Help setting up subwoofer base - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eljaycanuck
post #1 of 5 Old 12-23-2015, 01:10 PM - Thread Starter
Liked: 0
Question Help setting up subwoofer base
Hello guys. How are you all doing?
Folks, I'm new here and I need some help setting up a base for my subwoofer.
I was thinking about something like this:
subwoofer -> mdf base covered in anti-noise fabric -> 4 sorbothane feet on the four corners and some foam in the middle -> mdf base again -> 4 little wheels.
I have a laminated floor and I would love to have a base with wheels, but if that is to affect the sound quality too much, then I'll forget about it.
What do you guys think?
dream3 is offline
post #2 of 5 Old 12-23-2015, 01:29 PM
eljaycanuck's Avatar
Quoted: 788 Post(s)
Liked: 1169
I don't see the purpose of wheels on something that isn't supposed to move around. As for a base, I'd use a square of trimmable, 24" x 24" puzzle mat (like this).
Bill Fitzmaurice likes this.
eljaycanuck is offline
post #3 of 5 Old 12-23-2015, 01:43 PM - Thread Starter
Liked: 0
Hello.
I know but unfortunately the place where it is located tends to accumulate lots and lots of dust. I have to clean it frequently. Wheels would make the job way easier.
So if I add the puzzle mat in the mix along with the wheels attached to the mdf, would that be fine?
dream3 is offline
post #4 of 5 Old 12-23-2015, 05:45 PM
Quoted: 788 Post(s)
Liked: 1169
post #5 of 5 Old 12-23-2015, 05:51 PM
lovinthehd's Avatar
Quoted: 3509 Post(s)
Liked: 3499
Sure would make moving the sub around the room for testing for a good spot easier....as long as the base is solid and doesn't add noise, sounds convenient!
lovinthehd is offline
