Need some help connecting my Difinitive Subwoofer - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By lovinthehd
post #1 of 7 Old 07-23-2016, 12:42 PM - Thread Starter
justinnum1's Avatar
Question Need some help connecting my Difinitive Subwoofer
Hey everyone, i need some help connecting the new subwoofer i got (2nd hand)
It is a difinitive audio prosub 800.
I thought i could just use a subwoofer cable to connect it to a pioneer vsx1023. I included some pictures. there are some other inputs on the sub i am unfamiliar with or if i would need to use those and where they would connect to on the receiver.
i included some pics.
any help would be much appreciated.
thanks
Name:	back of sub.jpg
ID:	1561817   Click image for larger version
Name:	back of reciever.jpg
justinnum1 is offline
post #2 of 7 Old 07-23-2016, 12:51 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
The rca cable is connected to the correct jacks on both the avr and sub in the pictures. The high level (speaker level) inputs you don't need.
lovinthehd is offline
post #3 of 7 Old 07-23-2016, 01:13 PM - Thread Starter
justinnum1's Avatar
hmmm...i have it that way, nothing is coming out of the sub. the red light is on. maybe there is a setting on the receiver i need to configure.
post #4 of 7 Old 07-23-2016, 01:25 PM
lovinthehd's Avatar
Liked: 4775
Maybe try running MCACC again if you haven't. You did tell the avr there is a sub connected and set your speakers to small? Are you sure the sub works?
post #5 of 7 Old 07-23-2016, 01:40 PM - Thread Starter
justinnum1's Avatar
To be honest, I am moving in 5 days and just wanted to test my new aduio gear, i though plugging a few speakers into the reciever would let me test it(the other speakers work. Didn't know there might be a receiver setting for the sub i needed to touch.
I will check out the recievre manual, thought this would be quick and easy
post #6 of 7 Old 07-23-2016, 01:55 PM
lovinthehd's Avatar
Liked: 4775
Look at page 24 to start http://www.pioneerelectronics.com/St...ions011713.pdf
Good luck on this and your move....I hate moving....am done with that!
Madmax67 likes this.
post #7 of 7 Old 07-24-2016, 06:43 AM - Thread Starter
justinnum1's Avatar
I just plugged the sub into a pair of Kanto YU3(desktop powered speakers with a sub out) and the sub works! Now i just have to figure out why it's not working with my pioneer avr
