Moding Inuke fans for constant 12V? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-16-2016, 11:45 AM - Thread Starter
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
The inuke 6000 DSP runs the fans at 6v on startup and ups the voltage under certain conditions. I'd like to run the fans always at 12V. Is there an easy way to do this without using an external powersupply for the fans?
I'm not good with understanding circuits, but I'm good with surface mount soldering etc and am simply looking for a sufficient +12V/ground tap points. Thanks!
Anthony_Gomez is offline
post #2 of 2 Old 06-20-2016, 03:17 PM
squiers007's Avatar
Quoted: 747 Post(s)
Liked: 362
You'll probably have better luck over in the DIY section... wish I could help more.
Check out my End-Table Marty Build
squiers007 is offline
