I need some help.
I have been debating whether to go wireless or hardwired for my 2nd subwoofer (SVS PB2000), and have settled on hardwired, however I'm opened for suggestions on wireless connection though.
I have used Blue Jean Cables in the past for custom length cables, but not for in wall installation. I am not interested in the DIY route and want to make sure there are no issues, especially since the cable is going in wall. I've experienced bad cable connectors in the past and want to avoid this as much as possible.
Which cable would you suggest for in wall installation (40' run)?
So far these are the Blue Jean cables I've looked at.
1505F (rated for in wall per site)
1694A (best shielding per site, but no mention of in wall rating)
1695A (same as 1694A, but some other special rating - probably won't go for this one though)
LC-1 (rated for in wall)
Thanks...
Thanks...
