is it a good setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old Yesterday, 10:56 PM - Thread Starter
Liked: 1
is it a good setup
hi all
i am going to be using the rbh impressions speaker package with two svs pc 2000 subs and 2 rsl speedwoofer 10 subs would these work well intergrate well and blend well with this package thanks
markyboy14 is offline
post #2 of 3 Old Today, 07:20 AM
its phillip's Avatar
Quoted: 63 Post(s)
Liked: 116
no
its phillip is online now
post #3 of 3 Old Today, 07:26 AM
mthomas47's Avatar
Quoted: 2493 Post(s)
Liked: 3100
To expand a little on the above answer, it is not likely that the two RSL subs will integrate well with the two SVS subs, as their frequency responses are entirely different. It's not impossible that you would like the way they sound together, if you want to experiment. But, from a system integration standpoint, you would be much better advised to concentrate on good placement of your dual PC2000's, and to just get them blending well together.
Mike
mthomas47 is online now
