New Sub Advice - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Maconi
  • 2 Post By eljaycanuck
post #1 of 7 Old 08-11-2016, 08:27 PM - Thread Starter
Maconi's Avatar
Quoted: 29 Post(s)
Question New Sub Advice
I'm in the market for some new subs and all the choices have had my head spinning. My primary use will be HT and I'd like to keep it under $2k per sub. Here's my layout:
Blue lines are windows and red lines are doors (dunno if that matters in the grand scheme of things but included it just in case). Black arrow is stairway to second floor. Ceiling is 8ft.
The open floor plan isn't ideal I know but that's what I have to work with. I'm shooting for dual subs. If I placed them in front of the listening position like in the image I'd be around 10 feet away from them.
I can't fit tall or deep subs. I'm looking for something that's like 30x30x30 or less. I was considering dual JTR 1400's but would that be overkill for my space? Should I be looking at smaller subs or possibly sealed subs (like the JRT S1) instead?
The new Rythmik Audio 18" sub is on my short list as well (interested to see how it compares to the 1400 once it's released).
Thanks for the advice!
oneeyeblind likes this.
Maconi is offline
post #2 of 7 Old 08-11-2016, 08:40 PM
eljaycanuck's Avatar
Quoted: 1107 Post(s)
Liked: 1632
Originally Posted by Maconi
I'm in the market for some new subs and all the choices have had my head spinning. My primary use will be HT and I'd like to keep it under $2k per sub. ... I was considering dual JTR 1400's but would that be overkill for my space? ...
I was going to suggest the Captivator 1400. You've got a huge space to fill - they won't be overkill.
oneeyeblind and dsrussell like this.
eljaycanuck is offline
post #3 of 7 Old 08-11-2016, 10:47 PM
chucky7's Avatar
Quoted: 922 Post(s)
Liked: 720
Your requirements and space demand a pair of JTR Cap 1400s.
Panasonic TC-P55UT50
Pioneer SC-1222-K
Polk Audio LSiM703 / LSiM706c / RTiA3
JTR Captivator 1400
chucky7 is online now
post #4 of 7 Old 08-11-2016, 10:52 PM
basshead81's Avatar
Quoted: 164 Post(s)
Liked: 4723
Cap 1400's for sure!
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #5 of 7 Old 08-12-2016, 07:27 PM - Thread Starter
Maconi's Avatar
Quoted: 29 Post(s)
Thanks for the input all. I was afraid I might be going overkill for my space but it sounds like it might be just right.
Maconi is offline
post #6 of 7 Old 08-12-2016, 09:01 PM
MIX_MASTER_ICE's Avatar
Quoted: 1038 Post(s)
Liked: 795
MUCH better to have more woofage than you need than less than you want.
MIX_MASTER_ICE is online now
post #7 of 7 Old 08-12-2016, 09:03 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4770
Go as big as you can. Two may not be sufficient
lovinthehd is offline
