Best sub for about $350 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 1 Post By gajCA
  • 3 Post By RKSKYDANCER
  • 3 Post By gajCA
post #1 of 8 Old 02-15-2017, 04:05 PM - Thread Starter
Liked: 0
I have second room setup with a Marantz nr1506 receiver with paradigm Atoms. I am looking for a sub For about $300 for music & movies. Any suggestions? Really just need some decent clean accurate bass not huge room shaking bass as this is in a condo & the neighbors might not appreciate it. Maybe I can't for $300 but I thought I would ask!
Padsterman is offline
post #2 of 8 Old 02-15-2017, 04:13 PM
gajCA's Avatar
Quoted: 2088 Post(s)
Liked: 1248
https://www.amazon.com/SVS-SB12-NSD-.../dp/B009F8Y7SO
If you are near Atlanta I know an AVS member who might be selling one used as he bought an 18" sub to replace it!
Madmax67 likes this.
Geoff A. J., California
gajCA is offline
post #3 of 8 Old 02-15-2017, 05:00 PM
RKSKYDANCER's Avatar
Quoted: 82 Post(s)
Liked: 66
If i absolutely only had $300.00 to spend. I would buy this one. Have not listen to one but looking at the data and frequency specs and knowing Emotiva, it should be a good sounding subwoofer in the $300.00 price range. In fact my Brother is looking at this one or the BASX 8 at $199.00 for his apartment.
http://emotiva.com/products/subwoofers/basx-s10
If you can jump up to $399.00 then i would buy this one. I bought this one myself and it's a excellent performing subwoofer. 10" ported, very good output. accurate tight bass. Very good with movies & music. Impressive subwoofer at $399.00. Very good reviews thru audioholics and Sound & Vision. Check out the web site.
https://rslspeakers.com/speedwoofer10s/
christoofar, yanks1 and Madmax67 like this.
Living room; Samsung PN60F5300B Plasma TV, Marantz SR5008 AVR, Sony UHP-H1 UHD Blu-ray, Definitive Mytho 2's fronts-wall mounted, Definitive Pro Center 1000 speaker, Definitive Di 5.5R in ceiling for surrounds, RSL speedwoofer 10s , Comcast Xfinity HD DVR box.
Garage; Sherwood RX-4105 2 channel stereo receiver, Samsung DVD-C500 CD player, Klipsch KG 2.5 med Oak speakers
RKSKYDANCER is offline
post #4 of 8 Old 02-16-2017, 02:10 PM
garnuts's Avatar
Quoted: 79 Post(s)
Liked: 58
+1 for the SVS SB12-NSD if you can stretch your budget to 399.
I purchased one recently for my bedroom and it's an excellent sub for the price. It's also pretty small for a 12" sub at 14" square.
Living Room: Denon X4000, XPA-5, Polk RTiA9, CSiA6, RTiA3-wides, FXiA4, OWM3, SVS PC12+, 4 Shakers, Epson 5030, VApex 92”, Sony XBR9 52”, PS3, Xbox 360, Darbee, Harmony 1.
Bedroom: Denon X2000, Polk: RTiA3, CSiA4, RTiA1, SVS SB12-NSD, Sony XBR-55X850B, Sony BPD-S590, Xbox 360, RPi2-RasPlex, Darbee, Harmony 510.
Home Office: Onkyo 707, Polk: LSiM 703, LSiM 704, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors, Harmony 610.
garnuts is offline
post #5 of 8 Old 02-16-2017, 03:35 PM
gajCA's Avatar
Liked: 1248
You're going to laugh but in my secondary listening area I have two of these and they are great.
Sure, they play just a bit below 30hz and that's it but one or two might be your solution...especially considering some of the other $300 suggestions don't play any lower.
Just go to Best Buy and pick one up for $90 and if not happy return it.
If you like it but want more just buy another.
I sealed mine with some open cell foam and it tightened up the bass and actually flattened out the frequency according to my testing with tones and an SPL meter.
http://www.bestbuy.com/site/yamaha-8...?skuId=9262781
Sure they don't play as loud as my main sub in my HT that digs down to 15hz but I didn't need that or want that in my secondary 2.2/3.2 system.
Brazle, yanks1 and Squirrel! like this.
gajCA is offline
post #6 of 8 Old 02-16-2017, 04:12 PM
Quoted: 653 Post(s)
Liked: 325
Don't need to impress everyone in secondary systems. I use Polk PSW125 and 15 year old 10" Velodyne DLS sub and they are just fine
yanks1 is online now
post #7 of 8 Old Yesterday, 06:19 AM
falconxr6's Avatar
Another vote for the Speedwoofer 10S.
Yamaha RX-A3060 AV Receiver Emotiva XPA-3 Emotiva A-300 Focal Aria 906 with SS900 stands Focal Aria CC900 Centre Energy Bipole Rears RSL 2 x SpeedWoofer 10 Ultimate Subwoofers Oppo UDP-203 BluRay Logitech Harmony Ultimate Remote Philips 65inch 7101/79 UHD LED Display
falconxr6 is offline
post #8 of 8 Unread Today, 08:24 AM
Quoted: 654 Post(s)
Liked: 769
$350?
An Alpine SWS 15" sub, iNuke 1000DSP and 1.5 sheets of plywood. Spotted the Alpine Dual 4 ohm voice coil version for $99.50 the other day. Build a 6.5 cubic foot box, port it for around 19Hz, bridge the iNuke for 400 real watts into the 8 ohm load, set the DSP to high pass around 17Hz and done. Total cost? About tree fitty--if it was me.
If you think you might want a second sub in the future, get the 4 ohm SWS 15 and use the iNuke3000DSP. 600 real watts per channel into 4 ohms, you can adjust the limiter down depending on Xmax calculations if you like but the amp will run you around $250 by itself. All depends...
Just an option--pick your rabbit hole!
18Hurts is online now
