belkin subwoofer cable - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 2 Post By MIX_MASTER_ICE
  • 1 Post By WantMore
  • 1 Post By eljaycanuck
  • 1 Post By enricoclaudio
  • 3 Post By Bill Fitzmaurice
post #1 of 17 Old 12-09-2016, 01:51 PM - Thread Starter
velocci's Avatar
Quoted: 137 Post(s)
Hi all, does Belkin make good subwoofer cable?
http://www.canadacomputers.com/produ...item_id=020387
www.jvpix.com
system: Onkyo TX-NR 646 AVR with Polk Audio RtiA3 fronts,
BIC America F12 sub and Polk Audio RC-65i rears
velocci is offline
post #2 of 17 Old 12-09-2016, 02:06 PM
MIX_MASTER_ICE's Avatar
Quoted: 1424 Post(s)
Liked: 1195
I have a couple of Belkin RCA cables and they work great. I think Belkin and Mediabridge are two very good brands that don't cost an arm and a leg. You can spend a lot on cables of all sorts, but most of the time it's throwing money away.
yanks1 and Madmax67 like this.
MIX_MASTER_ICE is online now
post #3 of 17 Old 12-09-2016, 03:43 PM - Thread Starter
velocci's Avatar
Quoted: 137 Post(s)
the only length the store has right now is 25 feet. if my speaker wire for the fronts are 15 feet, is 25 feet too long for the subwoofer?
www.jvpix.com
velocci is offline
post #4 of 17 Old 12-10-2016, 11:35 AM
WantMore's Avatar
Quoted: 28 Post(s)
Liked: 56
It won't make a difference, other than having extra cable to hide.
MIX_MASTER_ICE likes this.
WantMore is offline
post #5 of 17 Old 12-10-2016, 01:02 PM
eljaycanuck's Avatar
Quoted: 1351 Post(s)
Liked: 1964
The length of your speaker wire has no bearing on the length of your subwoofer cable. Buy roughly the length of cable you need.
eljaycanuck is offline
post #6 of 17 Old 12-10-2016, 01:36 PM
enricoclaudio's Avatar
Quoted: 1509 Post(s)
Liked: 1656
I had a Belkin subwoofer cable. It was OK. I like the MediaBridge Ultra Series subwoofer cable a bit better and it cost about the same as the Belkin.
https://www.amazon.com/Mediabridge-U...ubwoofer+cable
yanks1 likes this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #7 of 17 Old 12-11-2016, 07:08 AM - Thread Starter
velocci's Avatar
Quoted: 137 Post(s)
you can actually hear the difference between the two cables?
www.jvpix.com
velocci is offline
post #8 of 17 Old 12-20-2016, 05:37 AM - Thread Starter
velocci's Avatar
Quoted: 137 Post(s)
Hi all, as I said before I bought a Belkin cable because the Monoprice cable I ordered was taking too long to arrive. Yesterday it arrived and I notice it was a bit thicker and stiffer. Is it worth me changing to this monoprice cable?
www.jvpix.com
velocci is offline
post #9 of 17 Old 12-20-2016, 05:58 AM
Liked: 1964
Since you have both cables, try them both out. Only you can know for certain if it's worth you changing to that Monoprice cable.
post #10 of 17 Old 12-20-2016, 06:53 AM - Thread Starter
velocci's Avatar
Quoted: 137 Post(s)
I doubt I would hear the difference if there is one, but do you think there would technically be a difference?
www.jvpix.com
velocci is offline
post #11 of 17 Old 12-20-2016, 06:55 AM
Bill Fitzmaurice's Avatar
Liked: 5687
No. Electron waves aren't particularly bright, they can't tell the difference. Neither will your ears.
Frohlich, Blood Simple and Ben Tan like this.
Bill Fitzmaurice is offline
post #12 of 17 Old 12-20-2016, 07:01 AM
Liked: 1964
If you don't hear a difference between the two cables, there is technically no difference regardless of my opinion.
post #13 of 17 Old 12-20-2016, 07:01 AM
Bill Kentucky's Avatar
Quoted: 274 Post(s)
Liked: 262
Some people dislike the connectors on the Monoprice. I have a couple of their sub cables, I have had no issues with them. I also picked up a SVS cable from a member here, the connector on that is definitely better. The Monoprice will probably fall apart with enough handling, whereas the SVS will hold up a lot longer.
__________________________
Current setup: PSA MT-110 L/R, PSA MT-110c center, PSA MT-110sr surround, Dual PSA v3600 subs, Denon x4200w Receiver
Bill Kentucky is offline
post #14 of 17 Old 12-20-2016, 01:10 PM
Liked: 1195
I had a monoprice cable crap out on me right away. If you bent it the right way it would hold signal, but otherwise it wouldn't. Not sure if he still does it or not, but Tom V used to throw in a sub cable for free when you bought a sub from PSA. One I got from him, a Monoprice cable, already had the casing around one end come apart and would slide up and down the cable, not staying screwed on. Needless to say, I no longer look at Monoprice for RCA cables.
Rec Room>Vivitek 1080p projector w/100" screen/Hisense 65" 4K, Onkyo TXNR656, Fluance signature towers & center, AV5 sides, Loft 40 rears, RBH I-12/e x2, I-12 x2 subs. Living Room>Sammy 59" Plasma, Onkyo HTRC560, Klipsch KF28 L/R, KC25 center, Polk RC60i in-wall rears, SVS PB12NSD (x2) subs. PC set up> 27" LG IPS, Onkyo TXNR509, Primus P363's, JBL 550P sub. Master Bedroom>Samsung 42" LED, Pioneer VSX532, Denon 5 spkr set, Jamo J110 sub. Gaming> PS4 (x2), PS3, XBox One (x2), XBox 360
post #15 of 17 Old 12-20-2016, 01:57 PM
CurtP's Avatar
Belden, yes. Belkin, no. Build my own with Belden 1694A coax and Canare RCAP-C53 connectors.
CurtP is offline
post #16 of 17 Old 12-21-2016, 05:49 AM - Thread Starter
velocci's Avatar
Quoted: 137 Post(s)
CurtP, are you answering my original question of whether Belkin makes good subwoofer cables?
www.jvpix.com
velocci is offline
post #17 of 17 Old 12-22-2016, 04:29 AM
CurtP's Avatar
Yes, answering your question. My experience with Belkin cables have been less than positive. Too many that don't work out of the packaging or have a loose connection somewhere. They are the typical made in China cables that you can get anywhere. If I was looking for an inexpensive cable, I'd look elsewhere, or do what I've done and take matters into my own hands. While I agree, for the most part, that wire is wire, the issue I have with cheap cables is the construction and materials. Like the wire not centered in the insulation (and I've seen the conductor poking out of the insulation), the copper being brittle, poor crimps or cold solder joints, insulation that deteriorates after a few years, etc. There's a good chance that you'll never have a problem, like many that use Belkin cables, but I won't risk it on my equipment. I believe in higher quality cables not because it makes my movies sound better, but for peace of mind that they're going to remain reliable. And for me, that means building my own RCA cables with known good components like Belden cable. That's why I said yes to Belden, no to Belkin. And to be clear, I'm not against Chinese made products, I'm against poorly made products. I've never had an issue with Belden wire that was made in China.
CurtP is offline
