 3rd sub. Hard to say whether the control points improved as much as the optimization points. It would be helpful if the response curves could be viewed normalized to the MLP. @andyc56 ?
The MSO project with all measurements can be downloaded at https://dl.dropboxusercontent.com/u/...onf-3subs.msop in case you want to play around with exemplary data from a real untreated room.
Attached you can find an overview of room layout and measurement points. You can download the SketchUp data for details at https://dl.dropboxusercontent.com/u/...oom-layout.skp
All data is just temporarily online.
ID:	1927553   Click image for larger version
Markus
post #419 of 777 Old 01-29-2017, 05:33 AM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 391
I like that idea. I'll have a look at putting it into the next release. That may be a while, as I have some home projects in work. Looks like I can use your data to test that feature, so that's helpful.
I too was having trouble figuring out what was going on from the earlier plots, as there's so much data, and the MLP data are different for the plots that need to be compared.
There's also configuration metrics, and I"ll have a look at how those compare in your project.
Svenibaer likes this.
andyc56 is offline
post #420 of 777 Old 01-29-2017, 05:50 AM
markus767's Avatar
Liked: 1577
In the earlier plots I defined the unoptimized combined response as the target curve hoping any reduction in variance would be easier to spot. Guess that didn't work too well That's why a normalization feature would come in handy.
I've removed all filters from the project above so anybody can start start with a clean slate. In my testing I've used delay, gain, polarity inversion and a huge number of filters.
Markus
